10 to 15 yrs. ago I had Comp Cams grind me a custom solid roller for a customers Street Hemi motor with a 727 and a B&M 069J converter in a 1964 Plymouth Savoy that had 3:54 gears in a Dana 60 with 275x60x15 radails street tires. The cam used non Hemi lobes, probally BB Chevys
that had around 260 @ .050 duration and close to .600 net lift. The motor pulled really hard from a idle to 7000 rpm
EDIT, I built a new Hemi street motor this summer for a new customer, World block with 4.25 bore and 4.25 stroke, 9.4 to 1 compression,custom ground Comp Cams hydraulic roller cam, Moparts single four crate hemi intake that the customer had, 850 CFM Speed Demon carb, crate Hemi iron heads the customer had and Stage V rocker assembly they had. The motor is in a 1968 Charger with a 727 and a Continental custom built 11 inch converter, Dana 60 with 3:73 gears, pulls hard, runs good, idle is fairly nasty but does not load up or do anything stupid
PM if you want one similar to either cam
