Tips and Tricks for Loosening K-Member Bolts
#2026802
03/07/16 10:16 PM
03/07/16 10:16 PM
Posts: 755 Tempe, AZ
loco340cuda
Tempe, AZ
I'm going to take out the k-member on my 70 Cuda so I can clean it up and paint it. I tried a quick test to see how difficult it would be to loosen the 4 bolts and the first one i tried is in their rock solid (I assume the rest are the same way).
The bolts are not rusty but I'm sure they are in there pretty good. I doubt anyone has ever taken out the k-member since it was installed at the factory.
What are some tips and tricks you guys have for removing these bolts?
-Thanks
70 Cuda 340 4 speed - now stroked to 416ci (SOLD) 2017 Mustang Shelby GT350
Re: Tips and Tricks for Loosening K-Member Bolts
[Re: loco340cuda]
#2026812
03/07/16 10:30 PM
03/07/16 10:30 PM
Posts: 12,017 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Big, long breaker bar or oxy-acetylene torch.
Master, again and still
[Re: DaveRS23]
#2026818
03/07/16 10:36 PM
03/07/16 10:36 PM
RapidRobert
Drill a mini hole in the subframe on the insides at the right height just big enough to fit a thin red straw into & blast it good with WD40 every day for several days
[Re: loco340cuda]
#2026845
03/07/16 11:20 PM
03/07/16 11:20 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Took the K member out of my 65 Cuda, don't remember needing anything special to get them out. I might of used my impact gun on it, but I forget.
I do, however, vividly remember taking the K member out of a 79 Newport, that one put me in the hospital for stitches. The captured nut the bolt screwed into had broken free (this was a real rust Texas coast car) and I was using a pickle fork to apply downward pressure in the gap between the K and the frame rails when the fork slipped out and smacked me upside the head. Got 5 stitches on the side of my head where the bone is between the eye and temple. I was using an impact gun then.
[Re: RSNOMO]
#2026873
03/07/16 11:51 PM
03/07/16 11:51 PM
RapidRobert
The torque applied ain't the problem, it is (as said) on a toughie you dont wanna break off the welded nut on the inside with the bolt still threaded into it. Yes with enough grunt put to it it will come loose (& most do) but on occaision the nut itself will break loose & you dont want that to happen
[Re: RapidRobert]
#2026916
03/08/16 12:36 AM
03/08/16 12:36 AM
Posts: 4,951 northwest USA
NANKET
northwest USA
Drill a mini hole in the subframe on the insides at the right height just big enough to fit a thin red straw into & blast it good with WD40 every day for several days OR, you could use a good penetrating lubricant and it will work even better.
[Re: NANKET]
#2026985
03/08/16 02:15 AM
03/08/16 02:15 AM
RapidRobert
Drill a mini hole in the subframe on the insides at the right height just big enough to fit a thin red straw into & blast it good with WD40 every day for several days OR, you could use a good penetrating lubricant and it will work even better. Agreed, there are better choices than the WD40 I mentioned (Kroil/PB blaster & I'm sure others)
[Re: loco340cuda]
#2026997
03/08/16 02:34 AM
03/08/16 02:34 AM
Posts: 12,494 Western Colorado High Desert
moparmarks
Well if the car has always been a Southwestern car then get an impact gun and go at it. If it's a rust belt car then you might want to lube them first and take your time removing them. There are holes at the front of the frames that you can shoot some lube onto the front bolts. Will probably have to drill holes for the rear bolts. I can't begin to count how may frames I've pulled and never have any problems from Western cars but rust belt one can be more work.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: sthemi]
#2027011
03/08/16 02:57 AM
03/08/16 02:57 AM
loco340cuda
Tempe, AZ
Okay you guys have me a little nervous now with breaking the welded nut.
This car is a western car and has minimal rust on it so I don't think the bolt it rusted in. I don't have an air compressor so i will have to use a breaker bar.
I'm thinking I will drill a small hole and use PB blaster. I will try the breaker bar and if I can get it to budge then I most likely throw in the towel and clean the k-member and paint it in place. This is not ideal but better then breaking a nut and having a bigger problem.
[Re: loco340cuda]
#2027012
03/08/16 03:03 AM
03/08/16 03:03 AM
Posts: 4,861 Riverside, Ca
R70RUNNER
Riverside, Ca
As said soak them with PB blaster.. Overnight. Bump it with the impact. If it's rotted enough to fail it's gonna fail. Fix it and move on. I had a Chicago car that was a royal PITA to get out but working slowly and soaking it came out. I'd use caution with a torch on these parts. As in I wouldn't.
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
[Re: R70RUNNER]
#2027016
03/08/16 03:07 AM
03/08/16 03:07 AM
RapidRobert
As said bump the breaker bar as opposed to a steady pull (same principle as the impact). Odds are you will be fine (Do ya feel lucky?)
[Re: dvw]
#2027024
03/08/16 03:16 AM
03/08/16 03:16 AM
Posts: 1,653 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
Try to tighten the bolt first a 1/8 turn or less. Then start to remove. If it starts to bind up tighten /loosen a little in each direction. I've taken many a rusty bolt out with out breaking them or the weld nut in the frame. Patience is the key. Doug This is the ticket. If a very small turn counterclockwise doesn't loosen the bolt, go clockwise a very small turn. Repeat. And add some heat if needed. If you ruin one, get new ones here, bottom of page 114: http://www.amkproducts.com/Catalog_PDF/109-127.pdf
