Page 3 of 20 1 2 3 4 5 19 20
Re: Moparts official power adder thread [Re: n20mstr] #2024683
03/04/16 09:48 PM
03/04/16 09:48 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Originally Posted By n20mstr
NOS doublecross plate jetted 65x2 N, 53x2 F, 6 psi fuel, 23° timing, C12 fuel. Have not even begun to tune it from this baseline.
start leaning it out, drop the fuel psi and timing . then watch it pick up some mph
That's really a little shy of 250Hp and is probably a good bit on the rich side of a razor sharp tune. Has some left assuming converter is right.
If getting it on quicker forces the car to pick the front up, you actually need to get after it MUCH harder, as well as putting some weight on the nose
As far as comparing to car I referenced, there is no comparison. We have a very heavy big inch HEMI, against a 3000lb mediocre small block Nova.
Re: Moparts official power adder thread [Re: FastmOp] #2024772
03/05/16 12:16 AM
03/05/16 12:16 AM
michigan
turbo toad Offline
turbo toad  Offline
michigan
Originally Posted By FastmOp
My top ring is total seal PN 100098
My 2nd is PN 002629
I called total seal and told the it's a street driving big block with 30 pounds of boost lol
Thanks FastmOp
Lets hope this sticky keeps steam and rolling along I always enjoy learning smoke
Check out my build on Facebook Ttoad Hurley its updated regularly
Re: Moparts official power adder thread [Re: turbo toad] #2025505
03/06/16 03:25 AM
03/06/16 03:25 AM
St.Louis ,Mo.
72sat Offline
72sat  Offline
St.Louis ,Mo.
is there a way to split these up into separate groups. I love any and all power adders. but I'm not so smart. would love to keep each adder separate just to keep it a little simpler. there is definitely enough interest, can somebody help make this right????
Re: Moparts official power adder thread [Re: 72sat] #2026363
03/07/16 11:47 AM
03/07/16 11:47 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
This website can't support 1 power adder sticky and will probably go away. Ted was nice enough to give it a try but with only 1600 hits so far it will probably go away. Hits mean traffic, traffic means advertising dollars to help support the site. I think some guys would be surprised to see the cost and time it takes to keep a site like this up and running. Thanks go out to Tom and all the Mods.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Moparts official power adder thread [Re: tboomer] #2026380
03/07/16 12:10 PM
03/07/16 12:10 PM
an8sec70cuda Online content
an8sec70cuda  Online Content
Ian...my combo is a 572" pump gas hemi (800+ hp N/A), 727 trans (footbraking), 4.10 Dana w/ Cal-Tracs and drag radials. The car weighs about 3900 lbs.
The car is set up to run the 1/4. Best N/A pass is 6.05 at 112.9 mph in the 1/8 and 9.54 at 140.4 mph in the 1/4. That was in good air.
best on spray so far is the 8.95 at 149.7 and 5.71 at 121.6 in the 1/8. The air was not too great when I ran that night, but not sure it matters a whole lot when using nitrous.
The converter seems to be on the tight side. I had my converter guy build me one specifically for nitrous, 9" spragless. Seems to have around 6% slip up top. Surprisingly, the 4.10 gear seems to be OK through the 1/4 on the nitrous. Crosses the strip at about 7400.
I'm hoping the switch from the -4 feed to the bigger -6 will help somewhat. Bottle's in the trunk so there's 14 feet of feed line. That much -4 line has to be restrictive?
I have not tried less than 3 tenths delay on the hit. I had it nearly go on the bumper the first night I ran it w/ the new D/A shocks. Got them to where the car is leaving good now w/ the 3 tenth delay. I just have a digiset, no progressive.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Moparts official power adder thread [Re: 72sat] #2026417
03/07/16 12:52 PM
03/07/16 12:52 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I agree, and I understand that "traffic" is the main goal seldom talked about goal here, but seems to me lumping all power adders together serves little purpose to the followers, like combining auto and manual transmissions in one thread. Its enough hassle IMO sorting thru the unrelated stuff that it actually reduces the highly sought after "traffic", and that leads to the widely predicted demise. Not separating is half hearted. I fully admit there may not be enough interest in the first place, but not done well, it just leads to failure. twocents
Re: Moparts official power adder thread [Re: jcc] #2026908
03/08/16 12:29 AM
03/08/16 12:29 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
What size line is best for pressure measurements/gauges on both hot and cold side for a turbo? 1/8" Tubing? Does it matter or effect response time, if it can even be seen by eye?
Re: Moparts official power adder thread [Re: tboomer] #2026953
03/08/16 01:13 AM
03/08/16 01:13 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I used -4 on my waist gate and boost controller.
Re: Moparts official power adder thread [Re: tboomer] #2027090
03/08/16 10:44 AM
03/08/16 10:44 AM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
for steady-state dyno work, we use 1/4" line.
For any high speed measurements we use direct mount transducers with cooled adapters that sample every 0.1-1 crank angle degrees. This is probably outside the requirements and budget, however.
Anyone using turbo speed sensors at the track? I doubt the sizing is that close to the limit of what most are doing, just be interesting to see...
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Moparts official power adder thread [Re: tboomer] #2027099
03/08/16 10:53 AM
03/08/16 10:53 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
My FAST uses SSI pressure sensors. I use them for the oil, fuel and boost pressures. They read 0-100psi.
Re: Moparts official power adder thread [Re: tboomer] #2027217
03/08/16 02:49 PM
03/08/16 02:49 PM
michigan
turbo toad Offline
turbo toad  Offline
michigan
I use 1/4 line as well with either a pushloc or compression fittings for easy removal.
Reference points may very to some degree but off the top of my head
Wastegate (below TB/CARB)
Fuel pressure regulator (carb hat preferable toward the back of the hat where a clean sweep into the inlet of the carb/tb)
Boost vacuum gauge (intake runner)
Blow off valve (below the TB/CARB)
MAP sensor for msd 6al (below the TB/CARB)
Tigger sensor for my ams500 wastegate controller (carb hat) its on a pressure switch much like a hobbs switch
This was how my slant was setup and ill follow close to that same pattern on my twin setup. When i refer to below the carb/thorttle body im refering to the plenum inlet aera
Hope this helps
Re: Moparts official power adder thread [Re: turbo toad] #2027330
03/08/16 06:08 PM
03/08/16 06:08 PM
elmira ny
hp340nos Offline
hp340nos  Offline
elmira ny
looking for some jetting for a nos cheater plate,im currently running a .055n/.045f,, 5 psi flowing through flow tool,and 30*timing total. on pump gas in a 340 stroker 9.8 comp iron head street/strip motor. gap at what would be the next step up in jets for horsepower.current plugs are champion rc9yc.at .030 gap.msd 6al box with the dialback timing box hooked to it.i always db check it on balancer when using the dialback.thanks mike
Re: Moparts official power adder thread [Re: an8sec70cuda] #2027610
03/09/16 12:20 AM
03/09/16 12:20 AM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
thanks that gives me a better understanding whats going on with your combo .the next thing i would look at is front end travel and stiffness and the rate of extension on the front ,i have changed mine to keep the front down on the hit and screw the hit earlier.
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: Moparts official power adder thread [Re: Ian] #2027625
03/09/16 12:35 AM
03/09/16 12:35 AM
birdtracker Offline
birdtracker  Offline
Do nitrous motors like compression? Birdtracker
Re: Moparts official power adder thread [Re: tboomer] #2027976
03/09/16 05:17 PM
03/09/16 05:17 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Every motor likes compression
Re: Moparts official power adder thread [Re: Ian] #2028002
03/09/16 05:56 PM
03/09/16 05:56 PM
Ian...my D/A shocks are a little shorter than my old shocks so I lost about an inch of travel. Between that and tightening up the extension I was able to get the car to leave VERY nicely last time out. Came up about a foot and carried it about 100 feet out.
CHIP
Re: Moparts official power adder thread [Re: birdtracker] #2028003
03/09/16 05:58 PM
03/09/16 05:58 PM
The higher the compression, the smaller your tuning window gets...easier to hurt stuff. Seems like most dedicated nitrous motor stick around 13:1.
CHIP
Re: Moparts official power adder thread [Re: an8sec70cuda] #2028082
03/09/16 08:20 PM
03/09/16 08:20 PM
birdtracker Offline
birdtracker  Offline
thanks for the advice. My motor is 14 1/2 already. Birdtracker
Re: Moparts official power adder thread [Re: jcc] #2028101
03/09/16 08:55 PM
03/09/16 08:55 PM
IL
furious70 Offline
furious70  Offline
IL
I use copper oil psi line and gauge to measure hot side back pressure. This was suggested to me by my 'build mentor' The gauge bounces a lot until you pour the coals to it but I got nice steady reading at the upper rpm range this way.
I found out just how small my Ford SVO turbos were that way and moved up to some Precisions that have a much more friendly ~2:1 ratio (for my big heavy street car I'm fine with that in order to get the responsiveness I want)
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Moparts official power adder thread [Re: furious70] #2028350
03/10/16 04:38 AM
03/10/16 04:38 AM
MR_P_BODY Offline
MR_P_BODY  Offline
A smaller feed line will always respond quicker
BUT it can also have a lot of jump in the gauge
if your using a gauge... a transducer is much
better and faster if your using a data logger..
some of the stuff I was using had a rate of 800
reads per second and there is faster stuff now..
if you want to get rid of the jumping gauge you
can put a small orifice in the gauge to smooth out
the reading.. but it will slow it down
wave
