Re: Moparts official power adder thread
[Re: tboomer]
#2021800
02/29/16 12:15 PM
02/29/16 12:15 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
Well then.My 1st question is,,,what is the max intake manifold air temp before no gain will be realized.So far I have seen 205* in the intake.This is a Roots set up,wonder if it's different for turbo.
[Re: tboomer]
#2021818
02/29/16 12:43 PM
02/29/16 12:43 PM
Posts: 368 michigan
turbo toad
michigan
Im putting together a 470 low deck 4.375 bore with a set of TT ill be running E85 what are you guys running or your recommendations for piston rings? Compression ratio of 9.5 and boost levels between 10 and 15 psi.
Check out my build on Facebook Ttoad Hurley its updated regularly
[Re: turbo toad]
#2021820
02/29/16 12:52 PM
02/29/16 12:52 PM
Posts: 9,099 Rogue River, OR
Jeremiah
Rogue River, OR
I'm getting ready to dyno tune my new 511" low deck this week or next. A few questions:
1) Should I use an inline nitrous filter?
2) Plug gap?
3) How do I purge the fuel solenoid? Through the engine with the bottle turned off?
4) At what RPM should I hit it on the dyno? 5k?
5) The designed max RPM on this combo is 7500. How high should we let it go with the nitrous? Don't worry about my stock block I had it blessed by a holy man.
[Re: Ian]
#2021851
02/29/16 01:43 PM
02/29/16 01:43 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
well done, i love nitrous lets get this tech started ,what quench should you run with a steal rod and 35 cc chamber with 12.5 comp and 350 hit I like to see very timing sensitive smallblocks set up in the .080 range for a lot of nitrous
[Re: Jeremiah]
#2021852
02/29/16 01:53 PM
02/29/16 01:53 PM
Monte_Smith
North Alabama
2) Plug gap?
5) The designed max RPM on this combo is 7500. How high should we let it go with the nitrous? Don't worry about my stock block I had it blessed by a holy man. You nitrous solenoids should have filters, if you bought a kit. Do you fill your own bottles, or have them filled. Most guys who fill use a filter in the fill line to avoid possible contamination in mother bottle. So if this is done no need for an in car filter......But, if won't hurt to run an inline filter. Plug gap .020-.025 You shouldn't need to purge the fuel solenoid, but if you feel you need to, turn the pump on, crack the line and then retighten. Without engine running of course. 4500-5000 will be fine on activation rpm. If you plan to turn the motor to 7500, that's where you should go
[Re: tboomer]
#2022466
03/01/16 11:20 AM
03/01/16 11:20 AM
Posts: 13,354 Marion, South Carolina [><]
an8sec70cuda
Jeremiah...what I've been doing w/ mine is running it on straight C12 when I spray it. I do trailer my car to the track, so I drain the pump 93 out and refill w/ C12 at home. My motor is around 11:1 and I'm spraying about 250 on it. I didn't want the hassle of 2 fuel systems...I did that several years ago w/ this car and it worked ok, I just wanted to keep it simple this time. One big pump and a bunch of regulators, lol.
[Re: tboomer]
#2022564
03/01/16 01:42 PM
03/01/16 01:42 PM
an8sec70cuda
I've never sprayed on pump gas. Not worth the chance of hurting something to me. It is a pain in the rear to drain the tank and make the switch before going to the track every time, but it is what it is.
[Re: tboomer]
#2022683
03/01/16 05:13 PM
03/01/16 05:13 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
Turbo Guys: Ever give any thought to an electric WG actuator?
I guess the way most handle it now are with compressed air and electronic boost controllers.
Many OEMs are going to electric actuators for WG control, as it allows more flexibility (i.e. opening WG at part throttle for increased fuel economy).
While we are not interested in fuel consumption, the flexibility this could offer might be interesting, during staging, etc. I can't help but look at the actuator on my desk and think about adapting it to an external WG.
I guess no sense in reinventing the wheel, but just thinking out loud...
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: tboomer]
#2022766
03/01/16 08:35 PM
03/01/16 08:35 PM
Posts: 258 Stockholm, Sweden
TomsCharger70
Stockholm, Sweden
Nitrous question.
My car runs 10.45 to 10.50 N/A. The BO time in the class I run is 10.10sec, so need to gain about a 1/2 second. It´s not allot, but its still about two car lengths at the finish line, so.. I don´t know if I´ll be able to gain the needed 1/2 second just with chassies tuning (Cal-Tracks, AFCO DA shocks front/rear) and going with a taller slick tire. I ran with a 29.3" diam. Hoosier QTP tire, going 30x9" Hoosier slicks this season. 60ft times kinda suck, got the 60ft down to 1.51sec, but haven´t been able to get the car off the line with out tire spin. I hope with real slicks and some chassies adjustments I´ll be able to get the 60ft times down around 1.45sec. (Hope it would run a 60ft under 1.45sec.)
I don´t think I´d need much nitrous assistance, something like 75hp shot should get me where I need to be?
..any ways, to my questions...
1. Do I need to run higher octane fuel if only adding some 75hp of nitrous? (The engine has 10.8:1 comp. I run on 98oct. pump fuel, don´t know what´s similar in the Usa.)
2. Should I run a separate fuel system or would I be able to run a 75 to 100hp shot with 98oct fuel, just by adding a second regulator for the nitrous fuel feed? (Run a Magnafuel 275 pump)
3. How critical is the carb tune before adding nitrous? Right now the carb (1050 cmf Dominator) runs on the fat side. At full throttle the A/F is around 10.4.
4. How much timing needs to be pulled if adding 75hp shot of nitrous?
5. Should I forget about the whole nitrous deal and just focus on getting the car off the line and get the carb tune better...
-Sorry if my quesions seem dumb, but Im new to nitrous so... I´ll probably have more questions later...
Thanks! /Tom
[Re: tboomer]
#2022775
03/01/16 09:02 PM
03/01/16 09:02 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I am in the same boat as TomsCharger70. I run 6.20's in the 1/8 and I need to pick up around 2-3 tenths to run in my local 6.0 heads up class. I was thinking around trying the same amount of NOS as him. I am also on pump gas but 93 octane. I need the same info as him.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: Gary Robbins]
#2022808
03/01/16 09:58 PM
03/01/16 09:58 PM
Posts: 361 Canada
onig
Canada
You guys spraying a pump gas engine do you ever spray with 93 pump gas or are you always changing out fuels for the track...Smallblock at 9.5 comp !! Always on pump gas, as it is a street/strip ride. 10.5 :1
69 Dart
[Re: Gary Robbins]
#2022817
03/01/16 10:10 PM
03/01/16 10:10 PM
Posts: 4,673 On the parachute mount
n20mstr
You guys spraying a pump gas engine do you ever spray with 93 pump gas or are you always changing out fuels for the track...Smallblock at 9.5 comp !! Gary my sons magnum 360 (all stock except for camshaft and carb intake) runs fastest on plain pump 93. I proved it to him we swapped out 110 race gas and it picked up almost .2 in the quarter mile.
....BAD A$$ STREET CAR.....
[Re: tboomer]
#2022906
03/02/16 12:20 AM
03/02/16 12:20 AM
Posts: 733 jacksonville,FLORIDA
slammedR/T
I was spraying a 200 shot on a 408 small block magnum with 10.2:1 compression and 93 octane, drove it to the track running 5.80-5.90 all day and then drove it home.(1/8 mile times)
Got Eddie Miller building a 410" small block magnum with 11.5:1 compression and will also be spraying a 200 shot on 93 octane in the near future.
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
