Re: Nitrous
[Re: rb446]
#2031605
03/15/16 12:45 PM
03/15/16 12:45 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
ps. thought I was doing ok by getting 1.4sec gain on the 340 with 250hp (110/110 jets), apparently not?, I was only getting about 150hp actual fly hp gain according to the mph/weight.
I got 1.2 sec and 13 mph (on a 12 second car) on a 0.051 jet Something may have been up... Superchuck, in my limited experience, that sounds like a good start. WHat fuel jet and fuel pressure you plan on running?
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
Re: Nitrous
[Re: OUTLAWD]
#2031612
03/15/16 01:00 PM
03/15/16 01:00 PM
Posts: 570 UK
rb446
UK
I got 1.2 sec and 13 mph (on a 12 second car) on a 0.051 jet Something may have been up... No it ran real sweet, rather boring really, all I noticed was that it was all over a bit quicker than usual. I used to run around 12.4's@108 N/a on 98 octane at 36 deg total. I only came back 2 deg, hit it off the line as well and went 122.8, tbh 110/110 was extra safe on the petrol side on those kits as std. back then!.....the chassis was up to it on leafs. A .051 jet was only 125hp if I remember right on the cheater kit, thats half of what I ran, was yours a bone stock motor? Having a seperate pump for N20 is the biggest important thing you can do, although for 100 shot its not necessary, but it IS when you step it up!!
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
Re: Nitrous
[Re: tboomer]
#2031631
03/15/16 01:38 PM
03/15/16 01:38 PM
Posts: 13,356 Marion, South Carolina [><]
an8sec70cuda
rb446...you're right, a lot has changed w/ nitrous in the past 25 years. That 110/110 jetting was not extra safe, just extra rich. There's a reason the jet maps are so different now. And running a separate pump for the nitrous is not necessary. One good pump w/ a separate regulator for each stage is all you need.
Re: Nitrous
[Re: an8sec70cuda]
#2031643
03/15/16 02:00 PM
03/15/16 02:00 PM
Posts: 570 UK
rb446
UK
Yeah thats what I meant, extra safe = extra rich. So todays equivalent NOS Cheater kit or 1 with the same size solenoids would be what in the hp ratings per jet sizes?...I see plates with dual cross bars and all sorts, will have to do some research, so whats the main reason jet maps are so different, retard boxes etc., progressive solenoids?
We don't go much on N20 over here any more cept for some of the Pro-Mod runners and a few Top Sportsman runners, its regarded as cheating by most of the doorslammer guys....I say do what you gotta to win if its allowed, which it is!......I guess there's nothing wrong in being a purist so to say, but.
A lot of guys here are buying big stroker motors at serious $$$$$!!, when they could put together a cheapo 468 chev (sorry), or a Mopar, stick a .600" lift cam and ally heads, x2 .090 thou solenoids and make 1100hp+!!, been done by many when Super Mod was running here, they outran all the big cube N/A boys
Re: Nitrous
[Re: OUTLAWD]
#2031693
03/15/16 03:02 PM
03/15/16 03:02 PM
Posts: 200 midwest
superchuck
On thin ice
On thin ice
midwest
I got 1.2 sec and 13 mph (on a 12 second car) on a 0.051 jet Something may have been up... Superchuck, in my limited experience, that sounds like a good start. WHat fuel jet and fuel pressure you plan on running? The carb is using 72/78 I can't remember the nitrous jet sizes, the kit came with 100/ 150/ 175/ 250 jets. I put in the smallest. Carb fuel pressure is 5 1/2 and I still have the set the pressure for the nitrous, I was thinking the same at 5 1/2. Maybe I should tighten up the spark plug gap? My car is only used for sportman bracket racing, I'll only use the nitrous for test and tune for a few of those WOOHOOO passes. I already had the kit for something else.
Re: Nitrous
[Re: tboomer]
#2031703
03/15/16 03:26 PM
03/15/16 03:26 PM
OUTLAWD
Metro Detroit
The factory jetting recommendations are generally a bit rich. Looking a the Perf. RPM kit instructions on Summit, 100hp looks like 59N/59F. This will likely be rich.
The old powershot plates called for 47N/53F, I think I reversed them to 53N/47F and got close.
I was a overly conservative with mine and went a step colder plug as well pulling more timing.
Re: Nitrous
[Re: tboomer]
#2031713
03/15/16 03:39 PM
03/15/16 03:39 PM
an8sec70cuda
They figured out that rich is not safe, so they leaned out the jetting. They went to square jetting and eventually to the nitrous jets being larger than the fuel jet. Everyone used to just flip flop the jetting, like OUTLAWD said, which made em run a lot better.
A Cheater system will supposedly flow 250 hp max. The orifice in a Cheater nitrous solenoid is only .093", so your 110 jet really did no more than a 93 jet would have. The solenoid was your restriction.
Re: Moparts official power adder thread
[Re: tboomer]
#2031837
03/15/16 07:32 PM
03/15/16 07:32 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Nitrous question. Is it better to "under carb" a heavy dosing nitrous engine? Seems to me that you would get a higher oxygen content with smaller throttle plates. I saw a nitrous specific sheet metal intake with some very small throttle bodies way back when.... Was on a "somewhat" local engine builders car. Very competitive at the time. I wasn't supposed to see it. Always wondered about that.
Re: Nitrous
[Re: an8sec70cuda]
#2031928
03/15/16 10:17 PM
03/15/16 10:17 PM
Posts: 4,673 On the parachute mount
n20mstr
I have -3 lines from my solenoids to the plate. Is it worth it to change the solenoid fittings to -4 and use the -4/-3 combo lines? The line itself looks to be the same size, so the only gain in flow looks to be from the larger -4 fittings on the solenoids. I know all the bigger kits use the -4/-3 lines. I started w/ a small kit and worked up to a big one. Just curious if it's worth the $140+ to change 2 fittings and 4 lines? u Might be minimal, I never tested back to back....but usually any thing you do to increase even the supply of nitrous to the jet helps. I changed from a .116 solenoid to a trash can and the car was totally different.
....BAD A$$ STREET CAR.....
Re: Nitrous
[Re: tboomer]
#2031996
03/15/16 11:45 PM
03/15/16 11:45 PM
Posts: 733 jacksonville,FLORIDA
slammedR/T
The old saying "rich is safe" is total bullcrap!! being extra rich can actually be worse than being extra lean. If you read todays jetting the pros prefer little on the lean side and pull more timing.
Hopefully Monte Smith will chime in and explain this better than I can. But I use to be one of those "fat is safe and more timing means more power" dummies also.
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
Re: Nitrous
[Re: slammedR/T]
#2032225
03/16/16 10:11 AM
03/16/16 10:11 AM
OUTLAWD
Metro Detroit
But I use to be one of those "fat is safe and more timing means more power" dummies also. Agreed. I pulled 10 degrees on a small hit to be safe, when I went to add it back in, it didn't pick up, so I left it out.
Re: Nitrous
[Re: tboomer]
#2032476
03/16/16 04:47 PM
03/16/16 04:47 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
TIMING is what destroys nitrous motors NOT lean. With enough timing out, you can't get one lean enough to hurt it. It will just be down on power, like any other vehicle that is lean. No fuel, no power.
Too many are under the impression that timing MAKES power, it does not. Timing, or spark lead is just where you light the fire based on the efficiency of your engine to get a complete burn. The combination is what makes power, NOT how much timing you run in it.
The "old school" way rich tunes seemed to stand more timing, simply because you were not making near the power you thought you were, because it was dead rich. Way rich, with big loads of nitrous will beat ring lands off pistons faster than you can replace them
Re: Nitrous
[Re: tboomer]
#2032535
03/16/16 06:15 PM
03/16/16 06:15 PM
Posts: 368 michigan
turbo toad
michigan
Duel wideband o2 sensors are a must.
Check out my build on Facebook Ttoad Hurley its updated regularly
Re: Nitrous
[Re: Monte_Smith]
#2032643
03/16/16 08:40 PM
03/16/16 08:40 PM
slammedR/T
The "old school" way rich tunes seemed to stand more timing, simply because you were not making near the power you thought you were, because it was dead rich. Way rich, with big loads of nitrous will beat ring lands off pistons faster than you can replace them Thank you for explaining this, I'm going to inform some other dummies I know.
Re: Nitrous
[Re: tboomer]
#2032654
03/16/16 09:02 PM
03/16/16 09:02 PM
n20mstr
Don't be afraid to retard timing.....I ended up with 8* total....with a ten spread direct port , 4.5 psi flowing and a ten spread plate 5.0 psi flowing...both on at the same time. always retard before you advance .
I banged out rings, head gaskets and Pistons when trying the same tuneup with 12* timing. Just because I thought...how could it run with so little timing ? burn and Learn.....lol
Re: Nitrous
[Re: slammedR/T]
#2032742
03/16/16 11:20 PM
03/16/16 11:20 PM
Monte_Smith
North Alabama
The "old school" way rich tunes seemed to stand more timing, simply because you were not making near the power you thought you were, because it was dead rich. Way rich, with big loads of nitrous will beat ring lands off pistons faster than you can replace them Thank you for explaining this, I'm going to inform some other dummies I know. You saw how I ran that Vette. 870" motor on 4 stages with a 13.0 target air fuel ratio. It WORKS
Re: Nitrous
[Re: tboomer]
#2033039
03/17/16 12:05 PM
03/17/16 12:05 PM
an8sec70cuda
Ran the car last night w/ the exact same setup as last time, except for the bigger -6 feed line from the bottle to the solenoid. The weather was worse last night, yet the car still ran 1 mph faster. ET was almost the same as before. Back in September in better air it ran 8.95 at 149.7 mph. Last night it went 8.96 at 150.6 mph. Much warmer and humid last night...not sure what the DA was. So maybe the bigger feed line leaned it out a little and gained me some MPH. It got quicker when I brought the nitrous in faster. For my last pass I took another degree of timing out and lowered the fuel pressure by about 1/4 lb., but the track went away.
Re: Nitrous
[Re: Monte_Smith]
#2033427
03/17/16 10:15 PM
03/17/16 10:15 PM
slammedR/T
The "old school" way rich tunes seemed to stand more timing, simply because you were not making near the power you thought you were, because it was dead rich. Way rich, with big loads of nitrous will beat ring lands off pistons faster than you can replace them Thank you for explaining this, I'm going to inform some other dummies I know. You saw how I ran that Vette. 870" motor on 4 stages with a 13.0 target air fuel ratio. It WORKS I did I was trying to learn all I could that day from you and Eddie LOL
