Re: it's time for [b]DON'T ASK ME HOW I KNOW[/b]
[Re: cudadoug]
#2019163
02/24/16 11:38 PM
02/24/16 11:38 PM
Posts: 1,505 TN
SCATPACK 1
TN
You are painting your car in a garage at night to avoid the heat of the day, just after you have laid down 4 coats of really slick clear coat, do not let your brother open the garage door to let out the paint fumes, because bugs as big as birds will be attracted to the light reflection in your new shiny clear coat and be there forever. Don't ask me how I know. Jerry
Old Geezer Racing
[Re: v cummins]
#2019167
02/24/16 11:45 PM
02/24/16 11:45 PM
Posts: 1,098 Massillon, Ohio
cudatom
Massillon, Ohio
cudatom - cudadoug are you two guys related Nope but it was funny how we responded back to back. Your entry made me laugh. My wife asked what was so funny. I told he and got the old wife eye roll. I guess guys have a different sense of humor than women.
Ok
[Re: SCATPACK 1]
#2019174
02/24/16 11:52 PM
02/24/16 11:52 PM
Posts: 52,972 Romeo MI
MR_P_BODY
You are painting your car in a garage at night to avoid the heat of the day, just after you have laid down 4 coats of really slick clear coat, do not let your brother open the garage door to let out the paint fumes, because bugs as big as birds will be attracted to the light reflection in your new shiny clear coat and be there forever. Don't ask me how I know. Jerry I know this one for sure.. I'm thinking of repainting my Rampage if this trans works right... and will be shooting it in the day light.... so I can see.. the best paint job I did was JUST before a storm...out doors.. the bugs go away... then push it in the shop.. DAHIK
[Re: cudatom]
#2019271
02/25/16 03:14 AM
02/25/16 03:14 AM
Posts: 20,163 Park Forest, IL
slantzilla
Park Forest, IL
When testing an MSD for spark w/a jumper wire don't have your other hand on a ground.
DON'T ASK ME HOW I KNOW, and that one hurt. lol I was helping a buddy of mine troubleshoot his MSD. He was holding the coil wire to the frame while I tapped the white wire. It sparked and startled him causing him to jerk the coil wire as I tapped the white wire a couple more times. For some reason he won't let me help with electrical stuff anymore.
[Re: HEMIFRED]
#2019522
02/25/16 03:33 PM
02/25/16 03:33 PM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
there are quite a few informative lessons here. I have learned a lot
home of the Sox and Martin Hemi Duster
[Re: BIG DRAG]
#2019558
02/25/16 04:38 PM
02/25/16 04:38 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
When unloading the race car at the track from your open car trailer make sure that the ramps are down. If you pull the car out of gear and then get distracted it will roll back off of the trailer and come to a sliding stop the on the ladder bars. A slight incline will make this happen without any effort. Also try to do it in front of as many people as possible so when you are done laughing they can help you lift the car back on to the trailer because a jack will not have enough reach to do anything. The best part of this method is that if you do it exactly like I did you will at least go to the final round that day. DAMHIKT Also...after driving up on your trailer (that is slightly uphill at the track) DO NOT get distracted by talking about the .002 loss and MAKE SURE you put in park before getting out.
[Re: HEMIFRED]
#2019775
02/25/16 09:21 PM
02/25/16 09:21 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I use to work with a guy that took the drive shaft out of his mustang and it rolled off the ramps and split his head open when it ran over him. He got several stitches in his head. He thought it would not roll since it was in park.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: HEMIFRED]
#2019915
02/26/16 12:39 AM
02/26/16 12:39 AM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
If you use a carb bell to seal your carb to your hood scoop, make sure you remove the hood scoop plug before you attempt your burnout.
5000 rpm Will make enough of a vacuum to make your scoop collapse like a large blueberry souffle falling in the oven.
[Re: HEMIFRED]
#2020001
02/26/16 03:42 AM
02/26/16 03:42 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
Take the hood off the roof of the car before testing the stall of the new torque converter, or moving the car in the trailer. I guess I didn't learn the first time?
[Re: HEMIFRED]
#2020049
02/26/16 10:49 AM
02/26/16 10:49 AM
HEMIFRED
SOUTH JERSEY
don't stand in front of the car when setting the idle in gear make sure it's in park or neutral before winging the throttle for response when it lurches forward you can get run over DON'T ASK ME HOW I KNOW
[Re: HEMIFRED]
#2020231
02/26/16 02:54 PM
02/26/16 02:54 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
Don't use by-pass oil filters,,,,,,,,,,,,,,,,
[Re: HEMIFRED]
#2020282
02/26/16 04:07 PM
02/26/16 04:07 PM
slantzilla
Park Forest, IL
My Dad was on the rescue squad for many years in the little town I am from. one of his favorites was:
Local racer put 2X6's on cement blocks and drove the front end of his big block Challenger up on them and put it in Park. He then proceeded to pull the trans pan and pull the valve body out. Car rolled down and the driver's side header went down on his chest. Only thing that saved his life was he had the torsion bars cranked up 4wd high.
