Re: Can I achieve 400hp with a late 70's 440 on a $2000 budget
[Re: Adam71Charger]
#2025461
03/06/16 02:03 AM
03/06/16 02:03 AM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
Try Delta Cam, they are in Tacoma and can grind any profile that you can think of. BTW I used iron 906 heads (stock valves & ports) out of the yard on my 1st racer and the last cam I used was a DC 296 x .557 Mopar solid cam. The new racer has a Comp hydraulic cam with more lift and duration and it has 906 iron heads that were massaged by a shop in SoCal. The dyno sheets that came with the engine show a max of 514 hp on pump gas. It was not $2,000.00
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: Adam71Charger]
#2026335
03/07/16 10:31 AM
03/07/16 10:31 AM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
If you cut them to 80 cc and cut the intake side the valve cover rail gets thin, at 70 I think it would disappear.
Have a great day Iowan
"obsolete is neat"
[Re: Adam71Charger]
#2026878
03/07/16 11:54 PM
03/07/16 11:54 PM
RapidRobert
do you use rtv in the retainer before laying the seal in? Yes & the Car Quest Victor Reinz JV551 rear main seal kit (just 2 halves & the goop) comes with a tube of it
[Re: Adam71Charger]
#2027535
03/08/16 10:37 PM
03/08/16 10:37 PM
RapidRobert
Its generally cost efficient to have them do it as the tool is expensive for the few times it is used (unless your friends tip you a bit for borrowing it if you buy one). You could redrill the cam bearing vertical feed holes to 1/16 and the ones that feed the heads to 1/8 which is plenty of oil for journals/journals that feed the heads & leaves more oil for more critical areas. probably not a dealbreaker in your deal and it'd be extra labor time for the shop or you could purchase them yourself then drill em & some shops squalk at carry in parts. Short version: yes let your shop install em & bring the cam in with you along with the block
[Re: Adam71Charger]
#2027630
03/09/16 12:39 AM
03/09/16 12:39 AM
Posts: 20,116 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Got the block cleaned and did the honing today. On closer inspection I saw that one of my cam bearings was gouged pretty bad. I've never had to replace cam bearings before, and a lot of the tools are fairly expensive starting around 120, so maybe more cost efficient to have the machine shop R&R the cam bearings for me If you have a shop do it (smart move) take your cam so they can trial fit it after they install the cam bearing. Big block MOPAR and small block Fords are the hardest out there to get in and NOT get a tight bearing.
[Re: Adam71Charger]
#2027672
03/09/16 01:54 AM
03/09/16 01:54 AM
RapidRobert
so total cost is around $100 after tax For that kind of money I would suggest springing for the tool. I just checked ebay & for 150-200 you can get one & the one I have was one of those very reasonably priced ones. I ain't used it yet but I dont anticipate a problem. EDIT the pattern looks real rough in the pic
[Re: Adam71Charger]
#2027685
03/09/16 02:36 AM
03/09/16 02:36 AM
Posts: 10,177 Someplace you aren't
SomeCarGuy
At this point you are just a punch and pistons from a totally fresh short block. Not finishing the deal might be penny wise and pound foolish.
I want my fair share
[Re: Adam71Charger]
#2027794
03/09/16 12:25 PM
03/09/16 12:25 PM
Posts: 74,904 U.S.S.A.
JohnRR
U.S.S.A.
Some cylinders had steady hatch, but some of the areas I reamed wouldnt blend completely with the rest of the cylinder. Can't see picture at work , but not surprised , this is what happens when a novice uses a ridge reamer. For the record, I'm a novice and after having to sleeve a block because a hack went at it with a ridge reamer I'd never recommend it''s use.
[Re: Adam71Charger]
#2027938
03/09/16 04:21 PM
03/09/16 04:21 PM
Posts: 28,063 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Again, a photo of metalwork can be really deceiving. That pic makes you think some freak went after the bore with a piece of 40 grit paper. That can very likely be the camera picking up reflections and making things look worse. In reality, the bore can be smooth as a baby's bottom and we'd never know.
There is no sign of the ridge reamer work so it could either be a nicely done job or an excessively deep cut.
The bores should be very smooth to the touch. I don't see any trace of oil in the bore. You needed to be oiling it before, during, and after honing. If not, you'll have lots of blow by and the rings may never seat.
