LS Springs #1945527
11/05/15 09:58 AM
11/05/15 09:58 AM
Canada
Max Weg Offline OP
Max Weg  Offline OP
Canada
Who's LS springs work the best?
Max Weg
Re: LS Springs [Re: Max Weg] #1945592
11/05/15 12:23 PM
11/05/15 12:23 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
Comp 918, PAC 1218 or PAC 1518. It will need an LS specific valve seal and you'll need to open the shims up about .015 to sit over the guides.
A 1218 is PAC's variant of the 918 and the 1518 is the nitride version that is an endurance spring rated for a little bit more lift.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: LS Springs [Re: Max Weg] #1945928
11/05/15 09:55 PM
11/05/15 09:55 PM
Canada
Max Weg Offline OP
Max Weg  Offline OP
Canada
Great info!!
Max Weg
Re: LS Springs [Re: Max Weg] #1946087
11/06/15 02:21 AM
11/06/15 02:21 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
The above springs listed by Alex are good for the older 5.7 and 6.1 heads. There are better options for eagles and apache heads
Re: LS Springs [Re: Max Weg] #1946197
11/06/15 11:54 AM
11/06/15 11:54 AM
Canada
Max Weg Offline OP
Max Weg  Offline OP
Canada
i am currently working on the older heads but I have som appache and I am looking for some eagles. Any info would be greatly appreciated.
Max Weg
Re: LS Springs [Re: Max Weg] #1946217
11/06/15 12:36 PM
11/06/15 12:36 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Max Weg
this is what BES runs on the newer heads and I bought this kit. it comes with a shim pack. springs and retainers. I looked to see if you can piece part cheaper but I couldn't do it. You could probably get away with not buying the retainers which are stupid money. part numbers are there
http://www.highhorseperformance.com/PSI_Valve_Spring_Manley_Titanium_Retainer_p/1515springkit2.htm
Re: LS Springs [Re: Max Weg] #1946230
11/06/15 12:43 PM
11/06/15 12:43 PM
Canada
Max Weg Offline OP
Max Weg  Offline OP
Canada
Thanks I appreciate the help!! I am currently building 2 Gen 3 hemis to do some testing with so anything i can learn is much appreciated.
Max Weg
Re: LS Springs [Re: Max Weg] #1946421
11/06/15 05:14 PM
11/06/15 05:14 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
Eagles and Apache heads run a different spring. I use a PAC 1220 which is an ovate beehive big block Chevy spring.
PAC has a 1535 for the older heads that is a direct drop in for the old 5.7/6.1.
Re: LS Springs [Re: Max Weg] #1947262
11/07/15 11:33 PM
11/07/15 11:33 PM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
1218x on my old style 5.7 heads.
Alex used to sell FRI and GTP cylinder heads. He knows his stuff.
-'02 Dodge Viper Ex-World Challenge racecar
-'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
Re: LS Springs [Re: Max Weg] #1947496
11/08/15 01:39 PM
11/08/15 01:39 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I'm using Manley Nexteks.
Mopar to the bone!!!
Re: LS Springs [Re: Max Weg] #1949921
11/12/15 12:49 PM
11/12/15 12:49 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
GOOD INFO...love this section
Re: LS Springs [Re: Max Weg] #1995381
01/21/16 07:53 AM
01/21/16 07:53 AM
Germany, Northcoast
Buschi340 Offline
Buschi340  Offline
Germany, Northcoast
i am using LS1511 behive springs with locators and shims since the cages of the stock springs broke...
Re: LS Springs [Re: Max Weg] #2008384
02/09/16 02:29 AM
02/09/16 02:29 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
GM performance has factory springs good to .570 lift and they are only around $60 shipped for a set of 16. I think they are ls9 or ls6 factory springs... just installed a set in my ls1.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
