A Body Barracuda front disc brake hoses
#2007961
02/08/16 03:39 PM
02/08/16 03:39 PM
Posts: 3,287 Stroudsburg, PA
Erik
Stroudsburg, PA
What hoses are correct for an A-body cuda with front discs? All I seem to find are drum hoses. The few that I have found that say disc look like drum hoses in the pics.
Anyone have a pic of the correct front disc brake hoses?
Thanks!
1970 Challenger Convertible soon to be T/A convertible
Contrary to the opinions of some, I am not dumber than I look.
Re: A Body Barracuda front disc brake hoses
[Re: Erik]
#2008017
02/08/16 05:13 PM
02/08/16 05:13 PM
Posts: 74,904 U.S.S.A.
JohnRR
U.S.S.A.
What disc setup are you using, 68-72, or 73 later ? The hoses will be different.
[Re: JohnRR]
#2008029
02/08/16 05:29 PM
02/08/16 05:29 PM
Erik
Stroudsburg, PA
68-72 specifically it's off a '69.
[Re: Erik]
#2008129
02/08/16 07:46 PM
02/08/16 07:46 PM
Posts: 16,117 Mesa, Arizona
dart4forte
Mesa, Arizona
Finelines shows a part # of HSPD4309
Abe Lincoln
[Re: Erik]
#2008621
02/09/16 04:17 PM
02/09/16 04:17 PM
Erik
Stroudsburg, PA
Thanks. It looks like I might have the right hoses. Is there an adapter/fitting to install the hoses to the KH calipers?
[Re: Erik]
#2008639
02/09/16 04:31 PM
02/09/16 04:31 PM
Posts: 5,354 Rancho Cordova, California (Sa...
hemi71x
Thanks. It looks like I might have the right hoses. Is there an adapter/fitting to install the hoses to the KH calipers? Rubber hose connects to the second hard metal line on the caliper.
RF-4C Phantom 69-370 Zweibrucken, Germany
[Re: Erik]
#2009327
02/10/16 04:44 PM
02/10/16 04:44 PM
dart4forte
Mesa, Arizona
Thanks. It looks like I might have the right hoses. Is there an adapter/fitting to install the hoses to the KH calipers? There's a bracket that bolts to either side where the hose mates to the hardline. For the life of me I can't think of the name of this bracket, right on the tip of my tongue. There was an add sometime back from a member selling those brackets.
Abe Lincoln
[Re: Erik]
#2009814
02/11/16 01:25 PM
02/11/16 01:25 PM
Erik
Stroudsburg, PA
Looks like I'll need a set.
[Re: Erik]
#2009880
02/11/16 03:13 PM
02/11/16 03:13 PM
Posts: 3,391 cheshire, ct
davesmopars
cheshire, ct
I sell the KH caliper brake line brackets 35.00 plus shipping
you need the star shape ones and the square hoses
Keeper of the 440 M code Cuda registry mcodecuda@yahoo.com
[Re: Erik]
#2009955
02/11/16 05:17 PM
02/11/16 05:17 PM
Erik
Stroudsburg, PA
Thanks. What else do I need? I assume there's some sort of nipple/attachment right on the caliper. All mine have are a treaded hole.
The brake setup I have is off a '69. Does that make a difference?
[Re: Erik]
#2010472
02/12/16 02:40 PM
02/12/16 02:40 PM
hemi71x
Caliper hard lines: Fine Lines, Inline Tube, Classic Tube.
Pad Hold Down Clips: Any vendor, seller, of your choosing for restoration Mustang parts. Look under 67 Mustang.
Caliper hose mounting Brackets: davescuda, over on forabodiesonly.com for repop brackets.
Original caliper mount bolts to spindle: Unobtanium, obsolete, dinosaur eggs, hens teeth, unavailable. Whatever you can get in grade 8 bolts at Lowes, Ace, Home Depot, stores.
Horseshoe clips holding the brake hose(s) to the mount bracket: Junk yard, or internet restoration companies.
Appears that you got yourself into these 4 piston Kelsey Hayes disc brake systems without knowing what it exactly takes, parts wise, in putting them together, but good luck to you.
[Re: Erik]
#2031044
03/14/16 05:06 PM
03/14/16 05:06 PM
Erik
Stroudsburg, PA
Does anyone know where I can get the correct front hoses with the square shaped mounting/fittings for a '68? Everywhere I look only has the round fittings.
Thanks!
