Does anyone make an inline fuel filter with a check valve?
#2005615
02/04/16 07:43 PM
02/04/16 07:43 PM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
I have a number of cars and since I work 2 weeks out of town sometimes when I get around to driving them I have to spin them a minute to pick up fuel to fire. It doesn't occur if it is driven regularly and it's not like it spins enough to kill a battery but I do feel it takes it toll on starters. It happens to everything from 2 to 6 barrell, Holley and otherwise and all of the big 3. Generally only 3-4 weeks at worst between being driven. I have considered that it is the ethanol evaporating causing even the bowls to be dry.
Thanks in advance, Kevin
Careful, your character's showing!
Re: Does anyone make an inline fuel filter with a check valve?
[Re: Porter67]
#2005693
02/04/16 09:31 PM
02/04/16 09:31 PM
Posts: 2,655 western PA
mopar4ya
western PA
1 to 2oz of gas down the carb is easy enough... Not if it is a shaker hood car.
[Re: mopar346]
#2005709
02/04/16 09:57 PM
02/04/16 09:57 PM
mopar346
Don't want to put an electric pump on most of the cars for a number of reasons and no doubt I could prime them but I really don't know why I should have to. They all have aftermarket stock pumps and clear fuel filters. It's not a huge deal but mainly irritating cause I like my cars to work right. The one with the least trouble is my dually which is a GM with a Q-jet, it has the carb filter with the check valve and even after a month or so it fires after minimal spinning. I'm reasonably sure I'm not the only one with this issue and I'm thinking surely someone make an inline filter with a check valve.
[Re: mopar346]
#2005796
02/04/16 11:43 PM
02/04/16 11:43 PM
mopar346
I have considered that due to the ethanol boiling but I thought I might try it. They don't sit long enough for generic evaporation but with the heat and ethanol maybe. Strangely enough if doesn't do it if I start them the next day with one exception but it's a Ford so who knows what it's issue is.
[Re: mopar346]
#2005822
02/05/16 12:25 AM
02/05/16 12:25 AM
Posts: 10,538 Freeport IL USA
poorboy
Freeport IL USA
Time for all new fuel lines, hoses, hose clams and maybe a new fuel pump.
I suppose the fuel could evaporate from the carb, it has air bleeds that could allow evaporation, (the bowl vent has a hose going to the carbon canister to collect the fumes, right?) The fuel has to be draining back through the pump to make the line between the pump and carb empty. Otherwise it shouldn't take very long for a good fuel pump to refill the carb, unless there was no fuel at the pump. I don't see the fuel flowing back up into the tank, which is often higher then the line. (The fuel line is higher then the tank where it run above the rear axle before dropping down to the frame rails) The section of fuel line above the axle should stop and fuel from returning into the tank between it and the pump. If the fuel can't return to the tank, the fuel line, hoses, or hose clamps must be leaking, or the pump is leaking fuel, or is too weak to move the fuel like it should, otherwise where did the fuel go? Gene
[Re: mopar346]
#2005877
02/05/16 01:26 AM
02/05/16 01:26 AM
mopar346
Well the new parts describe half the cars, only one of the cars was born with a charcoal canister and it is disabled. My guess is that the aftermarket pumps, most of which are new, don't have check valves in them allowing the fuel to drain back, further I think the fuel may be boiling in the line running on the frame rail by the exhaust manifold (factory, everything correctly located and in good shape). The key may be in the quality of fuel which I haven't completely resolved in my head. Most are parked on level surfaces so the line hiegths are correct and prevent drain back into the tank. No fuel leaks that are noticeable under pressure. Not arguing with the ideas just thinking through then out loud. I need to start looking at the fuel filters before fire up to make sure it is what I think it is but I cant imagine it can be anything else the way they act.
[Re: mopar346]
#2005970
02/05/16 09:01 AM
02/05/16 09:01 AM
Posts: 5,777 ohio
ruderunner
ohio
I have the same problem. See through filters mounted code to and slightly above the pumps will tell the tale.
Yes fuel evap from the carbs is going to happen but a good pump will overcome that quickly.
Worst I saw was anew pummp on a cj5, it would go epty in a matter of minutes.
Angry white pureblood male
[Re: mopar346]
#2006015
02/05/16 11:52 AM
02/05/16 11:52 AM
Posts: 3,920 Richmond, Indiana
19swinger70
Richmond, Indiana
My 340 Dart does the same thing. I have a Carter "performance" mechanical pump and the new mini starter. That combo gets fuel to the carb pretty quick.
1970 340 swinger. sublime 1967 barracuda fastback BB 55 Plymouth Project
[Re: mopar346]
#2006045
02/05/16 01:25 PM
02/05/16 01:25 PM
DaytonaTurbo
Manitoba, Canada
I have considered that due to the ethanol boiling but I thought I might try it. They don't sit long enough for generic evaporation but with the heat and ethanol maybe. Strangely enough if doesn't do it if I start them the next day with one exception but it's a Ford so who knows what it's issue is. That would be an incorrect assumption. Fuel isn't going to drain uphill, through your needle and seat to leave the carb. Yet when you go to start your car after it's been sitting for weeks there's no fuel in the bowls, requiring much cranking to refill them enough to fire the car. At starter rpm, mechanical pumps don't seem to refill the carbs all that quick. Fuel's evaporating out of your carb, it happens to all of us with this modern pump swill they call gasoline. A check valve won't do anything for you. My last two carbed vehicles I changed over to electric fuel pumps. All my fueling trouble vanished. Turn the key to run for a few seconds so the electric pump can fill the bowls, pump the gas and hit the key. Doesn't get any easier than that.
[Re: Alaskan_TA]
#2006448
02/06/16 01:08 AM
02/06/16 01:08 AM
mopar346
With four cars, only the /6 car will start quickly after a month. For the three 318 cars, I keep gas in a used mustard bottle, with a squirt down the carb throat they always start. Might just try some high octane mustard. OK, I know the fuel is junk for the most part but I wasn't putting that much creedance in it was just the fuel since others seem to react better than others, all in the same parking conditions. I have 110 leaded out of the pump hear, I might try it in a few cars for a tank and see how they act. I'm not adding electic pumps to most of my cars so that's a no car, is there any additive that has been proven to work? Any that claim to work? Thanks for the input folks.
[Re: mopar346]
#2006461
02/06/16 01:30 AM
02/06/16 01:30 AM
mopar346
Too bad someone doesn't make one that looks and mounts like a regular pump and had a single wire that could be routed on the K-member to be inconspicuous. That I would do to most any of them. Where's Mike Ross, he likes to develop good produces for us, maybe he can take this on and I'll only need 2% of the profits for the idea.
[Re: mopar346]
#2007708
02/08/16 01:08 AM
02/08/16 01:08 AM
DaytonaTurbo
Manitoba, Canada
Too bad someone doesn't make one that looks and mounts like a regular pump You want to mount them back by the tank. Electric pump are better pushers than pullers. Also, keeping the fuel pressurized for the length of the car, rather than under vacuum also solves a whole hose of vapor lock and suction leak problems.
[Re: mopar346]
#2007808
02/08/16 05:54 AM
02/08/16 05:54 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Why not add a priming electric pump that runs in parallel to a check valve, with a 5 second timer off of the ignition, it will fill the bowls and crank if you just turn on the key and wait to crank. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: mopar346]
#2008039
02/08/16 05:40 PM
02/08/16 05:40 PM
mopar346
I know I could use a typical electric pump but I really don't want to add wires and brakcets to my AAR or even either of the RTs. I'm aware they are better pushers and your point about pressurizing the entire line is logical. My thought of the pump on the engine is more from an appearance stand point not to mention there isn't a heavy fuel pressure requirement but in some cases a volume concern with a pump but I would think most any quality electric pump would out perform a stockish mechanical pump.
The other issue I am fighting is why should I have to do anything they worked fine for years and I guess the answer there is the fuel is way worse than I thought and/or I am becoming more in tune to the issue since it is longer between driving each of them now. I'm in PA for a couple of weeks again but I will start experimenting with different fuels when I get home. The Coronet has good fuel in it now so it will be a good test sitting for 2 weeks.
[Re: mopar346]
#2008526
02/09/16 01:39 PM
02/09/16 01:39 PM
Posts: 74,974 U.S.S.A.
JohnRR
U.S.S.A.
I know I could use a typical electric pump but I really don't want to add wires and brakcets to my AAR or even either of the RTs. I'm aware they are better pushers and your point about pressurizing the entire line is logical. My thought of the pump on the engine is more from an appearance stand point not to mention there isn't a heavy fuel pressure requirement but in some cases a volume concern with a pump but I would think most any quality electric pump would out perform a stockish mechanical pump. You can put a pump up front but it is not going to survive very well , all you really need the pump for, it seems , is to prime the carbs on initial start up , Mr Gasket makes one that is in line and that would probably fill that need and you could mount it to something that is already back there and out of the way fairly easily, wiring will not require anything that requires modifying your precious cars ... [/soapbox]this attitude is why there is very little to no aftermarket support for Mopars , the owners won't do anything that is non stock and then [censored] and complain because there is no aftermarket support.[/soapbox] The other issue I am fighting is why should I have to do anything they worked fine for years and I guess the answer there is the fuel is way worse than I thought and/or I am becoming more in tune to the issue since it is longer between driving each of them now. I'm in PA for a couple of weeks again but I will start experimenting with different fuels when I get home. The Coronet has good fuel in it now so it will be a good test sitting for 2 weeks. Dear Mr. Van Winlke, Gasoline is formulated now, thanks to the GUBERMINT, to work in cars with CLOSED LOOP SYSTEM, they don't even vent to atmosphere. Our precious cars are a blip on the radar screen, the gubermint doesn't care about us, adapt or live with it, these are our ONLY choices.
[Re: mopar346]
#2008863
02/09/16 10:38 PM
02/09/16 10:38 PM
mopar346
Well ya'll have convinced me that the check valve issue is probably off base although the one that behaves the best is a GM with a Q-jet that has a check valve filter in the inlet. An electric fuel pump in the rear would require power to be run back to it which isn't the end of the world but I really don't want to do and I'm a little concerned about running an inline pump that runs all the time without a return line, the concern being that it will overpower the needle and seats. Hopefully I will see liveable results with good fuel.
How about this for an idea, I have used a gas cap with a tire valve stem in it in the past to pressurize the tank for starting a flow to drain the tank, what if I used that cap and put about 10 lbs. of pressure to the tank to get the fuel to the engine fast on the first start up. Maybe 5 lbs is better. I might try that on a lesser car to see how it works just incase something doesn't work.
Thanks for the input folks, i have been living with it and will no doubt continue to, no way am I gonna stop driving my cars.
[Re: mopar346]
#2008868
02/09/16 10:45 PM
02/09/16 10:45 PM
astjp2
Utah and Alaska
[Re: mopar346]
#2008895
02/09/16 11:10 PM
02/09/16 11:10 PM
mopar346
No I didn't ignore it, it was just a day or so since I read it so I HAD forgotten it. I understand that is how the modern systems energize and the ones I am familiar with then get a signal from the distributor to run once the engine is spinning. But again it adds wiring I don't care to add.
[Re: mopar346]
#2009379
02/10/16 05:48 PM
02/10/16 05:48 PM
JohnRR
U.S.S.A.
Thanks for the input folks, i have been living with it and will no doubt continue to, no way am I gonna stop driving my cars. A 6psi pump is not going to overpower the needle and seat . As far as pressurizing the tank, that is not going to work because the tank is vented to atmosphere. You'll never pressurize it and 10psi would definitely overpower the needle and seat. A short blast of starting fluid sprayed into the filter would probably get you enough to fill the bowls for a restart?
[Re: poorboy]
#2009620
02/11/16 01:00 AM
02/11/16 01:00 AM
mopar346
So I'm clear about this: You don't want to run a wire and an electric fuel pump that will solve your problem, but you willing to dump raw fuel into your motor, or spray either into the air cleaner assembly, or add a GM inline fuel filter to your Mopar? Because originality is so important, or adding a wire and electric fuel pump is so difficult? UM, OK! You better just leave it in the garage, so you won't hurt your investment by driving it, then the poor start won't be an issue. Gene If you only knew how funny that was........ I have said nothing about dumping fuel (I assume you are talking about priming) or or ether (I believe it is actually too dry and isn't good for any motor) although others have suggested it, The GM filter comment was simply pointing out an example of one in use and the way it started. I do like orginality on certain cars but really love the day 2 thing and as for difficult, I'm not thinking installing an inline, frame mounted or in tank pump would be an issue for me at this point. And as for leaving it in the garage to protect my investment, I have taken my most expensive investment (which I bought in about 15 boxes and assembled from a bare shell to driving status in about 6 months, 90% of the aparts are original to the car, it only had 59K on it), anyway I have driven it about 12,000 miles in the last 18 months including a maiden voyage of 4400 miles and a second trip of 3500 miles. Not to mention I'm not afraid to drop the clutch on any and all of them at 3-4 grand 1000 miles from home. As for the rest of my fleet, my newest vehicle is my dually which is a 88 square body Chevy with the Q-jet on it. Any given week I drive 3-4 true 4 speed muscle cars over 45 years old and average 2-300 miles in the week just riding for no reason at all. So forgive me when I smirk at your suggestion that I should leave any of my cars in the garage for fear of hurting my "investments". A survior should be protected, any restored car can be restored again no reason not to enjoy the devil out of them. Not measuring but very few on this board have the seat time I have, either in the last 35 years of driving or the last 5 or the last year.
[Re: mopar346]
#2010053
02/11/16 07:55 PM
02/11/16 07:55 PM
JohnRR
U.S.S.A.
The only reason for a filter to have a check valve would be because the needle and seat is level with the upper level of the fuel , the only Mopar carb I can think of that has an issue close to that ... off the top of my head ... would be the carter BBD 2bbl ??
Even if the OP was able to adapt/find a filter with a check valve it would do nothing other than lighten his wallet, and waste his time.
I have a can of ether that has top cylinder lubricant ... unless the can is lying to me ???
[Re: mopar346]
#2010180
02/11/16 10:51 PM
02/11/16 10:51 PM
mopar346
Yea, I'm off the check valve thought and will start trying better fuel when I get home. I'll report back the results just to finish the thread. Have heard of ether with lubricant but that would negate all the negative I've heard about it over the years. I had a mud truck that I called druggy that thing refused to start with ether back in the day, even if it sat for a half hour while someone else was in the hole I'd have to shut it. I didn't really care about that engine so I didn't care what I did to it. That is the one I would pressurize the tank on to drain it from time to time, it would pressurize to the point that you could hear the tank flex, the vent must have been stopped up with mud. I do appreciate all the input folks.
[Re: Yellow Fever]
#2010512
02/12/16 03:58 PM
02/12/16 03:58 PM
Posts: 1,638 PA
70Duster
PA
I prefer mine to crank a while as it helps build oil pressure seeing as that drains back as well. Same here.
[Re: mopar346]
#2010812
02/12/16 10:51 PM
02/12/16 10:51 PM
mopar346
Strangely enough, that thought did cross my mind, but in the end I could concile a power wire to a pump more easily.
Anyone recommend an inline pump that doesn't require mounting? IE would fit in the rubber hose like na inline filter. Restricting flow when it was off would also be a concern.
[Re: mopar346]
#2012101
02/14/16 11:15 PM
02/14/16 11:15 PM
Posts: 5,788 Hamilton, Ontario Canada
Magnum
It seems like mopar346's problem has been answered. It's evaporation.
I'd like to add priming SHOULD not be pouring fuel down the venturi. That is a good method of drying off the cylinder walls. Especially when 90% of us will be pouring in way too much. Use a squirt bottle to add 10 or 20 mL into the front bowl. Then you can control the pump shot with the throttle just before you crank.
As for spinning the starter with to build fuel and oil pressure. I'm also guilty of doing this in the past but when you consider oil will not reach the piston rings, wrist pins and walls. Instant fire up is better for engine life.
[Re: mopar346]
#2016274
02/20/16 09:01 PM
02/20/16 09:01 PM
mopar346
I busted off my Coronet today after a 2 week sleep, it is the one I put a tank of high(er) octane non-ethanol in before I left. Pushed the pedal twice and spin it, busted right off. I'll try a different car this week.
[Re: mopar346]
#2016571
02/21/16 01:19 PM
02/21/16 01:19 PM
Magnum
My front bowl isn't attached to pump to shoot. Then you understand which bowl to fill.
[Re: mopar346]
#2016941
02/21/16 11:05 PM
02/21/16 11:05 PM
mopar346
I filled the tank of the AAR today with the good stuff, I'll let it sit for a week or so and see how it acts and report back.
