Page 3 of 3 1 2 3
Re: Does anyone make an inline fuel filter with a check valve? [Re: mopar346] #2010541
02/12/16 04:38 PM
02/12/16 04:38 PM
mopar346 Offline OP
Let me tell ya about fat chicks!
mopar346  Offline OP
Check valve in the filter holds that well since I they don't go long enough between start ups for that to be an issue .............. that I'v noticed anyway, I have to spin them to crank them so the oil pressure is good by the time it fires. grin
Careful, your character's showing!
Re: Does anyone make an inline fuel filter with a check valve? [Re: mopar346] #2010604
02/12/16 06:13 PM
02/12/16 06:13 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
OK, don't laugh me out of the room. It's not original and you'd probably want to hide it, but how 'bout trying a primer ball like on a boat's fuel system. Open the hood, squeeze it a couple times, and crank it up...
Re: Does anyone make an inline fuel filter with a check valve? [Re: mopar346] #2010812
02/12/16 10:51 PM
02/12/16 10:51 PM
mopar346 Offline OP
mopar346  Offline OP
Strangely enough, that thought did cross my mind, but in the end I could concile a power wire to a pump more easily.
Anyone recommend an inline pump that doesn't require mounting? IE would fit in the rubber hose like na inline filter. Restricting flow when it was off would also be a concern.
Re: Does anyone make an inline fuel filter with a check valve? [Re: mopar346] #2012101
02/14/16 11:15 PM
02/14/16 11:15 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
It seems like mopar346's problem has been answered. It's evaporation.
I'd like to add priming SHOULD not be pouring fuel down the venturi. That is a good method of drying off the cylinder walls. Especially when 90% of us will be pouring in way too much. Use a squirt bottle to add 10 or 20 mL into the front bowl. Then you can control the pump shot with the throttle just before you crank.
As for spinning the starter with to build fuel and oil pressure. I'm also guilty of doing this in the past but when you consider oil will not reach the piston rings, wrist pins and walls. Instant fire up is better for engine life.
Re: Does anyone make an inline fuel filter with a check valve? [Re: mopar346] #2012109
02/14/16 11:20 PM
02/14/16 11:20 PM
mopar346 Offline OP
mopar346  Offline OP
My front bowl isn't attached to pump to shoot. grin
Re: Does anyone make an inline fuel filter with a check valve? [Re: mopar346] #2016274
02/20/16 09:01 PM
02/20/16 09:01 PM
mopar346 Offline OP
mopar346  Offline OP
I busted off my Coronet today after a 2 week sleep, it is the one I put a tank of high(er) octane non-ethanol in before I left. Pushed the pedal twice and spin it, busted right off. I'll try a different car this week.
Re: Does anyone make an inline fuel filter with a check valve? [Re: mopar346] #2016571
02/21/16 01:19 PM
02/21/16 01:19 PM
Magnum Offline
Magnum  Offline
Then you understand which bowl to fill.
Re: Does anyone make an inline fuel filter with a check valve? [Re: mopar346] #2016941
02/21/16 11:05 PM
02/21/16 11:05 PM
mopar346 Offline OP
mopar346  Offline OP
I filled the tank of the AAR today with the good stuff, I'll let it sit for a week or so and see how it acts and report back.
Page 3 of 3 1 2 3
