Re: Big block A-body guy's
[Re: dartman366]
#1985190
01/06/16 10:06 PM
01/06/16 10:06 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I'm using the Pro Parts headers. This is my second set in about 30+ years. Original set we got thru Herb McCandless,new set thru Bob Mazzolini. The new Pro Parts style are made for Bob by TTI. They are very nice quality and better tubing.
[Re: ozymaxwedge]
#1985266
01/06/16 11:44 PM
01/06/16 11:44 PM
Posts: 8,193 fredericksburg,va
cudaman1969
fredericksburg,va
The Hedman fenderwell headers that Sixpackgut mentioned are something that I always wanted to try as they made more power than anything else on several cars that I read about.
If you run the hedman fender well headers don't you also run into tire clearance issues where a taller tire will hit plus you can't make Sharp turns without them rubbing. I'm not sure just asking Yes we have them on a Aussie A Body and they rub before you get to full lock, not real big problem on a part time street/drag car. Headman My buddy's car had a set just like those on his dart back in the late 70s, called, Headers by Ed, fit better than the hookers and more tire clearance. Changed plugs from underneath
[Re: dartman366]
#1985282
01/07/16 12:01 AM
01/07/16 12:01 AM
Posts: 19,304 Las Vegas
Al_Alguire
Las Vegas
FWIW I have used Pro Parts and TTI BB A body headers and IMO they both leave a lot to be desired. IMO it is worth they expense of getting headers built.
[Re: dartman366]
#1985426
01/07/16 07:01 AM
01/07/16 07:01 AM
Posts: 2,932 Finalnd, Perkele
jyrki
Finalnd, Perkele
What I have tested, the Hookers are good for tq but limit peak power somewhat, the primaries are extremely long. TTI's are a pain, there really isn't room for underchassis headers, never used the Hedmans, have built my own fenderwells. The shock towers can be chopped and the top ends of the shocks moved outside for a little more room, and pushing the firewall a little back behind the wheels gives you enough room not to limit the tire size.
Plynouth VIP '67 TT IC EFI
[Re: mopar dave]
#1985490
01/07/16 12:29 PM
01/07/16 12:29 PM
Posts: 1,534 bronx n.y
one bad fish
bronx n.y
no, not with a 26" tire. I am going to a 28" so I will see. can u send me a pic of the headers installed
[Re: DoubleD]
#1985495
01/07/16 12:34 PM
01/07/16 12:34 PM
Posts: 6,350 Aurora, Oh.
max_maniac
Aurora, Oh.
You want stainless or steel? lol Hey he is going Big so go stainless - he has a budget (an unlimited budget) I heard this story before! Yes you have ---- where do you think I got it from
[Re: max_maniac]
#1985603
01/07/16 03:30 PM
01/07/16 03:30 PM
dartman366
Mt. Vernon, Ohio
You want stainless or steel? lol Hey he is going Big so go stainless - he has a budget (an unlimited budget) I heard this story before! Yes you have ---- where do you think I got it from Where the heck you guy's getting your info from!!
[Re: dartman366]
#1985890
01/07/16 10:27 PM
01/07/16 10:27 PM
Posts: 687 Ohio
Chad Bittle
Ohio
I've got that kit to build 2" headers, Bill. I don't know if they'd be any good but we can try something. You want them between the frame rails, all the same length tubes, good clearance for easy spark plug removal and easy to get the bolts out...in an A Body? Sounds easy.
[Re: Chad Bittle]
#1985926
01/07/16 11:21 PM
01/07/16 11:21 PM
dartman366
Mt. Vernon, Ohio
I've got that kit to build 2" headers, Bill. I don't know if they'd be any good but we can try something. You want them between the frame rails, all the same length tubes, good clearance for easy spark plug removal and easy to get the bolts out...in an A Body? Sounds easy. sound's about right,,,oh and don't forget easy installation with no loss of knuckle meat.LOL
[Re: dartman366]
#1985996
01/08/16 12:50 AM
01/08/16 12:50 AM
Posts: 20,116 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I've got that kit to build 2" headers, Bill. I don't know if they'd be any good but we can try something. You want them between the frame rails, all the same length tubes, good clearance for easy spark plug removal and easy to get the bolts out...in an A Body? Sounds easy. sound's about right,,,oh and don't forget easy installation with no loss of knuckle meat.LOL I have to remove my engine plate to get the headers off in my new small tire car. Those STOCK firewall rules make things tough. LOL At least he was able to weld the collectors on so I don't have to buy those silly cable systems.
[Re: dartman366]
#1986068
01/08/16 02:35 AM
01/08/16 02:35 AM
Al_Alguire
Las Vegas
We usually have to make a wrench for the plugs but otherwise they are somewhat pain free. Slip on collectors and install and removal is easy
