Starter went south, I think 70 RR
#198356
01/19/09 07:26 PM
01/19/09 07:26 PM
Posts: 2,414 St. Croix, US Virgin Islands
David_in_St_Croi
Our track is finally open again. Naturally, the Road Runner went into Prima Donna mode. Last Saturday we went down and I was having starting problems. The engine is a 383 with a 143 tooth fly and Dynomax headers. The starter motor is a standard Mopar reduction gear starter. The car acted as if the battery was dying. The battery is only 3 months old and is a group 27 battery with over 800 CCA. It normally starts the car fine. The cables are 1/0 tinned marine wire running to the starter, the engine block and the chassis. The car is a 70 Road Runner with a 4 speed fortunately so we were able to push start it.
We put it on a charger for probably an hour or so. I had it on the high charge initially and when it started dropping the amps on the gauge I dropped it to medium charge and kept checking the battery temperature with my hand. It seemed to make no difference, the starter still cranked it slowly.
On Sunday, I put the battery on a charger again. I checked it with a voltmeter and it was over 13 volts. Same symptom. I grabbed the Group 65 battery from Michelle's Land Rover. No difference in cranking. I moved the ground conection from an intake manifold bolt to one of the water pump bolts, one of the top ones that does not go through water, and I wire brushed the threads. The ground cable for the engine goes straight from the engine block to the negative terminal on the battery. I also removed and cleaned both ends of the positive cable. After charging all night the same symptom this morning. Either battery started the Land Rover with no problem.
I suspect the starter is cooked. It is a rebuilt, I believe, that I got locally a couple of years ago. It is only a few millimetres from the header tubes which does not help.
How can I check the starter? Should I drop it out and hook it up to the battery with jumper cables and jump the solenoid terminal? I guess if I do that and it still turns slowly I have my answer.
I have been looking at the RobbMC starter. It looks like a nice piece of kit. Its small size would allow me to wrap it in insulation to protect it, I think. Does anyone have any other suggestions? I looked on Summit's website and all of the better quality small high torque starters appear to be in the same price range.
The vapor lock or fuel delivery problem will be another thread.
Still had a great time at the track of course.
Re: Starter went south, I think 70 RR
[Re: David_in_St_Croi]
#198357
01/19/09 07:28 PM
01/19/09 07:28 PM
Posts: 5,080 organ
maximum entropy
organ
hmmm. sounds like it went north to me.
#198358
01/19/09 07:34 PM
01/19/09 07:34 PM
Posts: 52,972 Romeo MI
MR_P_BODY
How can I check the starter? Should I drop it out and hook it up to the battery with jumper cables and jump the solenoid terminal? I guess if I do that and it still turns slowly I have my answer. Use a amp draw gauge on the starter cable during cranking, sounds like its up there
[Re: MR_P_BODY]
#198359
01/19/09 07:47 PM
01/19/09 07:47 PM
David_in_St_Croi
Is this something I can do at home or do I pull the starter and take it somewhere?
#198360
01/19/09 08:13 PM
01/19/09 08:13 PM
MR_P_BODY
You do that with the starter still in the car, the gauge slips over the postitive cable, ask a old mechanic about them. Its just a small hand held gauge
[Re: MR_P_BODY]
#198361
01/19/09 08:18 PM
01/19/09 08:18 PM
David_in_St_Croi
Thanks, I will ask around. Any idea what the amp draw range should be? The engine is 10.2:1 compression, I think DRAM said cranking pressure was around 180-185 when he built the motor.
#198364
01/19/09 11:45 PM
01/19/09 11:45 PM
Dave, those Robbmc starters are pretty nice, maybe just a little pricey though. we carry the full powermaster line if your interested in something like that. by the way, i wore your (my) T-shirt to the track here. it sparked a lot of interest about your racing on the island. thanks.
[Re: 1_WILD_RT]
#198366
01/19/09 11:54 PM
01/19/09 11:54 PM
sounds like a cool idea, would that make it good to the last drop?
