ADJ PINION SNUBBER #198040
01/19/09 12:32 PM
01/19/09 12:32 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
Everyone is saying to get rid of it but what do you guys put in its place ? The reason I ask is because the aluminum center sec the bolt holes are 2in on center and the iron housing are 2-3/8in on center.I was going to mod the snubber I have but it doesnt have enough meat.Should I cobble 1 up from scratch or just run w/o it?
Re: ADJ PINION SNUBBER [Re: Scamp408] #198041
01/19/09 12:40 PM
01/19/09 12:40 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
Depends on your setup, some 60ft better with a snubber and some don't. My car hooks better with it on. I would try it without and see how it runs.
The only Carbs I care about are under the hood!
Re: ADJ PINION SNUBBER [Re: Scamp408] #198042
01/19/09 12:45 PM
01/19/09 12:45 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If you have good springs with the front segments
clamps this will eliminate the spring rap up which
is what the pinion snubber does. If you have the good
springs you will also need a good adjustable shock
to control the body lift
Re: ADJ PINION SNUBBER [Re: Scamp408] #198043
01/19/09 12:46 PM
01/19/09 12:46 PM
organ
maximum entropy Offline
organ
super stock springs?
Re: ADJ PINION SNUBBER [Re: maximum entropy] #198044
01/19/09 01:01 PM
01/19/09 01:01 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
I have the 002/003 ss springs comp 3 way shocks.I had it set before at 1in off of floor and my 60ft are in the 1.51 range.I was going to put it back on but it will not line up right .I was wondering if I should waste my time to make 1 or just forgetaboutit.
Re: ADJ PINION SNUBBER [Re: Scamp408] #198045
01/19/09 01:33 PM
01/19/09 01:33 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I wouldnt bother with it IF you have your springs
clamped and I would dial those shocks to the max
on extension
Re: ADJ PINION SNUBBER [Re: MR_P_BODY] #198046
01/19/09 07:51 PM
01/19/09 07:51 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
Alot of clamps on now I dont think I can put anymore up frt.
Re: ADJ PINION SNUBBER [Re: Scamp408] #198047
01/19/09 07:58 PM
01/19/09 07:58 PM
Salina ks
572_dup2 Offline
Back On The Bumper!!
572_dup2  Offline
Salina ks
Heres what worked for me. Maybe it will help you out. Click on SS Springs. www.carpetperfect.com
Shawn Jennings
Re: ADJ PINION SNUBBER [Re: 572_dup2] #198048
01/19/09 08:46 PM
01/19/09 08:46 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
Most of the springs are clamped some I cant by the tire.The car always hooked good before never had a problem.I gues I will try it w/o once the track opens.Thanks to all.
Re: ADJ PINION SNUBBER [Re: Scamp408] #198049
01/19/09 10:41 PM
01/19/09 10:41 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
what do the clamps do on a street driven car? I want to add them but I dont want to find out the hard way that its a racing only thing
Re: ADJ PINION SNUBBER [Re: aarcuda] #198050
01/19/09 10:58 PM
01/19/09 10:58 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The clamps on the front segments make the front
more rigid(stiffer). A leaf spring does 2 things
(not counting the side to side location). The
front segment is a trailing link... it holds the
rearend at a certin distance back then acts like a
lesser version of a ladder bar... you want the front
STIFF. The rear segments are the spring portion of
it(holds up the body) that you want somewhat free
moving. But if you get the front nice and stiff you
will need good shocks to control the lift of the body
that the stiff front segments will try to do
Re: ADJ PINION SNUBBER [Re: MR_P_BODY] #198051
01/19/09 11:40 PM
01/19/09 11:40 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
thanks. I might make me a set for the front section. I have some stout shocks in the front (konis) and in the back). I may go with some softer ones in the front to get the front up a bit. my car sits pretty flat as it takes off
