Question about cable routing on TA shifter #197826
01/19/09 09:09 AM
01/19/09 09:09 AM
United States
STLDuster Offline OP
United States
I am about to mount my TA Cheetah Shifter and I am trying to figure out the best place for the cable to go through the floor. I was wondering if the hole for the shift cable should be directly in front of the shifter or if I could get the cable to flex a little of to the passenger side.
If you could post anypictures I would greatly appreciate it.
Thanks!
"No great genius has ever existed without some touch of madness." - Aristotle
Re: Question about cable routing on TA shifter [Re: STLDuster] #197827
01/19/09 10:58 AM
01/19/09 10:58 AM
Q
Quicktree Offline
Quicktree  Offline
Q
it's not going to flex a lot where it comes off of the shifter. why do you need to do that? it only needs about an 1/2" hole.
Re: Question about cable routing on TA shifter [Re: Quicktree] #197828
01/19/09 11:02 AM
01/19/09 11:02 AM
United States
United States
I am just trying to figure out the best way to go about doing this. I have never been around a shifter like this.
Re: Question about cable routing on TA shifter [Re: STLDuster] #197829
01/19/09 11:07 AM
01/19/09 11:07 AM
Q
Quicktree Offline
Quicktree  Offline
Q
just position the shifter where you want it and drill a small hole at the end where the cable will go through. I will see if I can get a pic this after noon. look at my post on protecting front exit shifter cables. it will show you how to do the cable underneath.
Re: Question about cable routing on TA shifter [Re: Quicktree] #197830
01/19/09 11:09 AM
01/19/09 11:09 AM
Q
Quicktree Offline
Quicktree  Offline
Q
Re: Question about cable routing on TA shifter [Re: Quicktree] #197831
01/19/09 11:23 AM
01/19/09 11:23 AM
United States
United States
I was just reading over your post about protecting the shift cables when you posted the link. Those pictures help out a ton! I like the way you ran the cable through the crossmember and looped around that way. I was thinking that I was going to have trouble coming down the passenger side of the transmission and in between the pan and cross member.
Re: Question about cable routing on TA shifter [Re: STLDuster] #197832
01/19/09 03:42 PM
01/19/09 03:42 PM
United States
United States
