Re: Anyone use 440 Source Ultralight stroker crank yet?
[Re: Azzkikrcuda]
#2454075
02/19/18 07:09 PM
02/19/18 07:09 PM
Posts: 103 Washington
weedburner
Washington
If your racing where the engine rpm varies very little, like a Powerglide equipped drag car with 800-1000 rpm drop on a single shift, there won't be much advantage to a liteweight crankshaft / rotating assy. If you are racing where the engine rpm varies a lot, like a 4spd manual drag car losing 2000rpm on each of 3 shifts, weight of the rotating assy can make a big difference.
Here's a comparison of two engines that I installed a street/strip manual 4spd car, only significant difference between them was different component weights. Not Mopar, but the results are still relevant...
...Engine #1 was 4.04" x 3.48" w/ 5.7" i-beam rods, hypers with gas ported spacers and 1.2mm rings (12lb oil), 49lb crank and heavy 8" balancer, 1863g bobweight.
...Engine #2 is 4.03" x 3.48" w/ 6" aluminum rods, forged pistons with lateral gas ports and 1.5mm rings (14lb oil), 42lb crank with pendulum style counterweights, drilled rod journals, 6" balancer, 1492g bobweight .
Both had flat tops with nearly identical quench and compression. Exact same intake and carb, same carb calibration. Exact same cam installed on the exact same intake centerline. Exact same flywheel and pressure plate installed in exactly the same car, same weight, with exactly the same gearing and tires. Even though these tests were a couple weeks shy of 2 years apart, both tests are on the same location with zero tire spin and conditions were very close to the same. The car itself was basically a time capsule...I lost engine #1 a few weeks after the test, and i had other irons in the fire so the car sat until engine #2 was ready to install...just picking up where i had left off with regard to developing the car. Here's the average rates that each engine gained rpm WOT thru the gears...
1st gear 2000 to 4000 rpm- engine #1 1634 rpm/sec........engine #2 1910 rpm/sec (276 rpm/sec difference) = 18.8% gain 1st gear 4000 to 6000 rpm- engine #1 1975 rpm/sec........engine #2 2217 rpm/sec (242 rpm/sec difference) = 12.2% gain 2nd gear 4000 to 6000 rpm- engine #1 1070 rpm/sec.......engine #2 1116 rpm/sec (46 rpm/sec difference) = 4.2% gain 3rd gear 4000 to 6000 rpm- engine #1 535 rpm/sec.........engine #2 541 rpm/sec (6 rpm/sec difference) = 1.1% gain No 4th gear data available for comparison.
As you can see, the quicker an engine sweeps thru a gear, the more you will gain from lightweight components. These two engines might both make around 500ft/lbs each running steady state NA, making engine #2's 12.2% gain in 1st gear from 4-6k roughly equal to around a 60hp advantage over engine #1.
Sometimes it helps to think about what happens in opposite extremes...
A given engine has a maximum acceleration rate that it can gain rpm without any external load at all...like a neutral free-rev. At that point all it's power is being used to accelerate itself, and no power is left over to do external work. The lighter an engine's rotating assembly, the easier/quicker it is to accelerate. Sweeping thru the heart of it's torque curve, engine #1 in my example above could gain rpm without a load at the average rate of 8500 rpm per second. Engine #2 could gain rpm without a load at the average rate of 11,515 rpm per second.
On the other end of the spectrum if a car accelerates and works it's way thru the gears, it eventually reaches a point where the engine can no longer accelerate the car. At that point all the engine's power is being used to overcome friction/drag, and there is no power left over for acceleration. This is also the point where the weight of the rotating assy no longer has any effect at all on the power output of the engine. All the torque the engine is making is reaching the transmission's input shaft, no power is being absorbed by the rotating assy as inertia. Operating WOT against maximum load, engine #1 and engine #2 both make the same power.
Looking at these two extremes makes it easier to understand how acceleration rate can have such a huge effect on dyno data. The two otherwise identical engines will make about the same torque when operating against maximum load at a constant rpm, but if engine #1 were dynoed at an acceleration rate of 8500 rpm per second, it would make zero torque on the dyno. Engine #2 still has power left over to move the needle.
If you are running wide open across the ocean, less crankshaft weight will probably hurt you more than help you. If you are a dirt track sprint car on the pole during a re-start, less crankshaft weight is going to be a “BFD”! Most of us here will fall somewhere in between.
Grant
[Re: Azzkikrcuda]
#2454411
02/20/18 04:25 AM
02/20/18 04:25 AM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
I have an ultralight in my low deck 512. It's going in front of a 4-speed. It wraps up really quick on the test stand. I'll hopefully see how it does in the car this year.
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
[Re: OhioMopar]
#2454436
02/20/18 08:52 AM
02/20/18 08:52 AM
Posts: 12,383 Taxes & Virus's R-US, NY
Dragula
Mine is done, and we have a few passes on it...Hits the convertor hard! I love the way it revs...We are expecting 9.60's out of my combo this year...
[Re: Dragula]
#2454614
02/20/18 03:53 PM
02/20/18 03:53 PM
Posts: 43,123 Bend,OR USA
Cab_Burge
Another thing to consider is total rotational weight on how it affects traction, stick shift car with small C.I. normally will use a heavier flywheel and clutch assembly than a larger motor will due to the difference in the ability of the car to spin the tires, like how a converter stall can affect traction Lightweight is right, big (C.I., carb, exhaust, tires) is best
[Re: AndyF]
#2455620
02/22/18 02:40 PM
02/22/18 02:40 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
Andy... that Scat crank looks pretty nice..what did it take to balance in on your set up Well the crank came balanced for the stroker kit but the pistons ended up being lighter than advertised so we had to re-balance the crank. It took a little work to do the re-balance. Had the crank come un-balanced the job would've been easier. Final bobweight on this crank was 2222 grams so it is fairly light for a big block. Andy, I choose one of 440 Source's Ultra-light cranks for my RB when they were first offered thinking the reduced weight of the reciprocating assembly would be easier on the stock block's mains. I don't have the bob weight handy, but the replacement pistons came in at 524 grams to match the old ones. I had the motor apart to change pistons to lower the compression 2 points and resolve some valve train harmonics issues that resulted from insufficient of spring pressure/ hydraulic rollers being spun to high. There was no sign of cap walk on the parting line or on the caps. How much do you suspect the lighter weight crank and reciprocating assembly actually helps the stock blocks live?
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#2455667
02/22/18 03:54 PM
02/22/18 03:54 PM
Cab_Burge
I'm glad to hear that your not seeing cap walk Are you running the stock caps in your motor? If not what type did you use, steel, aluminum or ductile iron? Thanks for this information
[Re: weedburner]
#2455760
02/22/18 07:08 PM
02/22/18 07:08 PM
Posts: 4,254 Canada
WO23Coronet
Canada
Grant So while accelerating, the heavier rotating assembly takes more power to accelerate (makes sense), but would it still not use more power (although considerably less than when getting up to speed) at a static RPM since you are still having to spin a heavier weight? Even at a static velocity, there's always acceleration when dealing with circular motion, is there not?.
[Re: WO23Coronet]
#2455775
02/22/18 07:36 PM
02/22/18 07:36 PM
weedburner
Washington
Theoretically the entire rotating assy is just an energy storage device, basically one big flywheel. It soaks up energy as it accelerates, then gives that same energy back as it slows down. If that give/take were actually averaging out, there shouldn't be much difference overall in a heavy vs lite crankshaft/flywheel/clutch comparison. But there is a difference that I believe shows up on the time slip for two basic reasons... 1- lower launch rpm compared to the trap rpm. Basically if you were to launch a car at 6000 and trap at 8000, the engine will be burdened with creating enough additional energy during the run to make up that overall 2000rpm difference. Keep in mind the exponential effect that comes with rpm, it takes 16x more energy to accelerate that rotating assy from 6000 to 8000 as it did to accelerate it from 0 to 2000. In this case a lighter rotating assy is an advantage because it will absorb less energy while making up that 2000rpm difference between launch and trap. 2- less energy wasted during a post shift wheelspeed spike. The return of energy after the shift can be so intense that some of the energy released during fallback can be spent in non-productive ways, like knocking the tires loose for an instant. Because a lighter rotating assy releases less energy during fallback, that also reduces the amount of energy wasted as wheelspin after the shift. Grant
[Re: Al_Alguire]
#2455875
02/22/18 11:16 PM
02/22/18 11:16 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Crower can do it as well. Don't have a picture of my Crower crank handy though Al, the Crower price might scare a few of them however.....lol
RIP Monte Smith
[Re: CompWedgeEngines]
#2456052
02/23/18 11:44 AM
02/23/18 11:44 AM
Posts: 9,872 Weddington, N.C.
Streetwize
Weddington, N.C.
But also remember it's only one of the rotating components before the power gets to the ground.....so you really need to add in the sum of all the other (assume they are the same as before for comparison) rotating masses (the converter/flywheel, the trans, the driveshaft, the rear axle, the tires and wheels. Yes the mass is less but you really need the sum of the old sums/sum of the new sums and you see the overall percentage of reduced total mass is far lower than you may perceive. Herb Adam's book "Chassis Dynamics" explains this in much more detail....but even though the motor "free Rev's" much easier with a lighter crank.....remember you still have to hook the load to it.
[Re: Streetwize]
#2456118
02/23/18 02:04 PM
02/23/18 02:04 PM
weedburner
Washington
The example in my post on page 3 was basically a direct heavy vs lite crankshaft/pistons/rods comparison, in a real world 4spd manual trans application. The first part did include ALL of the other rotating components. The difference during the 1st gear WOT pull was equal to about a 60hp gain. By 3rd gear, that gain was down to about 5hp. If one were performing that same comparison on an engine dyno, testing at a single acceleration rate would not tell the whole story. Grant
#2456150
02/23/18 02:37 PM
02/23/18 02:37 PM
Posts: 19,360 Las Vegas
Al_Alguire
Las Vegas
Crower can do it as well. Don't have a picture of my Crower crank handy though Al, the Crower price might scare a few of them however.....lol Well I'm not gonna say you are wrong for sure They do make a nice product. But it certainly is another level of expense to be sure. But worth the money and less then Bryant or Winberg
[Re: Cab_Burge]
#2457891
02/26/18 02:59 PM
02/26/18 02:59 PM
jbc426
West Coast, USA
I'm glad to hear that your not seeing cap walk Are you running the stock caps in your motor? If not what type did you use, steel, aluminum or ductile iron? Thanks for this information Thanks for the insight guys. I'm running the stock caps, ARP studs and a Hughes girdle. Interestingly, the engine runs soooo much smoother throughout the RPM range with the new valve train parts and Mike at B3's geometry kit that it is astonishing. I'm thinking that the harmonics that ate up my last valve train is what is missing from this build and likely why the motor feels like it runs so much smoother now. It's a night and day difference.
