Page 1 of 11 1 2 3 10 11
My bracket hemi build #1970437
12/15/15 09:47 PM
12/15/15 09:47 PM
Renton Washington
Triple Threat Offline OP
Renton Washington
I blew up my small block at the end of the season so I'm moving to the Gen 3 platform.
I'm a bracket racer who makes 200 runs a season on average. My small block made 625 hp or so, and my goal is to make closer to 700 with this Hemi.
This is what I have gathered so far. Still waiting on the pistons to show up but everything else is in my or the machine shop's possession.
2004 5.7 .010 over bore
ARP Main and Head Studs
4.050 SCAT Crank
Scat H beam rods
Custom JE pistons, 15cc Dome, shooting for 13:1
Cometic head gaskets
Apache heads with some porting
Custom Camshaft 258/264@.050, .620/.630
Ritter intake, Dominator Flange, short version
Stock lifters and valvetrain
My trusty E85 1050 Dominator by AJ Casini
MSD 6 hemi with the 06+ style coils to fire it.
727, 8" Ultimate converter that flashed to 5800 behind my 450" small block.
4.10 rear gear for now.
My goal is to run 10.0's at 3350#. If its faster that's cool too. Will it happen, I dunno, but we're gonna find out. If it doesn't, I have shoe polish.
Still need to acquire headers, oil pan and other little items as we begin assembly.
For better or worse I'll share what I learn as we go and how it runs. Shout out to Ray (sixpackgut) and Rod (Just-A-Dart) for their help selecting pieces for this deal and sharing what they have learned.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: My bracket hemi build [Re: Triple Threat] #1970505
12/15/15 11:09 PM
12/15/15 11:09 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Please keep us in the loop, I am looking forward to hearing the details.
"Just a Bracket car dressed up like a streetcar"
Re: My bracket hemi build [Re: Triple Threat] #1970528
12/15/15 11:33 PM
12/15/15 11:33 PM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
Solid Combo! Good luck with it.
Re: My bracket hemi build [Re: Triple Threat] #1970553
12/15/15 11:56 PM
12/15/15 11:56 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I'm thinking it would exceed your expectations. That cam and those heads will make some serious steam.
Mopar to the bone!!!
Re: My bracket hemi build [Re: Triple Threat] #1970603
12/16/15 01:10 AM
12/16/15 01:10 AM
Stinnett, Tx
rumblebee4232 Offline
Stinnett, Tx
4.050 SCAT Crank
Scat H beam rods
My build is pretty close to yours--
2005 5.7 block 0.020 over
molnar 4.05 crank
molnar H beam rods 6.125 long
Diamond pistons 3.937 bore 14.6cc dome
Apache heads
hughs 5422 intake
holley dominator
MSD6 hemi ignition with harness's for both the 05 and down coils and the 06 and up coils (Also have the Holley Dominator FI system)
224/228@0.050 0.547 /0.550
Th350 5600 converter
Ford 9 inch 4.10 gears
weight should be about 2300lbs
ARP head and main studs
not sure of the header brand because I bought them off craigslist
modified the oilpan myself for increased capacity ( have not measured total capacity yet)
Re: My bracket hemi build [Re: Triple Threat] #1970788
12/16/15 01:26 PM
12/16/15 01:26 PM
Renton Washington
Renton Washington
That is a very similar build other than the cam. What are you putting it in that weighs 2300? Roadster?
-Dustin
Re: My bracket hemi build [Re: Triple Threat] #1970913
12/16/15 04:57 PM
12/16/15 04:57 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
it will be really great when there is a bunch of us to compare notes with. For a while now, its only been Me, Steff and Rick that have been able to ask each other questions about things and I have learned a lot from those guys so it should only help the more people we get to get info from.
The one day when me and Steff were at the track together, When Steff started his car, me and my friends all looked at each other and said the same thing. They sounded exactly alike.
Re: My bracket hemi build [Re: Triple Threat] #1971119
12/16/15 10:44 PM
12/16/15 10:44 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
4.050 SCAT Crank
Scat H beam rods
Tall order for sure, but I think if you open the heads, at that compression, you might be there. I have been contemplating one, but I see so few bracket car builds. I averaged a little over 100 passes on my car, and +50 in other peoples cars this year....We had a bunch of rain outs, so it was a light season...I will follow the build, hope you include pics...
Re: My bracket hemi build [Re: Dragula] #1971237
12/17/15 01:31 AM
12/17/15 01:31 AM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
4.050 SCAT Crank
Scat H beam rods
His heads flow 312 @.4, 355 @.6
Re: My bracket hemi build [Re: Triple Threat] #1971672
12/17/15 09:15 PM
12/17/15 09:15 PM
houston texas
gremlinsteve Offline
houston texas
Great build
Hope it all works out for you
Let me know if I can help in any ways
if You Like Gremlinsteve. Gremlinsteve Likes You.
Re: My bracket hemi build [Re: Triple Threat] #1971692
12/17/15 09:42 PM
12/17/15 09:42 PM
Renton Washington
Renton Washington
Thanks Steve! Looking forward to testing that camshaft!
-Dustin
Re: My bracket hemi build [Re: Triple Threat] #1971826
12/18/15 12:30 AM
12/18/15 12:30 AM
houston texas
houston texas
I'm looking forward to the results
Re: My bracket hemi build [Re: Triple Threat] #1971827
12/18/15 12:30 AM
12/18/15 12:30 AM
Stinnett, Tx
Stinnett, Tx
Chriss Alston Avenger tube chassis Skinned with a 90 Dodge Daytona body(outer skin only) fibreglass front fenders and nose, 2 gallon fuel cell, lexan windows..
Re: My bracket hemi build [Re: Triple Threat] #1971860
12/18/15 01:06 AM
12/18/15 01:06 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Looks like it will be a fun build Dustin.
68 Barracuda Formula S 340
Re: My bracket hemi build [Re: Bad340fish] #1972043
12/18/15 11:41 AM
12/18/15 11:41 AM
bonney lake washington
W
w2stroker Online content
w2stroker  Online Content
W
let me know your first day out at the track with it. would love to see it run. and i will be watching your build with much interest. hopefully it will spur me on with mine
Re: My bracket hemi build [Re: Triple Threat] #1972187
12/18/15 04:15 PM
12/18/15 04:15 PM
tri-cities Washington/Denver, ...
5280Dart Offline
5280Dart  Offline
I am looking at building a gen III in the next few months... who do you use for your machine work?
Re: My bracket hemi build [Re: 5280Dart] #1972584
12/19/15 11:41 AM
12/19/15 11:41 AM
PA
W5DART66 Offline
W5DART66  Offline
PA
Looks like it will be good bracket race engine.
But I think HP with the parts in that list is more like 600-640HP
That intake needs lots of work. (A blend job will not fix it. )
Can you share any pictures of the ports and chamber after porting?
Re: My bracket hemi build [Re: W5DART66] #1972816
12/19/15 06:24 PM
12/19/15 06:24 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Chambers not touched
Re: My bracket hemi build [Re: sixpackgut] #1972817
12/19/15 06:31 PM
12/19/15 06:31 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
wrench
Re: My bracket hemi build [Re: Triple Threat] #1973014
12/20/15 12:19 AM
12/20/15 12:19 AM
Maryland
twayne24365 Offline
twayne24365  Offline
Maryland
Looks like it should make some power, its a little less inches but similar to this build from [url=hugheshttp://www.hughesengines.com/TechArticles/21740hpgen3hemi.php][url=hugheshttp://www.hughesengines.com/TechArticles/21740hpgen3hemi.php][url=hugheshttp://www.hughesengines.com/TechArticles/21740hpgen3hemi.php]hugheshttp://www.hughesengines.com/TechArticles/21740hpgen3hemi.php[/url][/url][/url]
