Trans Question... HELP PLEASE
#1968471
12/12/15 05:12 PM
12/12/15 05:12 PM
Posts: 52,972 Romeo MI
MR_P_BODY
If the regular pressure is high will that cause the shift points to be high.. I think it does being that the governor has to match that pressure plus this has the throttle pressure added on to the regulator pressure ... also being this is a stock VB but with the shift improver kit for the 518 it doesnt like to down shift even when I come to a full stop.. I have to manually pull it into low then push the shifter up into drive... thanks for any help....anyone want to BUY a car
Re: Trans Question... Still
[Re: MR_P_BODY]
#1968529
12/12/15 06:54 PM
12/12/15 06:54 PM
Posts: 25,747 Rio Linda, CA
John_Kunkel
Rio Linda, CA
When you raise the line pressure the throttle pressure also rises. Since the governor pressure has to overcome throttle pressure in order for the upshift to occur, raising the line pressure will raise the shift points (all else being the same).
Failure to downshift at a complete stop can be either a stuck shift valve or a faulty governor....only to tell is to hook up a test gauge to the governor pressure test port; anything over 2 psi at a standstill is a faulty governor.
[Re: John_Kunkel]
#1968530
12/12/15 06:59 PM
12/12/15 06:59 PM
MR_P_BODY
Thanks John.. I figure as much on the line pressure.. as to the governor.. I thought for sure its clean and not stuck.. but that might be on the other trans I have.. if the governor is stuck why is it shifting.. but I do have to lift off the throttle to shift..I will put the gauges on it tomorrow
[Re: MR_P_BODY]
#1968545
12/12/15 07:50 PM
12/12/15 07:50 PM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
The governor may not be fully retracting and is letting some pressure bleed through.
As a funny FYI - a local trans shops fix for a sticky 518 governor was to put one of the snake oils in the fluid, and "rattle" the governor by tossing it into park at about 10MPH. I'm guessing that particular step wasn't included in the shift kit instructions.
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: Evil Spirit]
#1968549
12/12/15 08:03 PM
12/12/15 08:03 PM
MR_P_BODY
As a funny FYI - a local trans shops fix for a sticky 518 governor was to put one of the snake oils in the fluid, and "rattle" the governor by tossing it into park at about 10MPH. I'm guessing that particular step wasn't included in the shift kit instructions. All Ive ever had by stuffing any trans into park at low speed was the ratcheting of the parking paw till it locked into park.. I dont understand what would be accomplished by that.. other than ripping the park gear or the paw apart.. I might try the snake oil if I do show 2+ psi at the port... I had this trans gone over by a shop AFTER I went through it.. just to be safe since I've had so much of a issue with these.. this was the first one I did myself.. the guy said everything looked great but he felt the regulator spring was way high.. he guessed it would be about 200# as a guess.. all that went into the trans was a shift improvement kit from trans-go.. I do remember a spring change but didnt think it was the regulator pressure spring.. so I'm not sure since I myself didnt put it in
[Re: dizuster]
#1968619
12/12/15 10:26 PM
12/12/15 10:26 PM
MR_P_BODY
Mike is this the 2nd trans? Same valve body, different trans, same problem?
If so points to the valve body doesn't it? I'm loosing track of whats what.. 3 trans from you and then I bought another.. it didnt have drive(if I remember right) then this one I did and had it checked.. this one is the one that was the original but I went through so its the same VB... I can swap in the other stock VB.. but I have a couple of things to try first... when you changed the stuff in the VB.. what spring did you change.. was that the regulator spring or ?.. if it was then I might just change the spring from the stock VB or change the whole VB
[Re: MR_P_BODY]
#1968633
12/12/15 10:52 PM
12/12/15 10:52 PM
Posts: 16,923 NC
440Jim
NC
... the guy said everything looked great but he felt the regulator spring was way high.. he guessed it would be about 200# as a guess... That would be very high for line pressure in a forward gear. Although the Griner valve bodies I used allowed over 200 psi, I ran mine at 165 psi. For what you are doing, I would think 120-140 would be high enough?
[Re: 440Jim]
#1968653
12/12/15 11:19 PM
12/12/15 11:19 PM
MR_P_BODY
... the guy said everything looked great but he felt the regulator spring was way high.. he guessed it would be about 200# as a guess... That would be very high for line pressure in a forward gear. Although the Griner valve bodies I used allowed over 200 psi, I ran mine at 165 psi. For what you are doing, I would think 120-140 would be high enough? Thanks Jim.. I'm gonna put the gauges on it
[Re: MR_P_BODY]
#1968793
12/13/15 03:50 AM
12/13/15 03:50 AM
Evil Spirit
Newport, Mi
As a funny FYI - a local trans shops fix for a sticky 518 governor was to put one of the snake oils in the fluid, and "rattle" the governor by tossing it into park at about 10MPH. I'm guessing that particular step wasn't included in the shift kit instructions. All Ive ever had by stuffing any trans into park at low speed was the ratcheting of the parking paw till it locked into park.. I dont understand what would be accomplished by that.. other than ripping the park gear or the paw apart.. wave: Yup. Think of where the park gear and the governor body is located. Both the parking pawl gear and the governor body are a part of the output shaft. The vibration from the ratcheting of the pawl teeth is what "rattles" the sticky governor, along with the snake oil. You don't let it grind to a stop - it's a quick in and out. I'm not blaming anybody for not wanting to try it - just saying I've seen it done, and it worked. Like I said - I doubt if you will see that tip in any manual, but I know of several techs that swear by it. Sure is easier to try than ripping out a t/case and the O/D extension housing. If it doesn't work, it had to come apart, anyways.
[Re: J_BODY]
#1968879
12/13/15 12:48 PM
12/13/15 12:48 PM
MR_P_BODY
Glad somebody finally brought up the "park trick". I'm guilty as charged and have seen it work more times than I care to think about. Trans tech showed me in my early years. I did the park thing YEARS ago as a young wrench BUT it was more of a OH damn.. then pulled it out.. but there wasnt anything wrong with the trans... I guess its worth a try if it is stuck for a last chance before pulling it... but I am looking elsewhere right now.. I think I'm gonna pull the whole VB today and put in my other one and try that
[Re: MR_P_BODY]
#1968968
12/13/15 03:30 PM
12/13/15 03:30 PM
MR_P_BODY
I have heard from a trans guy that if you have the car (on the hoist) running in forward gear then hit reverse it will spike the pressure and free up a stuck governor... any true to this or has anyone tried it...(about 20-30 MPH in forward) EDIT I am giving thought to cutting the chassis in the drive shaft loop area so I can pull the tailshaft off to get at the governor... then I will set it up so I can pin it back on... but I'll leave it off till I have it all figured out then put it back on
[Re: J_BODY]
#1968969
12/13/15 03:33 PM
12/13/15 03:33 PM
Evil Spirit
Newport, Mi
Glad somebody finally brought up the "park trick". I'm guilty as charged and have seen it work more times than I care to think about. Trans tech showed me in my early years. That is one of those "tech tips" you post, knowing that you will probably get beaten up over. Sorta like the old dumping water down the carb to get rid of cylinder carbon deposits - some people cringe at it, others swear by it. Mike, as to the "rattling" of the governor - about 10MPH, toss in park for a quick one thousand one count, then back into a forward gear. Too fast and the pawl just skims over the teeth, too slow and it will engage and lock the tires.
[Re: Evil Spirit]
#1969658
12/14/15 07:38 PM
12/14/15 07:38 PM
MR_P_BODY
I have the Rampage up on the hoist... I was thinking about cutting some tubes to get the tail shaft off... thats not gonna happen.. there isnt enough room to slide it back to get it off.. so I'll have to try the park or reverse thing to see if it'll free up... if it doesnt... I pull the engine/trans AGAIN... this is getting REAL OLD.. I am gonna change valve bodies tomorrow to see if it helps the up shift... this thing is getting closer to the burn pile EDIT does anyone know of a trans dyno in the Detroit area
[Re: MR_P_BODY]
#1969664
12/14/15 07:54 PM
12/14/15 07:54 PM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
If you need to pull the motor/trans again I would be done with the OD deal. Put a 727 in it and don't sweat the RPM.
My junk knocks down 13-14MPG spinning 3500RPM on drag week for 4 years now. Its quieter and feels more "happy" then it does at lower RPM. If I put an overdrive in I would just have to drive faster lol(not that it would be a bad thing).
68 Barracuda Formula S 340
[Re: Bad340fish]
#1969668
12/14/15 08:01 PM
12/14/15 08:01 PM
MR_P_BODY
My junk knocks down 13-14MPG spinning 3500RPM on drag week for 4 years now. Its quieter and feels more "happy" then it does at lower RPM. If I put an overdrive in I would just have to drive faster lol(not that it would be a bad thing). Too late for that.. I would have to cut out a bunch of tubes to relocate the trans mount... I have all the gears its just the upshift and downshift.. if I want to down shift I can pull the shifter... the upshift I think is the valve body but way too high of rpms
[Re: MR_P_BODY]
#1969697
12/14/15 08:46 PM
12/14/15 08:46 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
You need to assess your situation from outside of the box you're stuck in. First, yes. Try the valve body. But if you need to pull the trans again, change what needs to be changed to get the trans out on its own. You have the skill, the equipment and the time to do it. You can't tell me that after all you've been through, that it would not be worth some extra time to make things easier on yourself. Sorry for the tough love, but damn...
[Re: TRENDZ]
#1969708
12/14/15 08:59 PM
12/14/15 08:59 PM
MR_P_BODY
You need to assess your situation from outside of the box you're stuck in. First, yes. Try the valve body. But if you need to pull the trans again, change what needs to be changed to get the trans out on its own. You have the skill, the equipment and the time to do it. You can't tell me that after all you've been through, that it would not be worth some extra time to make things easier on yourself. Sorry for the tough love, but damn... That ISNT gonna happen.. I would have to cut the WHOLE interior out and start over.. plus I would have to cut part of the dash(lower part) then cut out my seat mounts and the drive shaft loop and the X-bracing on the chassis... I built this thinking I wouldnt be pulling the trans... IF I could move the whole interior I wouldnt have room for myself.. hell I had to move the engine/trans over 1" to the right to give me just a bit of room..... so NOPE none of that is gonna happen.. if needed I'll pull the engine/trans one again.. but I will find a trans dyno to test it before it goes back in.. I can see you have never built a SMALL car... I deal in .010" for clearance on a lot of the stuff
[Re: MR_P_BODY]
#1970266
12/15/15 05:24 PM
12/15/15 05:24 PM
MR_P_BODY
I put a gauge on the governor port today.. it shows zero pressure in gear at zero speed... as I increased the speed it shows the pressure going up.. I brought it back to zero speed.. showed zero pressure.. as I brought it up in speed again it showed zero pressure this time... whats going on here.. also what port can I read the regulator pressure.... thanks for any help
[Re: MR_P_BODY]
#1970317
12/15/15 06:44 PM
12/15/15 06:44 PM
Posts: 7,131 Amarillo, Texas
BBR
Amarillo, Texas
I would put a manual valvebody in it and never look back.
Clicking gears is no bother on the street and gives me something to do when driving around.
Drag Week 2011 - 77th place - DD Drag Week 2012 - 2nd place SRBB N/A Drag Week 2014 - Kapooya RMRW 2018 RMRW 2020
[Re: BBR]
#1970323
12/15/15 06:57 PM
12/15/15 06:57 PM
MR_P_BODY
Clicking gears is no bother on the street and gives me something to do when driving around. I have a stock VB that I'm gonna put in it.. but I want to know whats going on with the governor pressure first... the VB in it now has a Transgo shift improver kit .. other than that its stock
[Re: MR_P_BODY]
#1970336
12/15/15 07:21 PM
12/15/15 07:21 PM
John_Kunkel
Rio Linda, CA
Line pressure test port is the plug in the middle "hump" on the passenger side.
[Re: John_Kunkel]
#1970346
12/15/15 07:32 PM
12/15/15 07:32 PM
MR_P_BODY
Thanks John... what kind of pressure should I see.. and I assume that is the regulator pressure... in my book it doesnt show a pressure for the front servo port also.. any idea why my test didnt repeat itself.. just came up with zero pressure
[Re: FastmOp]
#1970356
12/15/15 07:44 PM
12/15/15 07:44 PM
MR_P_BODY
Dang that sux, I hope you get a handle on it. So do I.. or I'll burn this thing to the ground... John stated that it should be zero pressure with zero speed.. it is but the pressure didnt climb the second and third times I tried.. I dont understand that it doesnt repeat
[Re: FastmOp]
#1970357
12/15/15 07:47 PM
12/15/15 07:47 PM
dartman366
Mt. Vernon, Ohio
Mike can you get the trans tailshaft extention housing off while in the car? if you can then take it off and disassemble the govenor and clean it, sounds like it's sticking or it's got a piece of trash in it, and you don't want to hear what a trans shop told me how to fix it with out taking it apart,,,it worked but not reccomended. LOL
[Re: dartman366]
#1970365
12/15/15 07:56 PM
12/15/15 07:56 PM
MR_P_BODY
Mike can you get the trans tailshaft extention housing off while in the car? if you can then take it off and disassemble the govenor and clean it, sounds like it's sticking or it's got a piece of trash in it, and you don't want to hear what a trans shop told me how to fix it with out taking it apart,,,it worked but not reccomended. LOL No way in hell to get it off... I spent a hour trying to get a fitting into the governor port today and found it couldnt be done.. I ended up pulling the carpet and drilled a 1" hole in the tunnel so I could get my readings.. I did do the drive to park and drive to reverse thing... nothing changed(I assume that is what you were gonna say about the fix)
[Re: MR_P_BODY]
#1970368
12/15/15 08:04 PM
12/15/15 08:04 PM
dartman366
Mt. Vernon, Ohio
Mike can you get the trans tailshaft extention housing off while in the car? if you can then take it off and disassemble the govenor and clean it, sounds like it's sticking or it's got a piece of trash in it, and you don't want to hear what a trans shop told me how to fix it with out taking it apart,,,it worked but not reccomended. LOL No way in hell to get it off... I spent a hour trying to get a fitting into the governor port today and found it couldnt be done.. I ended up pulling the carpet and drilled a 1" hole in the tunnel so I could get my readings.. I did do the drive to park and drive to reverse thing... nothing changed(I assume that is what you were gonna say about the fix) LOL yep, scared the bejeezus out of me, the only other thing I could suggest is dump a can of Sea Foam trans cleaner in it and drive it, that stuff will help clean them up and take any varnish and gunk out of them, had a Aries wagon once with the 2.2 auto in it and had some issues with it shifting and not shifting into 1st at a traffic light,put that stuff in and drove it for about 250-300 miles and never looked back, still worked good when I sold it 2 years later.
Re: Trans Question... HELP PLEASE
[Re: MR_P_BODY]
#1970373
12/15/15 08:13 PM
12/15/15 08:13 PM
TRENDZ
Milwaukee WI
Sent a pm. Gov pressure port for 518 is high/back
[Re: MR_P_BODY]
#1970759
12/16/15 12:45 PM
12/16/15 12:45 PM
MR_P_BODY
Any other suggestions to what might be wrong with this thing.. I'm gonna change the VB today with the stock one I have EDIT Whats the correct procedure to adjust the TP cable just so I know
[Re: MR_P_BODY]
#1970818
12/16/15 02:34 PM
12/16/15 02:34 PM
MR_P_BODY
I just got off the phone with John Cope.. glad I talked with him... I was gonna put this other VB on which is a non lock up trans.. the one in the car is a lock up style that I changed out the pump and input shaft on.. well the non lock up VB wont work on a lock up case... so that takes care of me changing the VB.. he suggested a trick on freeing the governor which I will try today.. its blowing air into the governor test port while the engine is running.. it works sometimes if its just small trash... but as he also said.. if its eating itself up and putting trash in there it will just happen again(which I knew).. so for today I'll put the gauge on the accumulator port and get some readings and try the air pressure on the governor port.. I think I will drop the pan to check for trash.. I have a drain plug but I want to see whats on the magnet... he also said that A&A makes a manual shift VB for these.. so if it doesnt have trash in it and the VB just doesnt want to work right I will order the manual shift VB so it eliminates the need for the governor EDIT Thanks John for the info
[Re: MR_P_BODY]
#1970819
12/16/15 02:35 PM
12/16/15 02:35 PM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
Mike, If there is no pressure coming out of the governor at speed, it's because the governor weights are stuck blocking the flow completely.
From looking at the flow diagrams, the rear clutch feed in the case is the same circuit as the governor feed. Meaning if the governor didn't have any flow going to it, the rear clutch wouldn't apply either.
The problem does not appear to be in the valve body.
Didn't this thing have a stuck/burred governor weight in it the last time we took it apart? I remember you taking it home to fix before we put it back together. Is this the same trans, or the junk yard trans now in the car? (Easy way to tell... is it painted black? Or did you paint the junk yard trans black?)
If the governor pressure doesn't rise with speed, it won't make the automatic 1/2 shift like it should.
[Re: dizuster]
#1970823
12/16/15 02:42 PM
12/16/15 02:42 PM
MR_P_BODY
This is the one you did originally.. yes it had a stuck/burred governor which I did fix.. I know it moved freely.. I made damn sure of it...both trans are black.. I painted the JY one also after I cleaned it up
[Re: MR_P_BODY]
#1970932
12/16/15 05:50 PM
12/16/15 05:50 PM
John_Kunkel
Rio Linda, CA
The "no repeat" on the governor pressure test is baffling, don't have a clue to a cause.
The front servo test port will only show pressure when the trans is in 3rd gear and should be the same as line pressure or a little lower. Line pressure will vary with the throttle, 50-100 psi....you can disconnect the linkage and operate the TP lever by hand to raise/lower the line pressure at idle.
[Re: John_Kunkel]
#1970953
12/16/15 06:20 PM
12/16/15 06:20 PM
MR_P_BODY
Right now I've spent a hour and a half trying to get a fitting into the accumulator port to get a reading on the line pressure.. so far I havent got the fitting in.. I had to take a break before I burn that thing.. my hand and my foot have cramped up... a word to people... DONT BUILD LITTLE CARS.. Im getting ready to pull the pass header just to help getting to the port
[Re: J_BODY]
#1971007
12/16/15 07:55 PM
12/16/15 07:55 PM
MR_P_BODY
It dont F-ing matter.. it has to come out..I pulled the pan.. its got a pile of crap in it.. 4 miles on it...........its getting torched
[Re: lewtot184]
#1971250
12/17/15 01:57 AM
12/17/15 01:57 AM
MR_P_BODY
After thinking about this.. I believe I have brought this on myself.. I never had the conv cleaned out and all my problems seem to be trash getting into the system... I have all the gears right now but trash is sticking stuff(VB and gov).. I chanced it the first time and didnt have it cleaned out... its the same conv in all of the builds
[Re: MR_P_BODY]
#1971546
12/17/15 06:03 PM
12/17/15 06:03 PM
MR_P_BODY
Hopefully this will be my last question...the trans I have on the bench is the JY one that I changed the pump on.. that trans didnt have reverse.. now when I opened it up I see that both of the nylon rings on the input shaft were torn up... would this be the cause of no reverse.. I think it is but I want to ask and make sure.. everything looks like new in it.. all the fibers and steels.. everything... I opened up the OD and those look great also... so am I correct to think the nylon rings would be the reverse issue... thanks much guys... Im sending out the conv to have it checked and cleaned.. I will clean out the cooler and lines
[Re: MR_P_BODY]
#1971703
12/17/15 10:13 PM
12/17/15 10:13 PM
TRENDZ
Milwaukee WI
do they seal the supply for the front clutch?
[Re: MR_P_BODY]
#1971715
12/17/15 10:26 PM
12/17/15 10:26 PM
TRENDZ
Milwaukee WI
I've always used the steel stepped rings.
[Re: TRENDZ]
#1971772
12/17/15 11:37 PM
12/17/15 11:37 PM
MR_P_BODY
do they seal the supply for the front clutch? I think they do.. but I would have to grab my book in the shop and follow the hyd path
[Re: a493demon]
#1971774
12/17/15 11:39 PM
12/17/15 11:39 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Yes the rings will cause no rev. and 3rd ask me how I know lol. P.S check the 3rd gear clutch pack to make sure it didn't burn the fibers. Exact dactly!
[Re: a493demon]
#1971776
12/17/15 11:40 PM
12/17/15 11:40 PM
MR_P_BODY
Yes the rings will cause no rev. and 3rd ask me how I know lol. P.S check the 3rd gear clutch pack to make sure it didn't burn the fibers. Thanks... the clutch looks like new.. still has the writing on them EDIT I only drove it about 50 feet when I seen it didnt have reverse
[Re: PC-CHARGER]
#1971964
12/18/15 03:24 AM
12/18/15 03:24 AM
MR_P_BODY
If you are talking about the small rings (about 1" in diameter) that are on the input shaft, they are the feed for the rear clutch that is used in all forward gears, not reverse. If you are talking about the larger rings that go on the pump, those feed the front clutch which is used in high and reverse.
I'm talking the 1" or so on the front of the input shaft... I thought that ended up messing up reverse.. I was sure I seen this same thing on a 727.. but I dont know much
[Re: MR_P_BODY]
#1971981
12/18/15 04:17 AM
12/18/15 04:17 AM
Evil Spirit
Newport, Mi
Mike, the 2 sealing rings that you describe on the input shaft seal on the inside of the front pump housing and are for the rear clutch, which is applied in all forward gears but not in reverse. There are 2 rings mounted on the front pump housing that seal to the inside of the front clutch drum which apply the front clutch in direct, O/D, and reverse. In reverse, the front clutch and the rear band is applied.
You should be able to check both clutches sealing rings and both drums piston seals by air checking the front pump and drum assembly on the bench.
[Re: Evil Spirit]
#1971986
12/18/15 04:40 AM
12/18/15 04:40 AM
MR_P_BODY
Right now all I know is it didnt have reverse and the only thing I seen wrong is the 2 nylon seal rings... I'll look tomorrow what the part name is
[Re: a493demon]
#1972039
12/18/15 11:33 AM
12/18/15 11:33 AM
MR_P_BODY
Sorry I thought you where talking about the stator support Nope... the 2 seals on the input shaft.. the reaction shaft support has 2 metal locking rings which is on the back of the pump..they are fine.. looks like these 2 seals, seal on the ID of the reaction shaft support
[Re: MR_P_BODY]
#1972423
12/19/15 12:08 AM
12/19/15 12:08 AM
Posts: 561 USA
B3RE
USA
Hopefully this will be my last question...the trans I have on the bench is the JY one that I changed the pump on.. that trans didnt have reverse.. now when I opened it up I see that both of the nylon rings on the input shaft were torn up... would this be the cause of no reverse.. I think it is but I want to ask and make sure.. everything looks like new in it.. all the fibers and steels.. everything... I opened up the OD and those look great also... so am I correct to think the nylon rings would be the reverse issue... thanks much guys... Im sending out the conv to have it checked and cleaned.. I will clean out the cooler and lines Mike, check out the replacement pump. Years ago my dad had a 727 rebuilt for his truck. The builder was a low buck trans guy, who replaced the "worn out" pump. When we got it installed, it didn't have reverse. It seems to me IIRC it also needed a lot of throttle input to get it to move in forward gears. The builder couldn't find anything wrong with it and basically told us we were SOL. We tore that trans apart at least a half dozen times, and everything looked right, until I noticed the front drum was lightly rubbing the back of the reaction shaft support. It turned out that either the builder ordered a lock up pump for a non lock up trans, or the pump was incorrectly boxed and he didn't catch it or know the difference. We found a used pump in our stash, put it in, and the trans works to this day. I know yours is a lock up. I'm just wondering how our experience would play out in reverse if your pump was actually for a non lock up trans. Could be worthwhile looking in to.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
[Re: MR_P_BODY]
#1979765
12/31/15 12:01 AM
12/31/15 12:01 AM
Evil Spirit
Newport, Mi
Figure anything out yet, Mike?
[Re: Evil Spirit]
#1979857
12/31/15 01:20 AM
12/31/15 01:20 AM
MR_P_BODY
Figure anything out yet, Mike? Just got the final parts today... I'm putting it back together tomorrow.. but I am sending out the conv to Ultimate in a few days to have it cleaned out and looked at EDIT I think I have this figured out.. I think with the rings on the input shaft messed up that it had just enough pressure to go forward(but I never left the drive way) but not enough pressure for reverse
[Re: MR_P_BODY]
#1980917
01/01/16 04:53 AM
01/01/16 04:53 AM
Evil Spirit
Newport, Mi
As we discussed earlier - the 2 small sealing rings that install on the input shaft, that seal the input shaft to the inside of the pump, CAN NOT cause a reverse apply failure, simply because they are the seals for the rear clutch, which is not applied in reverse.
If the 2 rings on the outside of the reaction shaft that seal to the inside of the direct clutch (front) drum fail to seal fail, the front clutch won't apply properly, and you will lose reverse, direct (3rd) and O/D.
I air check my clutch applies both as a rear/front clutch/pump assembly, and again once the pump is in but before I install the V/B.
[Re: Evil Spirit]
#1981016
01/01/16 01:10 PM
01/01/16 01:10 PM
MR_P_BODY
I was measuring the end play yesterday and I didnt like what I had.. the spec is .022-.091.. I was at .085... I wanted to get back to about .045 or so.. I have the thickest thrust washer on the back of the pump.. I am going to change the triangled shape one on the front of the intermediate shaft.. with that one I can tighten it up by .020... this would put me at about .065 end play.. I can deal with that I have the hardest time to get all the clutches to line up when I drop the forward drum in.. I spent over a hour to get the last disc to line up... it need to drop down a little farther into the lugs.. what a PITA
[Re: MR_P_BODY]
#1982209
01/02/16 07:46 PM
01/02/16 07:46 PM
MR_P_BODY
I found some issues today... with the help of Scott.. the pump support(stator support was the wrong size for the input shaft rings... the input shaft is 1.175" and the support ID is for a 1.240 input shaft... but I had already planned to go back with all the stock components from this trans.. so I might not have understood WHY it had issues.. but measuring it I now think I know why... the input shaft seal ring didnt come close to sealing.. and when the sealed blew out I had enough pressure to roll forward but not enough pressure for reverse.. it had enough pressure to barely roll in forward... at least this is what I think.. all I did on this trans was change the pump assm... but didnt know there was 2 different input shaft sizes... now I am learning that the early 518(non lock up) which was from 88-91 COULD have either input shaft.. in 92 they went with the lock up conv and they changed to the larger input with the hole down the middle for the conv.... still learning... anyways.. I put it back together today with the original stock pump.. plus Scott informed me he thought I had to have the output shaft on to measure input in play.. he was right.. now I'm on the low end of the spec.. which will be fine...tomorrow I will sit down and go through the valve body step by step to clean it.. the conv goes out Monday
[Re: dizuster]
#1982369
01/02/16 11:23 PM
01/02/16 11:23 PM
MR_P_BODY
What's strange is that I saw a non lock up pump with my own eyes today at Mikes with a 1.245" reaction shaft. Not sure how a 94+ pump made it into non lock up form.
Weird... Scott... I pulled it all back apart so I could do a final assm on it... I didnt have the low band bracket in it from the beginning... so back apart and I ended up pulling the OD back apart being it didnt want to line up.... total time for the reassmbly of every thing was 1 hour and 10 minutes including the OD tear down and back together... I'm becoming a pro on this junk.. now to figure out issues that cause problems
[Re: J_BODY]
#1982392
01/02/16 11:47 PM
01/02/16 11:47 PM
MR_P_BODY
splines in the OD units often did that when you'd remove them...... always hated that.
Did you find anyplace with a trans dyno?
Did you tear that shifter down and "fix" it so the detents would line up? I found the one and ONLY dyno in Mich.. but they wont dyno any trans that they dont build.. plus their dyno is pretty limited for what it will do.. I will look at the shifter.. but it was working right... but I'm thinking of buying a new shifter with a lower shift arm.. I would like a real short one.. this one is new but its a old unit thats obsolete now
[Re: MR_P_BODY]
#1983716
01/04/16 09:04 PM
01/04/16 09:04 PM
MR_P_BODY
I pulled the trans apart that was in the car last time that didnt like to up shift or down shift... this is the one that I had a shop check over for me... it had all sorts of rust on the steel parts.. like there was about a 1/2" to 3/4" of water in it.. I know damn a well it wasnt like that when I put it together... well that was a waste of money and time
