Page 3 of 4 1 2 3 4
Re: Trans Question... Still [Re: MR_P_BODY] #1971141
12/16/15 11:15 PM
12/16/15 11:15 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
if your not using a manual valve body i'd look at the kickdown linkage. i've had this problem before and it was always a kickdown adjustment.
Re: Trans Question... Still [Re: lewtot184] #1971250
12/17/15 01:57 AM
12/17/15 01:57 AM
MR_P_BODY Offline OP
After thinking about this.. I believe I have brought
this on myself.. I never had the conv cleaned out and
all my problems seem to be trash getting into the
system... I have all the gears right now but trash is
sticking stuff(VB and gov).. I chanced it the first time
and didnt have it cleaned out... its the same conv in all
of the builds confused
wave
Re: Trans Question... HELP PLEASE [Re: MR_P_BODY] #1971546
12/17/15 06:03 PM
12/17/15 06:03 PM
Hopefully this will be my last question...the
trans I have on the bench is the JY one that I
changed the pump on.. that trans didnt have reverse..
now when I opened it up I see that both of the nylon
rings on the input shaft were torn up... would this
be the cause of no reverse.. I think it is but I want
to ask and make sure.. everything looks like new in
it.. all the fibers and steels.. everything... I opened
up the OD and those look great also... so am I correct
to think the nylon rings would be the reverse issue...
thanks much guys... Im sending out the conv to have it
checked and cleaned.. I will clean out the cooler and lines
wave
Re: Trans Question... HELP PLEASE [Re: MR_P_BODY] #1971681
12/17/15 09:23 PM
12/17/15 09:23 PM
Anyone?
wave
Re: Trans Question... HELP PLEASE [Re: MR_P_BODY] #1971703
12/17/15 10:13 PM
12/17/15 10:13 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
do they seal the supply for the front clutch?
Re: Trans Question... HELP PLEASE [Re: MR_P_BODY] #1971715
12/17/15 10:26 PM
12/17/15 10:26 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
I've always used the steel stepped rings.
Re: Trans Question... HELP PLEASE [Re: MR_P_BODY] #1971728
12/17/15 10:46 PM
12/17/15 10:46 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
Yes the rings will cause no rev. and 3rd ask me how I know lol.
P.S check the 3rd gear clutch pack to make sure it didn't burn the fibers.
Re: Trans Question... HELP PLEASE [Re: TRENDZ] #1971772
12/17/15 11:37 PM
12/17/15 11:37 PM
I think they do.. but I would have to grab my book
in the shop and follow the hyd path
wave
Re: Trans Question... HELP PLEASE [Re: a493demon] #1971774
12/17/15 11:39 PM
12/17/15 11:39 PM
Kalispell Mt.
HotRodDave Offline
Happy Birthday HotRodDave  Offline
Kalispell Mt.
Exact dactly!
Re: Trans Question... HELP PLEASE [Re: a493demon] #1971776
12/17/15 11:40 PM
12/17/15 11:40 PM
Thanks... the clutch looks like new.. still has
the writing on them
EDIT
I only drove it about 50 feet when I seen it didnt
have reverse
wave
Re: Trans Question... HELP PLEASE [Re: MR_P_BODY] #1971949
12/18/15 03:07 AM
12/18/15 03:07 AM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
If you are talking about the small rings (about 1" in diameter) that are on the input shaft, they are the feed for the rear clutch that is used in all forward gears, not reverse. If you are talking about the larger rings that go on the pump, those feed the front clutch which is used in high and reverse.
Re: Trans Question... HELP PLEASE [Re: PC-CHARGER] #1971964
12/18/15 03:24 AM
12/18/15 03:24 AM
I'm talking the 1" or so on the front of the input
shaft... I thought that ended up messing up reverse..
I was sure I seen this same thing on a 727.. but I
dont know much
wave
Re: Trans Question... HELP PLEASE [Re: MR_P_BODY] #1971981
12/18/15 04:17 AM
12/18/15 04:17 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Mike, the 2 sealing rings that you describe on the input shaft seal on the inside of the front pump housing and are for the rear clutch, which is applied in all forward gears but not in reverse. There are 2 rings mounted on the front pump housing that seal to the inside of the front clutch drum which apply the front clutch in direct, O/D, and reverse. In reverse, the front clutch and the rear band is applied.
You should be able to check both clutches sealing rings and both drums piston seals by air checking the front pump and drum assembly on the bench.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: Trans Question... HELP PLEASE [Re: Evil Spirit] #1971986
12/18/15 04:40 AM
12/18/15 04:40 AM
Right now all I know is it didnt have reverse and
the only thing I seen wrong is the 2 nylon seal
rings... I'll look tomorrow what the part name is
wave
Re: Trans Question... HELP PLEASE [Re: MR_P_BODY] #1972003
12/18/15 10:36 AM
12/18/15 10:36 AM
a493demon Offline
a493demon  Offline
Sorry I thought you where talking about the stator support
Re: Trans Question... HELP PLEASE [Re: a493demon] #1972039
12/18/15 11:33 AM
12/18/15 11:33 AM
Nope... the 2 seals on the input shaft.. the
reaction shaft support has 2 metal locking rings
which is on the back of the pump..they are fine..
looks like these 2 seals, seal on the ID of the
wave
Re: Trans Question... HELP PLEASE [Re: MR_P_BODY] #1972139
12/18/15 02:56 PM
12/18/15 02:56 PM
illinois
rbkt65 Offline
rbkt65  Offline
illinois
if you changed frt drums and frt pump from originals and mis-matched parts-like we used to do, you could have problems. we used to disassemble trans and save parts and would use a front/rear drum or stator support without checking to be exact same part. we shot ourselves in foot. now we check all parts by measuring individual parts or using all parts that are kept together. john kunkel had/has a pictorial reference of parts that is very good at determining correct parts.get it if you can. also we now air check parts on bench before putting in trans. somethings to remember are very hard but jk's pictorial is very good at helping determine correct parts. would like to see jk put together and sell picture book. would be great reference material. we have also talked to john cope and rick allison on odd ball stuff and those fellows are both gentlemen and very knowledgable. thanks to both and also john kunkel.
Re: Trans Question... HELP PLEASE [Re: MR_P_BODY] #1972423
12/19/15 12:08 AM
12/19/15 12:08 AM
USA
B3RE Offline
B3RE  Offline
USA
wave
Mike, check out the replacement pump.
Years ago my dad had a 727 rebuilt for his truck. The builder was a low buck trans guy, who replaced the "worn out" pump. When we got it installed, it didn't have reverse. It seems to me IIRC it also needed a lot of throttle input to get it to move in forward gears. The builder couldn't find anything wrong with it and basically told us we were SOL. We tore that trans apart at least a half dozen times, and everything looked right, until I noticed the front drum was lightly rubbing the back of the reaction shaft support. It turned out that either the builder ordered a lock up pump for a non lock up trans, or the pump was incorrectly boxed and he didn't catch it or know the difference. We found a used pump in our stash, put it in, and the trans works to this day.
I know yours is a lock up. I'm just wondering how our experience would play out in reverse if your pump was actually for a non lock up trans. Could be worthwhile looking in to.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
Re: Trans Question... HELP PLEASE [Re: MR_P_BODY] #1979765
12/31/15 12:01 AM
12/31/15 12:01 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Figure anything out yet, Mike?
Re: Trans Question... HELP PLEASE [Re: Evil Spirit] #1979857
12/31/15 01:20 AM
12/31/15 01:20 AM
Just got the final parts today... I'm putting it back together
tomorrow.. but I am sending out the conv to Ultimate in a few
days to have it cleaned out and looked at
EDIT
I think I have this figured out.. I think with the
rings on the input shaft messed up that it had just
enough pressure to go forward(but I never left the
drive way) but not enough pressure for reverse
wave
Page 3 of 4 1 2 3 4
