Re: Add 2-nipple vapor return fuel sending unit-1971 Satellite?
[Re: moparx]
#1964853
12/07/15 12:40 PM
12/07/15 12:40 PM
Posts: 16,133 Mesa, Arizona
dart4forte
Mesa, Arizona
Is it leaking past the seal?
Abe Lincoln
[Re: JimG]
#1965010
12/07/15 05:30 PM
12/07/15 05:30 PM
RapidRobert
Jimmy G the JB weldmaster! Please tell me you no longer have my fabbed metering rod caps up on your wall of shame AKA as your garage door. Sending units that read correct are a rarity (mainly replacement ones) so if yours is OK there I would drill a hole in the circular flat & solder in a nipple. As said if going with another sender you'd want its dimentions (line shape/float arm configuration) the same as your good one in there now & have the lower horizontle bend of the line just off the floor as there is always some water etc that is heavier than gasoline & you dont want that in your carb (& an occaisional tank siphoning to clean it out). Why are you dropping the tank? there's been issues with replacement sending unit lock rings & I'd get an original one & good visual for bent tangs & likely that'll take care of it (the leak) plus a good circular gasket under it. Tell ya what, send me back my caps & I'll send ya a good OE lock ring!
[Re: RapidRobert]
#1965017
12/07/15 05:38 PM
12/07/15 05:38 PM
Posts: 531 Virginia
JimG
Virginia
Hi Robert:
Apparently, I'll never live that JB Weld thing down! By the way, the JB Welded distributor slots are still in there, and still just fine, thank you very much!
Regarding the Satellite tank, I took a quick look-see, and I'll at least have to let the passenger side of the tank droop quite a bit to get the sending unit out of the tank. that might be the plan.
I'll PM you later and we'll catch up.
ETA - I tried to PM you and you are over your limit of PMs. Clean out your mailbox, man!
