Re: Cam timing and piston to valve
[Re: sixty9bee]
#196398
01/17/09 08:05 PM
01/17/09 08:05 PM
Posts: 1,505 TN
SCATPACK 1
TN
You could advance the cam some to get clearance. But if you are hitting, I would flycut valve relief notches into the pistons. I do not feel safe with less than .100 thou on the exhaust to piston. I know it is more time consuming but do it any way and never have to worry about it.
Old Geezer Racing
[Re: sixty9bee]
#196399
01/17/09 08:05 PM
01/17/09 08:05 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Whats the intake at. Advance it 4* and check it again. I prefer to check it with the head gasket but thats me. Use a pushrod length checker with 0 lash then you can figure your lash in
[Re: sixty9bee]
#196404
01/17/09 11:06 PM
01/17/09 11:06 PM
before you go any further, check your intake valve clearance. if you have more clearance there you might be able to advance the cam and get enough for both. if not, you'll be flycustting pistons. most shelf ross pistons will not handle .700 lift safely.
[Re: sixty9bee]
#196406
01/17/09 11:47 PM
01/17/09 11:47 PM
Posts: 2,119 sc
tjmarcus1
sc
the rocker ratio is 1.5 the lash was at 0 and the interference was minimal, as a matter of fact was not noticable until a dial indicator was used to check exact clearance. the intake was checked and has more than enough room through entire range. we could have 60-80 thou removed from the intake clearance and still be around 90 through the cycle.
with that much int. clearance, are you sure the cam is in right?
[Re: tjmarcus1]
#196407
01/18/09 12:00 AM
01/18/09 12:00 AM
MR_P_BODY
The cam does sound like its installed retarted more than straight up
[Re: sixty9bee]
#196410
01/18/09 12:28 AM
01/18/09 12:28 AM
MR_P_BODY
I know, it sounds like its in retarded. that was my first thought. checked and started over checked again. the valve relief is deeper on intake side. the only question on install is the cam is ground on 110 but my understanding is comp puts 4 degrees advance into the grind. if that is correct, it should probably not be installed at 110 right? by the way thanks for all the replies
Yes they grind in advance but you still start at 110 for 0 then advance it from there if you want advance
[Re: MR_P_BODY]
#196411
01/18/09 01:43 AM
01/18/09 01:43 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Where your cam is installed now at a 110* ICL with a 110* LS you are neither advanced or retarded. Your at 0* Even if the cam had 4* advance ground into it.
mike
