Re: How much to mill Indy's SR's
[Re: drag440]
#196336
01/17/09 10:19 PM
01/17/09 10:19 PM
Posts: 14,479 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
based on what you gave for specs, i get 10.42cr now, and it would take 14cc's off the heads for 12:1.
you cut Indy heads are roughly .006 per CC, so for a 14cc reduction, you're looking at cutting them .084. better check the V/P clearance before cutting them that much.
cut the intake side .012 for every .010 off the deck. so, if you cut the decks .084, cut the intake side .100.
[Re: fast68plymouth]
#196337
01/17/09 10:56 PM
01/17/09 10:56 PM
Posts: 16,917 NC
440Jim
NC
IMO, that wasn't the best piston if a 12 CR was desired. But many are running those heads around 68cc, so it isn't a big streatch. Watch out for piston to valve clearance. A wide LSA nitrous cam will help somewhat.
