Page 1 of 8 1 2 3 4 5 6 7 8
`56 Plymouth modern front end swap advice #1962414
12/03/15 03:24 PM
12/03/15 03:24 PM
Caldwell, Idaho
67R/T4speeder Offline OP
Caldwell, Idaho
I have a `56 Plymouth car that I would like to put a 360 4-speed in and was considering a whole front suspension upgrade at the same time, maybe Heidts ??. Keeping the outside looking stock .
Any input from anyone that's been there done that would be appreciated.
pismopowerwagon@aol.com
Re: `56 Dodge modern front end swap advice [Re: 67R/T4speeder] #1962477
12/03/15 04:47 PM
12/03/15 04:47 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
My '56 Plymouth with 360 and 5-speed has a '91 Dakota front clip spliced to the original frame. Modern ball joint suspension, power R&P steering and disc brakes.
Mine has 2" dropped spindles so I don't know how the ride height would be stock.
Re: `56 Dodge modern front end swap advice [Re: 67R/T4speeder] #1962643
12/03/15 08:47 PM
12/03/15 08:47 PM
Caldwell, Idaho
Caldwell, Idaho
WOW that make me want to drop it a bit smile
Front width looks right too.
Very nice
incentive for sure thank you
Re: `56 Dodge modern front end swap advice [Re: 67R/T4speeder] #1962690
12/03/15 10:14 PM
12/03/15 10:14 PM
dogdays Offline
dogdays  Offline
There are all sorts of mustang II-based front ends out there, such as Heidt's or Fatman, and they have been working for years. I believe with most of those setups you keep your existing framerails. The aftermarket is full of upgrade parts for this basic setup. The same basic setup was used on the Granada so don't let someone tell you it isn't strong enough.
The Dakota swap is very popular here and it looks like that's because it is a good one. People either swap the whole frame or else cut and weld the new front end to the old back half of the frame.
I wonder when Dakotas are going to become scarce, they aren't really valued for much else and they are scarce on the roads right now. Probably quite a few sitting besides barns, though.
The Crown Vic is way too wide for a '50s car and there's no easy way to narrow it, as the crossmember is an aluminum casting. The rack and pinion is another problem. Hard to make it shorter...On the other hand, the Crown Vic would be just right for my '50 Buick, now there's a thought.
R.
Re: `56 Dodge modern front end swap advice [Re: John_Kunkel] #1962693
12/03/15 10:17 PM
12/03/15 10:17 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Any build pictures? bow
Re: `56 Dodge modern front end swap advice [Re: moparpollack] #1963167
12/04/15 03:28 PM
12/04/15 03:28 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The work was done by the PO.
Re: `56 Dodge modern front end swap advice [Re: John_Kunkel] #1964880
12/07/15 01:28 PM
12/07/15 01:28 PM
Caldwell, Idaho
Caldwell, Idaho
Do you use wheel adapters to get away from the 6 lugs Dakota?
Any idea what year donor truck is preferred?
Andy
Re: `56 Dodge modern front end swap advice [Re: dogdays] #1964881
12/07/15 01:29 PM
12/07/15 01:29 PM
Caldwell, Idaho
Caldwell, Idaho
R.
Thanks I like the Dakota idea
Re: `56 Dodge modern front end swap advice [Re: 67R/T4speeder] #1965007
12/07/15 05:27 PM
12/07/15 05:27 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Andy
My lugs are 5 X 4.5" so it might be a '90 clip or rotors were changed...junkyard receipt says it was a '91. shruggy
Re: `56 Dodge modern front end swap advice [Re: 67R/T4speeder] #1965049
12/07/15 06:49 PM
12/07/15 06:49 PM
Caldwell, Idaho
Caldwell, Idaho
OK so I will look out for a regular 5 4.5 truck
thanks for great pics
Re: `56 Dodge modern front end swap advice [Re: 67R/T4speeder] #1965149
12/07/15 10:16 PM
12/07/15 10:16 PM
dogdays Offline
dogdays  Offline
There is a one or two year overlap where the 6 lug rotor/hubs can be switched for 5 lug rotor/hubs. After that the suspension changed and it isn't easy at all. But it seems to me that the later Daks had wider tracks and wouldn't work as well anyway.
R.
Re: `56 Dodge modern front end swap advice [Re: 67R/T4speeder] #1965329
12/08/15 01:22 AM
12/08/15 01:22 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
5 lug Dakota were 1988 through 1990.
6 lug Dakotas started in 1991 and were present through the end of the truck line.
The 1991 through 1996 Dakota 6 lug stuff could be swapped by simply buying the 5 lug rotors on the front, and replacing the axle shafts (same size axle, the different sizes do not interchange) & drums on the rear.
In 1997, the front rotor, & bearing design was changed (along with the body change that appears to look more like the full size trucks). Converting from a 6 lug to a 5 lug is a major operation and not worth the effort. If you want 5 lug, get a 1996 or older frame to convert, or a 1990 frame with the existing 5 lug stuff. Gene
Re: `56 Dodge modern front end swap advice [Re: 67R/T4speeder] #1967088
12/10/15 02:52 PM
12/10/15 02:52 PM
Caldwell, Idaho
Caldwell, Idaho
Thanks again everyone for all the info
it really helps
Re: `56 Dodge modern front end swap advice [Re: 67R/T4speeder] #1993462
01/18/16 06:03 PM
01/18/16 06:03 PM
Caldwell, Idaho
Caldwell, Idaho
OK its not a Dodge I oops it a Plymouth Plaza I got excited with a new project. Found a Dakota the other day also. So here we go!!
Plaza straight six is suppose to be good runner so I will test it out where it is and if good I have `40 that could use it.
Re: `56 Dodge modern front end swap advice [Re: 67R/T4speeder] #1993718
01/18/16 11:23 PM
01/18/16 11:23 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Looks like a great place to start from. That will be a cool ride. Gene
Re: `56 Dodge modern front end swap advice [Re: 67R/T4speeder] #1995691
01/21/16 06:35 PM
01/21/16 06:35 PM
Caldwell, Idaho
Caldwell, Idaho
Found a decent truck for the swap, it has PS. PB. at least so those parts will come in handy. Dang it even runs so I can move it around at the shop tell I am ready. I have lots of measuring to do, better get a new tape measure ready.
Anyone need a service bed ? LOL
Re: `56 Dodge modern front end swap advice [Re: 67R/T4speeder] #1995750
01/21/16 07:32 PM
01/21/16 07:32 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
The service bed might be worth the hassles of a Craig's list ad, you sure won't need it, and its probably only worth $25 in scrap these days.
We will be watching the build process! Gene
Re: `56 Dodge modern front end swap advice [Re: 67R/T4speeder] #1995833
01/21/16 09:21 PM
01/21/16 09:21 PM
Lehigh Acres, Florida
rickstershemi Offline
Those Service Truck Beds make killer trailers I built a fleet of them years ago for my workers out of old utility trucks.
Rickster
Re: `56 Dodge modern front end swap advice [Re: 67R/T4speeder] #1996122
01/22/16 04:17 AM
01/22/16 04:17 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I suppose if your only using the front clip, making the utility box into a trailer would be very hard. Getting them titled here in IL is getting to be a challenge these days. Gene
Re: `56 Dodge modern front end swap advice [Re: 67R/T4speeder] #1998325
01/25/16 01:21 PM
01/25/16 01:21 PM
Caldwell, Idaho
Caldwell, Idaho
Saturday my wife and I started the flat six just to see if it would fun before we pulled for another project, ran real well so maybe just a minor rebuild or ?? .
And we took front clip off for a better look at the frame and good cleaning. She looks solid, I can start to see the similarities between the two frames now. Nice being a 3 on the tree car "it's got three pedals!!" since we are adding a 4-speed to the 360.
