Page 7 of 8 1 2 3 4 5 6 7 8
Re: `56 Plazakota [Re: 67R/T4speeder] #2117040
07/25/16 02:46 AM
07/25/16 02:46 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I would box the bracket in, or at least add a center support gusset, it will give the sheet metal more support on a rough road. The open bracket could flex and cause an issue with the rad & hoses om the roads around here. Gene
Re: `56 Plazakota [Re: 67R/T4speeder] #2117111
07/25/16 08:57 AM
07/25/16 08:57 AM
AZ
Mike P Offline
Mike P  Offline
AZ
The wheelbase on that looks great! I've seen way more frame swaps where the wheelbase isn't correct for the body than ones that look like they are supposed to.
As long as your welds are good you probably won't have a problem with the bracket as is. That being said a boxing in the top of the bracket would give it a more finished look and peace of mind for you.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold
1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold
1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears)
Re: `56 Plazakota [Re: 67R/T4speeder] #2117112
07/25/16 09:04 AM
07/25/16 09:04 AM
moparx Offline
moparx  Offline
if you mean the bracket used to support the front sheet metal, that would be a good idea, as that would eliminate any chance for it to promote side to side bending forces.
beer
Re: `56 Plazakota [Re: 67R/T4speeder] #2117207
07/25/16 12:01 PM
07/25/16 12:01 PM
Caldwell, Idaho
67R/T4speeder Offline OP
Caldwell, Idaho
Thanks for input peoples good or bad I like the input, I will box it in when I take front suspension off to rebuild worn parts.
Need to make bumper bracket mounts now. O goodie more welding I like to weld smile
Re: `56 Plazakota [Re: 67R/T4speeder] #2117826
07/26/16 01:03 AM
07/26/16 01:03 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
And, your doing a mighty fine job at it! up
Gene
Re: `56 Plazakota [Re: poorboy] #2124972
08/04/16 04:33 PM
08/04/16 04:33 PM
Caldwell, Idaho
Caldwell, Idaho
Gene
Thank you Gene
Re: `56 PLazakota project [Re: 67R/T4speeder] #2149715
09/07/16 04:23 PM
09/07/16 04:23 PM
Caldwell, Idaho
Caldwell, Idaho
I had some time to tear down suspension and cut off four/six banger mounts today. hammer
Re: `56 Plazakota [Re: 67R/T4speeder] #2157488
09/19/16 04:08 PM
09/19/16 04:08 PM
Caldwell, Idaho
Caldwell, Idaho
Fresh coat of paint always looks good to me.
Re: `56 Plazakota [Re: 67R/T4speeder] #2158224
09/20/16 07:04 PM
09/20/16 07:04 PM
British Columbia, Canada
Old Ray Offline
Old Ray  Offline
Upper steering shaft spliced together and welded.
Hi Andy, the short version of a long story is I have a ‘56 Plodge two door wagon and was on the forward looking site and met Gary Sand who sent me to the facebook site which had a link to this site. Still with me? Great thread, love it. I have been building cars for 55 years (I’m 72 now) and by no way mean any criticism or anything other than the greatest respect, just a heads-up that might not even be applicable but might save you some major grief down the road.
In many states and motor vehicle jurisdictions it is not permissible to weld on steering parts and if inspected would be a fail and if involved in any kind of accident probably result in a major lawsuit.
I’m a newbie here but not with cars and life, sorry for any discomfort caused, its not intended. (Canadians are always apologizing) I look forward to reading your thread.
Re: `56 Plazakota [Re: 67R/T4speeder] #2158804
09/21/16 03:24 PM
09/21/16 03:24 PM
Peoples Republic of Oregon
W
wayfarer Offline
wayfarer  Offline
W
....yeah...not an issue in the US.
Plenty of 'other' counties regulate everything but we're not there quite yet....
www.qualityengineeredcomponents.com
Early Hemi Parts and Tech
EarlyHemi and flat 6&8 trans adapters
***inventory clearance in progress. Nothing held back. See website.***
Re: `56 Plazakota [Re: 67R/T4speeder] #2162005
09/26/16 02:02 PM
09/26/16 02:02 PM
Caldwell, Idaho
Caldwell, Idaho
I managed to get core support bracket boxed in now I can paint it up.
Re: `56 Plazakota [Re: 67R/T4speeder] #2162631
09/27/16 10:12 AM
09/27/16 10:12 AM
moparx Offline
moparx  Offline
core support bracket looks good now. up it will be up to the task with no worries of flex or unwanted sideways movement.
beer
Re: `56 Plazakota [Re: moparx] #2162692
09/27/16 11:50 AM
09/27/16 11:50 AM
Caldwell, Idaho
Caldwell, Idaho
beer
I am going to make some rubber pads and metal shims to get body to line up similar to factory way.
Re: `56 Dodge modern front end swap advice [Re: John_Kunkel] #2177678
10/18/16 02:10 PM
10/18/16 02:10 PM
Caldwell, Idaho
Caldwell, Idaho
Do you use wheel adapters to get away from the 6 lugs Dakota?
Any idea what year donor truck is preferred?
Andy
My lugs are 5 X 4.5" so it might be a '90 clip or rotors were changed...junkyard receipt says it was a '91. shruggy
Do you have spool mounts on your car John I cannot tell in your pics you shared? Having some difficulty getting bracket to frame on drivers side to clear rack using spools.
Re: `56 Plazakota [Re: 67R/T4speeder] #2177681
10/18/16 02:18 PM
10/18/16 02:18 PM
Caldwell, Idaho
Caldwell, Idaho
Here is my issue with using the spool mounts at the moment. The rack is so close there is little room to build bracket to frame. Seems I had more room when I mocked up with pad style / early mounts. I go stare at it some more. work
Re: `56 Plazakota [Re: 67R/T4speeder] #2177762
10/18/16 04:10 PM
10/18/16 04:10 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Looks to me like you can go straight down with the frame brackets, then add a gusset at the rear of the brackets bracing towards the side, if you want to keep the spool mounts. When we did the 5.9 Magnum into the 57 Dodge wagon, we just used the later 80s sandwich mounts with the plate interlocks. Gene
Re: `56 Plazakota [Re: 67R/T4speeder] #2177997
10/18/16 07:02 PM
10/18/16 07:02 PM
Caldwell, Idaho
Caldwell, Idaho
Anchor 2469 fitting a B250 `88 type Gene? Thanks for input.
http://www.rockauto.com/en/catalog/dodge,1988,b250,5.2l+318cid+v8,1073449,engine,motor+mount,5552?a=Referer+www.google.com+URL+%2Fen%2Fcatalog%2Fdodge
Sorry not too good at linking shocked
Re: `56 Plazakota [Re: 67R/T4speeder] #2178088
10/18/16 09:22 PM
10/18/16 09:22 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Motor mount link
I haven't been too impressed with Anchor motor mounts myself, rubber comes apart too easy.
Don't be the exception.
Re: `56 Plazakota [Re: 67R/T4speeder] #2178186
10/18/16 11:04 PM
10/18/16 11:04 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I don't know about the brand, but those are the correct mounts we used. I believe ours came from Orilly's or NAPA. We paid more then $1.95 for them! Gene
Re: `56 Plazakota [Re: 67R/T4speeder] #2178493
10/19/16 11:58 AM
10/19/16 11:58 AM
Caldwell, Idaho
Caldwell, Idaho
I was just using that for a sample pic but I goofed that up LOL
I will see if dealer still has them around.
Thanks again
