Page 6 of 8 1 2 3 4 5 6 7 8
Re: Plazakota [Re: wayfarer] #2074431
05/16/16 11:55 AM
05/16/16 11:55 AM
Caldwell, Idaho
67R/T4speeder Offline OP
Caldwell, Idaho
Originally Posted By wayfarer
Here are some WMS measurements for those in need. NO, it is not complete and any additions will be appreciated.
http://www.qualityengineeredcomponents.com/?page_id=1023
NICE !! thank you
Re: Plazakota [Re: 67R/T4speeder] #2074821
05/16/16 11:21 PM
05/16/16 11:21 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Leaving IL on US 36, traveling through MO, KS then moving north in CO to Loveland. Got relatives in Loveland, planning on staying there a few days. Going to tour the Rocky Mountain Nat Park. Then we are heading north through WY on our way to the Black Hills in SD. Planning on spending a day or 2 there, before heading home on US 20 through SD, IA and back to Freeport IL.
16 days, 2200 miles, 7 States, in the coupe! We are intending on staying on two lane highways, and only traveling about 5 hours a day. If there is something we want to see along the way, we intend to stop. We are leaving home May 28. No time restraints other then being home on Monday June 13 for work.
Its been 25 years since we have taken a 2 week vacation! Gene
Re: Plazakota [Re: poorboy] #2074956
05/17/16 07:57 AM
05/17/16 07:57 AM
moparx Online content
moparx  Online Content
good for you gene ! sounds like a very enjoyable trip !
beer
Re: Plazakota [Re: 67R/T4speeder] #2075061
05/17/16 12:37 PM
05/17/16 12:37 PM
Peoples Republic of Oregon
W
wayfarer Offline
wayfarer  Offline
W
Sounds like a great road trip! Keep your eyes peeled for tin.
Early Hemi Parts and Tech
EarlyHemi and flat 6&8 trans adapters
***inventory clearance in progress. Nothing held back. See website.***
Re: `56 Plazakota [Re: 67R/T4speeder] #2075767
05/18/16 12:31 PM
05/18/16 12:31 PM
Caldwell, Idaho
Caldwell, Idaho
Trying different engine mounts out, I would like it to sit like this or close.
Re: `56 Dodge modern front end swap advice [Re: 67R/T4speeder] #2075818
05/18/16 02:06 PM
05/18/16 02:06 PM
W
wayfarer Offline
wayfarer  Offline
W
Looks like you have the 'wrong' block in there...it doesn't look like any 392 I have ever seen...... up
Re: `56 Dodge modern front end swap advice [Re: 67R/T4speeder] #2075927
05/18/16 04:15 PM
05/18/16 04:15 PM
Caldwell, Idaho
Caldwell, Idaho
OOOps I thought it was a little light there.
Re: `56 Plazakota [Re: 67R/T4speeder] #2075965
05/18/16 04:58 PM
05/18/16 04:58 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Before you make a final choice on engine location you might want to install the front end with the core support and check the relative location to the radiator core. Pic below shows my 360 in relation to the firewall and, in this position, the centerline of the water pump shaft is way low in the radiator core.
Re: `56 Plazakota [Re: 67R/T4speeder] #2076687
05/19/16 07:32 PM
05/19/16 07:32 PM
Caldwell, Idaho
Caldwell, Idaho
More good input and pics John thanks.
What headers are those? # stamp on flange?
Re: `56 Plazakota [Re: 67R/T4speeder] #2077190
05/20/16 04:34 PM
05/20/16 04:34 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The headers are Hedman 79540-6. Passenger side fits without dents but the drivers side is close to the steering shaft so it's dented a little. Wouldn't be necessary if the engine sat higher.
Re: `56 Plazakota [Re: John_Kunkel] #2077200
05/20/16 05:04 PM
05/20/16 05:04 PM
Caldwell, Idaho
Caldwell, Idaho
beer
Re: `56 Plazakota [Re: John_Kunkel] #2083527
05/31/16 06:32 PM
05/31/16 06:32 PM
Caldwell, Idaho
Caldwell, Idaho
Are those Magnum port?
Re: `56 Plazakota [Re: 67R/T4speeder] #2084172
06/01/16 05:11 PM
06/01/16 05:11 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yes.
Re: `56 Plazakota [Re: 67R/T4speeder] #2097313
06/24/16 12:46 PM
06/24/16 12:46 PM
Caldwell, Idaho
Caldwell, Idaho
I haven't had much time to tinker here but I did chop rack end of Dakota steering column and adapted to Plaza column housing so I could use the spring loaded bearing of the shaft which I like that idea. Now I need to get shafts to adapt together so I can keep stock wheel inside car.
Re: `56 Plazakota [Re: 67R/T4speeder] #2105822
07/07/16 07:05 PM
07/07/16 07:05 PM
Caldwell, Idaho
Caldwell, Idaho
Upper steering shaft spliced together and welded.
Re: `56 Plazakota project [Re: 67R/T4speeder] #2108902
07/12/16 07:03 PM
07/12/16 07:03 PM
Caldwell, Idaho
Caldwell, Idaho
Plaza got the front clip back on for a bit to see where I need to trim front Dakota frame horns to clear sheet metal so it will line up again.
The wheels are center of wheel opening...whooopie!!
Re: `56 Plazakota project [Re: 67R/T4speeder] #2109312
07/13/16 12:36 PM
07/13/16 12:36 PM
Caldwell, Idaho
Caldwell, Idaho
Fitting wheel back on modified shaft, still not in far enough but just resting there to see if I like it.
Re: `56 Plazakota [Re: 67R/T4speeder] #2116287
07/23/16 07:44 PM
07/23/16 07:44 PM
Caldwell, Idaho
Caldwell, Idaho
Finished making and welding up the core support bracket today.
I will add rubber cushions with final assembly.
Re: `56 Plazakota [Re: 67R/T4speeder] #2116513
07/24/16 09:50 AM
07/24/16 09:50 AM
that should work. could you show a pic of the engine compartment side of the core support/swaybar mount cross member ? thanks !
beer
Re: `56 Plazakota [Re: 67R/T4speeder] #2116626
07/24/16 01:40 PM
07/24/16 01:40 PM
Caldwell, Idaho
Caldwell, Idaho
Here you go, it is 4" c-channel, I wanted it to be bolted in so any fine tuning the body guy needs to they can shim either at sway bar bracket and center bracket like factory. Kinda like how sway bar tuck's inside it.
Thinking of boxing in bracket I welded to c-channel on engine side, what do you think?
