Ok Who Index's there plugs? #196101
01/17/09 03:19 PM
01/17/09 03:19 PM
Rock Springs
Bob_Coomer Offline OP
Rock Springs
I would NOT be posting this thread,but the offer made by Domino1609 Rick Liuzzo made this possible. I just wanted to see, who does this. I my self never have. But that will soon change. I know this is worth the time, and effort. I also wanted to know who has the best kits (washers) that has plenty enough to do a engine, and has the correct variety of thickness washers...
Again
Who takes the time to Index plugs
single choice
Votes accepted starting: 01/17/09 02:17 PM
You must vote before you can view the results of this poll.
Re: Ok Who Index's there plugs? [Re: Bob_Coomer] #196102
01/17/09 05:28 PM
01/17/09 05:28 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i use to do this but did lots of back to back tests & found zero gain so i gave up this process.
Re: Ok Who Index's there plugs? [Re: rebel] #196103
01/17/09 05:45 PM
01/17/09 05:45 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I used to also, I only do it now when I am bored,,,but I did notice the car would idle better but it made Zero change down the track.
Re: Ok Who Index's there plugs? [Re: Bob_Coomer] #196104
01/17/09 05:47 PM
01/17/09 05:47 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I have only done it on BBChevy engines with 15-1 pistons because you have to, otherwise they will get smacked by the pistons. Have never done it on a mopar engine.
Re: Ok Who Index's there plugs? [Re: Challenger 1] #196105
01/17/09 06:38 PM
01/17/09 06:38 PM
Mi.
G-Money1320 Offline
G-Money1320  Offline
Mi.
I did it when I installed my new Edelbrock heads on my motor before I put them on since it was easier at that time. I have read from some people that say it doesnt make a difference and it might not but if the spark is pointing in the direction of the incoming gasses then it sure couldnt hurt
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out.
11.06 open headers----so far!!
Re: Ok Who Index's there plugs? [Re: G-Money1320] #196106
01/17/09 07:37 PM
01/17/09 07:37 PM
Salina ks
572_dup2 Offline
Back On The Bumper!!
572_dup2  Offline
Salina ks
always do
Shawn Jennings
Re: Ok Who Index's there plugs? [Re: 572_dup2] #196107
01/17/09 07:40 PM
01/17/09 07:40 PM
Q
Quicktree Offline
Quicktree  Offline
Q
waste of time unless you have clearance issues.
Re: Ok Who Index's there plugs? [Re: Quicktree] #196108
01/17/09 07:44 PM
01/17/09 07:44 PM
Salina ks
572_dup2 Offline
572_dup2  Offline
Salina ks
I have no clearance issuses.
Shawn Jennings
Re: Ok Who Index's there plugs? [Re: rebel] #196109
01/17/09 08:25 PM
01/17/09 08:25 PM
Colorado
506RR Offline
506RR  Offline
Colorado
We saw zero difference doing this, so we stopped and considered it a waste of time. Although I have heard other people swear by it.
Re: Ok Who Index's there plugs? [Re: Bob_Coomer] #196110
01/17/09 09:38 PM
01/17/09 09:38 PM
Carbondale PA
Domino1609 Offline
Domino1609  Offline
Carbondale PA
Again
For what its worth, and this is only our opinion.
Most of the engines that we are involved in MUST have their plugs indexed, it is not an option. We will do anything to get the CR up and a pocket to fit the electrode is not in the picture.Our motors are a royal pain because there is only about 12 deg total area that a plug will fit in each hole.
I almost dont want to admit buying cases and cases of race plugs because I would not use an index washer, all because it would lower the CR in that hole.
Yes I know................
Remember this was in our 785HP 299 CI single 750 carb W8 motor, I gave nothing up.
Even if they did fit and because we want to give the plug every chance we can to stay clean, and fire, I would do it.
In engines that have high cylinder pressure, very high RPM, a dome, are rolled a ton, or a combination of any of the above, it gets harder for the plug to fire, to me it makes good sense not to shroud it. It just depends on the application, and the owner.
You may do it and never see a performance gain, but way back when the Super Comp class started our Dragster with a mild 440, iron 906 heads, flat tops, flat tappet cam, two 750s, ran 830s all day like a clock, I did it in that.
Its just part of a package, part of a way of doing things.
If you have a flat top or dish piston, there is probably no real reason to index, but it does not take long, and it cant hurt.
I tell guys that do not want to spend a ton of time or money, just get them pointed up, as long as the electrode is not on the bottom, it is a help.
Rick
Re: Ok Who Index's there plugs? [Re: rebel] #196111
01/17/09 11:52 PM
01/17/09 11:52 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Unless it's to orient the plug for piston clearance it's a complete waste of time.
Re: Ok Who Index's there plugs? [Re: Challenger 1] #196112
01/17/09 11:59 PM
01/17/09 11:59 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Re: Ok Who Index's there plugs? [Re: rowin4] #196113
01/18/09 01:52 PM
01/18/09 01:52 PM
Rock Springs
Rock Springs
Well
I am currently building a Hemi that has a pretty big dome on the piston. I will take the time with this engine to index the plugs.
Re: Ok Who Index's there plugs? [Re: Bob_Coomer] #196114
01/18/09 01:57 PM
01/18/09 01:57 PM
Canada
RobR Offline
RobR  Offline
Canada
I do ...
Re: Ok Who Index's there plugs? [Re: rebel] #196115
01/18/09 03:30 PM
01/18/09 03:30 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Same results and now I use the new Champion and they are side fire anyways.
Re: Ok Who Index's there plugs? [Re: rowin4] #196116
01/19/09 07:15 PM
01/19/09 07:15 PM
Lehigh Acres, Florida
rickstershemi Offline
That's why i do it....
Rickster
