01 ram 5.9 magnum spark plugs wont come out #1960711
12/01/15 03:06 AM
12/01/15 03:06 AM
Chicago Burbs
sthemi Offline OP
sthemi  Offline OP
Chicago Burbs
I changed them 6-7 years ago, now they wont unscrew, simply turn in the head. At least that is what it feels like.
Probably wait until spring and tear out the shields, to get a better view.
Re: 01 ram 5.9 magnum spark plugs wont come out [Re: sthemi] #1960724
12/01/15 03:24 AM
12/01/15 03:24 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Must be rust issues keeping the socket from dropping over the hex of the plug. Can't say I've seen iron heads lose their threads like a ford triton etc.
Re: 01 ram 5.9 magnum spark plugs wont come out [Re: sthemi] #1960752
12/01/15 06:04 AM
12/01/15 06:04 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
Yes,pull out the shields,soak them with penetrant oil.They are split so you can crush and remove them.Your plug socket must not be reaching the spark plug.Unless the plug broke at the base,I've done that.Plug was rusty and twisted in half!
Re: 01 ram 5.9 magnum spark plugs wont come out [Re: sthemi] #1960872
12/01/15 01:22 PM
12/01/15 01:22 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Those shields are such a pain.
They fill up with dirt/rust so blow them out with compressed air after you get the boots off and soak them in penetrating fluid.
Mo' Farts
Moderated by "tbagger".
Re: 01 ram 5.9 magnum spark plugs wont come out [Re: sthemi] #1961299
12/01/15 10:40 PM
12/01/15 10:40 PM
Maine
jerseybud Offline
jerseybud  Offline
Maine
The engineer that pushed for these ought to be kicked in the groin.
I think the metal from the head rusts and pushes the stainless shield ever so slightly reducing its overall diameter, making it so a standard thickness spark plug socket won't go on.
As you can imagine, the shields come out with a fight. I've been toying with the idea that drilling a hole thru them so that a punch (or similar) can be placed thru the holes, and then use a slide hammer to pull them. BUT getting enough room to pull 5 and 6 out would be tough because of the angle.
YOUR FIX: grind down the OD of a cheap 5/8 plug socket. It will give you just enough room to get the plug out. You may need 2 or 3 to do the whole engine, as they tend to crack.
DO NOT try the pliers trick to remove the sheilds. You'll just end up removing them in pieces and it will take all day. It only works in no rust environments like arizona.
Re: 01 ram 5.9 magnum spark plugs wont come out [Re: sthemi] #1961545
12/02/15 06:47 AM
12/02/15 06:47 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
I use a hose clamp & a pair of pliers to get the shields out
Go ahead & break the top of the plug off & blow all the crap out around it
Use a short socket & once you get it turned a little spray it with PB or a good penetrating oil Move on to the next one till you start over
Thy're still not going to come easily & you will coat the new ones with Never Seize
Re: 01 ram 5.9 magnum spark plugs wont come out [Re: sthemi] #1967581
12/11/15 04:54 AM
12/11/15 04:54 AM
Chicago Burbs
sthemi Offline OP
sthemi  Offline OP
Chicago Burbs
Thanks for the replies, it is going to wait until spring..
The reason I was going to change the plugs was it had a dead miss on one cylinder.
Turns out a squirrel ate the wiring to one fuel injector..
At least he left me a nut....
Re: 01 ram 5.9 magnum spark plugs wont come out [Re: sthemi] #1967590
12/11/15 07:32 AM
12/11/15 07:32 AM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
I ought to save this thread to show everyone that asks me "why do you shoot those squirrels?
