Tubular upper control arms #1959337
11/28/15 05:53 PM
11/28/15 05:53 PM
Marysville, WA
77ProStreet Offline OP
Marysville, WA
I bought these from a guy I found on Instagram, he said he's made many sets and even offered them on moparts. I figured I'd try them out. Not a bad price for tubular control arms that are reengineered for bad ball joint angle. I paid $350 and they are nice quality pieces. If you guys are interested, I can give his info as long as its ok with him. Maybe he'll chime in here. I haven't installed them yet as I'm getting them powder coated first. [img:center][/img] [img:center][/img] [img:left][/img] [img:right][/img]
Re: Tubular upper control arms [Re: 77ProStreet] #1959598
11/29/15 05:01 AM
11/29/15 05:01 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Did you buy those from Brandon
Re: Tubular upper control arms [Re: 77ProStreet] #1959599
11/29/15 05:20 AM
11/29/15 05:20 AM
Marysville, WA
Marysville, WA
Yes
Re: Tubular upper control arms [Re: 77ProStreet] #1959609
11/29/15 09:28 AM
11/29/15 09:28 AM
,Pa.
68dodge Offline
68dodge  Offline
,Pa.
They look good. Are they any lighter then the stock ones? Do you know how much the ball joint angle was changed? Thanks.
Re: Tubular upper control arms [Re: 77ProStreet] #1959710
11/29/15 02:34 PM
11/29/15 02:34 PM
Marysville, WA
Marysville, WA
I'm sure they are but won't know for sure tull I pull stock ones off. I would have to ask Brandon on that. They definitely take the bind off the joint tho.
Re: Tubular upper control arms [Re: 77ProStreet] #1959988
11/29/15 11:39 PM
11/29/15 11:39 PM
virginia
b-radschopshop Offline
virginia
to those who want to know, there about the same weight. i need to weigh them to be correct. but both in hand its hard to tell.
fabrication of 72-93 dodge truck suspension specialist
Re: Tubular upper control arms [Re: b-radschopshop] #1961243
12/01/15 09:16 PM
12/01/15 09:16 PM
virginia
virginia
these are on my bagged truck.
