Which rear shocks with SS springs? #195955
01/17/09 11:53 AM
01/17/09 11:53 AM
Houma, Louisiana
twister360 Offline OP
Houma, Louisiana
I have a 74 Duster that has SS springs and I added 3" lowering blocks to get the rear end back down to somewhat normal. I was able to install the 3 way adjustable shocks on the car but the stroke of the shock seems to be too short. Is there a longer shock to install when adding SS springs and lowering bloks? What brand would you use? Thanks Gary
My car 74 Duster mild 360/904/3.91 13.44/101.54 Son's car 75 Dart Sport 318/904/4.10 looking for a 360 or 408 2004 Dodge Ram 1500 Laramie 5.7 2010 Dodge Challenger R/T Classic B-5 6 speed 2010 Jeep SRT8 for the little wife
Re: Which rear shocks with SS springs? [Re: twister360] #195956
01/17/09 12:41 PM
01/17/09 12:41 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Re: Which rear shocks with SS springs? [Re: Dodgem] #195957
01/17/09 01:04 PM
01/17/09 01:04 PM
Salina ks
572_dup2 Offline
Back On The Bumper!!
572_dup2  Offline
Salina ks
Maybe something here that will help. Click on SS Springs. carpetperfect.com
Shawn Jennings
Re: Which rear shocks with SS springs? [Re: twister360] #195958
01/17/09 04:46 PM
01/17/09 04:46 PM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
I simply use shocks for an Imperial. They are longer than my stock "B" body shocks. The old Direct Connection chassis manual recomends them.
This is the land of the free because of the brave
Re: Which rear shocks with SS springs? [Re: twister360] #195959
01/17/09 05:35 PM
01/17/09 05:35 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
What is your intended use for this car?
By adding the 3" lowering block, youve (IMO) added a "lever" between your rear end and your springs. Think about lift blocks on a 4X4 truck. The blocks increase the rear ends leverage to "wrap up" the springs, increasing the possibility of wheel hop.
I realize you did this to lower the car back to a reasonable height. Just wanted to be sure you were aware that there is a downside to blocks. If youre not doing alot of drag racing, you may not have any issues.
To answer your question, I used 77 D100 shocks on my 65 Coronet
Re: Which rear shocks with SS springs? [Re: NTOLERANCE] #195960
01/17/09 06:26 PM
01/17/09 06:26 PM
Houma, Louisiana
Houma, Louisiana
I do go to the track sometime and the car hooks up real good with no wheel hop. I have some Mickey Thompson Street radials and they have excellent grip off the line. I just realize that the shocks are too short and wanted something else. Thanks for the reply Gary
Re: Which rear shocks with SS springs? [Re: twister360] #195961
01/17/09 09:43 PM
01/17/09 09:43 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
There are shock extenders out there as well.
http://store.summitracing.com/partdetail...mp;autoview=sku
Re: Which rear shocks with SS springs? [Re: NTOLERANCE] #195962
01/18/09 09:31 AM
01/18/09 09:31 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Yours leafs, shock plates and the bottom ends of your shocks are too far away from your chassis.
The addition of blocks only corrected the ride height.
Lose the lowering blocks and have a spring shop dearch your SS springs.
Re: Which rear shocks with SS springs? [Re: Magnum] #195963
01/18/09 11:07 AM
01/18/09 11:07 AM
Back In Iowa
belv2vert66 Offline
belv2vert66  Offline
Back In Iowa
Not to hijack, but I can't find any that will fit either. The D100 shocks have too small of a bushing at the top mount. I could probably change the top mount but I paid to have them zinc plated.... I am going to try ordering the ones for the Imperials.
Re: Which rear shocks with SS springs? [Re: twister360] #195964
01/18/09 01:03 PM
01/18/09 01:03 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
I have '84 D250 truck shocks on my '73 Duster with SS springs. NO lowering blocks though.
I had (too short) Summit 90/10 drag shocks on it before and after installing the truck shocks last fall my 60 foot went from 1.90 to 1.81.
Re: Which rear shocks with SS springs? [Re: dustergirl340] #195965
01/18/09 02:22 PM
01/18/09 02:22 PM
Salina ks
572_dup2 Offline
572_dup2  Offline
Salina ks
i used shocks for ramcharger truck
Shawn Jennings
Re: Which rear shocks with SS springs? [Re: dustergirl340] #195966
01/18/09 08:41 PM
01/18/09 08:41 PM
Houma, Louisiana
Houma, Louisiana
With the SS springs does you car sit pretty high in the rear? And how does it ride? Thanks Gary
Re: Which rear shocks with SS springs? [Re: twister360] #195967
01/19/09 11:24 AM
01/19/09 11:24 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Are these truck shocks you guys are using just regular Monroe matics, or gas matics or ???
Re: Which rear shocks with SS springs? [Re: twister360] #195968
01/19/09 11:57 AM
01/19/09 11:57 AM
Chicken coop
Chicken Little
Chicken Little
Chicken coop
Sits about the same as with my old HD ESPO springs. Here's a pic with the SS springs.
The ride is a little harder with the SS springs, but I really only notice on really rough roads, no big deal at all to me.
Re: Which rear shocks with SS springs? [Re: ademon] #195969
01/19/09 11:58 AM
01/19/09 11:58 AM
Chicken coop
Chicken Little
Chicken Little
Chicken coop
Monroe Gas Matics.
