Felpro valve cover gasket too long on 1 side #195911
01/17/09 11:19 AM
01/17/09 11:19 AM
Northern Virginia
Moparmaniacc Offline OP
Northern Virginia
I'm switching from chrome to stock valve covers I bought a long time ago. I test fit the gasket on the passenger side cover and the gasket seems to be a good 1/8" or 3/16" too long on one side. The cover seems fairly straight. Should I just cut this much out of the gasket before glueing it to the cover? What the best stuff to use, Permatex blue?
Re: Felpro valve cover gasket too long on 1 side [Re: Moparmaniacc] #195912
01/17/09 04:51 PM
01/17/09 04:51 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
I use permetex blue, only on the valve cover side, nothing on the engine side.
Re: Felpro valve cover gasket too long on 1 side [Re: Moparmaniacc] #195913
01/17/09 05:11 PM
01/17/09 05:11 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You shouldn't have to alter the gasket. You should be able to glue the gasket into the cover and the gasket will stay in where in place when installed. Just make sure the ends are inside the cover when you glue it
Re: Felpro valve cover gasket too long on 1 side [Re: stumpy] #195914
01/17/09 05:52 PM
01/17/09 05:52 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
As far as the sealant, I prefer Right Stuff gasket maker, made by permatex, item# 85224
You can get it at NAPA, their part number is 7653016.
Its not cheap.....
