Bearing clearance
#1957100
11/24/15 03:39 PM
11/24/15 03:39 PM
Triple Threat
Renton Washington
What is everyone running for bearing clearance?
If you could include what pump you're running and weight of the oil that would be helpful too.
Thanks!
Re: Bearing clearance
[Re: Triple Threat]
#1957155
11/24/15 04:48 PM
11/24/15 04:48 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
you already know mine but for other Ill post
.0025 on rods .003 on mains
Stock 6.1 pump. with piston squirters and 15-40 rotella it would get to about 60 psi oil pressure
without squirters, I have chaged to 10-40 mobil 1 and have about 60psi at idle and goes to 75-80 at wot
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: Triple Threat]
#1957265
11/24/15 07:33 PM
11/24/15 07:33 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Same clearance as Ray Melling 10342 pump, 6.1 pump spring Squirters installed 5W40 Rotella Synthetic 45 psi idle, 65-70 full song
Mopar to the bone!!!
[Re: Triple Threat]
#1957311
11/24/15 08:51 PM
11/24/15 08:51 PM
Posts: 3,871 Smyrna, South Carolina
STEFF
.003 rods, .0035 mains, no squirters, belt driven Petersen R4 pump, 5w20 oil, 25 psi idle, 80 psi at 7500
