ZOLATONE TRUNK PAINT #1956744
11/23/15 10:19 PM
11/23/15 10:19 PM
N.E. OHIO
P
polara426 Offline OP
P
N.E. OHIO
TPC Global says they no longer can mix the trunk paint for 65 B bodies does anyone know of someone else or a good alternative other than spray bomb.
Re: ZOLATONE TRUNK PAINT [Re: polara426] #1956761
11/23/15 10:35 PM
11/23/15 10:35 PM
west palm beach, florida
modelmakerinc Offline
is it a specific color you are looking for? you can buy Zolatone in lots of colors through Amazon, i just bought a few quarts of different colors
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: ZOLATONE TRUNK PAINT [Re: modelmakerinc] #1956763
11/23/15 10:41 PM
11/23/15 10:41 PM
N.E. OHIO
P
P
N.E. OHIO
Yes DX1734 Grey white blue. 64 and 65 b body
Re: ZOLATONE TRUNK PAINT [Re: polara426] #1959885
11/29/15 08:25 PM
11/29/15 08:25 PM
Albany, NY
67SATisfaction Offline
The member whose name is actually Art
Albany, NY
You are probably looking for a factory correct mixture. In which case this might not be helpful but when resto'ing my '65 Satellite I found an acceptable rattle can product at NAPA, or maybe it was Advance Autoparts.
There were a couple color choices.
I picked gray/black/white. It had a decent build-up and looks adequate.
- Art
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: ZOLATONE TRUNK PAINT [Re: 67SATisfaction] #1959900
11/29/15 08:58 PM
11/29/15 08:58 PM
N.E. OHIO
P
P
N.E. OHIO
Thanks might have to do that. Anyone else find Zolatone for early b.
Re: ZOLATONE TRUNK PAINT [Re: polara426] #1960146
11/30/15 11:03 AM
11/30/15 11:03 AM
moparx Online content
moparx  Online Content
in order for that stuff to be durable, doesn't it have to be cleared over ? or is the newer stuff better at durability ?
beer
Re: ZOLATONE TRUNK PAINT [Re: polara426] #1960423
11/30/15 08:38 PM
11/30/15 08:38 PM
The rattle can crap is usually a mix of oil/and water base paint to stay separated and achieve the look and will need to be cleared.
Zolatone is specically designed and does not need a clear, they do have a catalyst that hardens it further and makes it more durable.
I would choose a similar/maybe not "correct" color and still use the Zolatone brand paint because it is so durable and looks much nicer than rattle can.
Re: ZOLATONE TRUNK PAINT [Re: modelmakerinc] #1960582
12/01/15 12:23 AM
12/01/15 12:23 AM
N.E. OHIO
P
P
N.E. OHIO
I agree I used it my 64 Dodge and has held up well and looks factory. I know Moshers uses it in their restorations. I will see if they have something close.
Re: ZOLATONE TRUNK PAINT [Re: modelmakerinc] #1960585
12/01/15 12:27 AM
12/01/15 12:27 AM
Albany, NY
Albany, NY
Originally Posted By modelmakerinc
The rattle can crap ….. will need to be cleared.
Not the stuff I used, but maybe depends on the result you want.
This is an automotive paint product by Dupli-Color, called Splatter Paint Speckle Finish, "Restores Trunk Finish". The color I used was DM100 Gray/White.
Directions say nothing about top coating it. It's been as durable I need it to be.
Here it is in the background of this "electrical" photo.
Cheers, - Art
