Page 1 of 16 1 2 3 15 16 >
#1955519 - 11/21/15 05:34 PM OK! No more BS. Time to start working.
sgcuda Offline
Loc: Charlotte, North Carolina
After my mother-in-law passing away this week, I decided that life is too short to procrastinate on everything you want to do. So the garbage got thrown out, everything else got put in a spot, the Cuda finally saw daylight after, I don't know how long, bath and up on jack stands. Tomorrow, measure, measure, measure, disassemble and measure.
#1955526 - 11/21/15 05:48 PM Re: OK! No more BS. Time to start working. [Re: sgcuda]
ProSport Offline
Loc: Akron, Ohio
I wondered what happened to that car. Glad you're back on it.
Sassy Grass street Duster, best of 10.69 at 124 driven to the track with 3.23 gears, naturally aspirated on 93 octane.
#1955540 - 11/21/15 06:07 PM Re: OK! No more BS. Time to start working. [Re: sgcuda]
sgcuda Offline
Measured frame rail widths. Front rails are 33" on the inside where the notch is to clear the header tube. Rear backhalf is 31" on the inside. Headers are 28" on the outside. Going to cut right in front of the notch and go straight back to the ladder bar crossmember, and stay 1/2 above the rocker sill (stock rails are about 1" lower than rocker sill from front wheel well opening to transmission crossmember). New trans crossmember and driveshaft loop crossmember will get added. Old loop member is welded in and creates issues when removing trans. 4 speed input is very long.
[image][/image]
#1955619 - 11/21/15 09:10 PM Re: OK! No more BS. Time to start working. [Re: sgcuda]
Dragula Offline
Loc: Taxes R-US, NY
That will buff right out...
'71 Duster Pump Gas 512LD 2013 Mod Gas Winner GRS
https://www.youtube.com/watch?v=Z_XTmRBuvWs (6.19)
https://www.youtube.com/watch?v=gQZGfDBPROM (9.70 at 138.5mph)
'70 Cuda, Plan C....605 Hemi
https://www.youtube.com/watch?v=WYw6RA-k5Bk (6.31)
#1955633 - 11/21/15 09:35 PM Re: OK! No more BS. Time to start working. [Re: sgcuda]
MadMopars Offline
Loc: Tucson AZ,
Sorry to hear about your mother-in-law. frown The car looks like a fun project, everyone else's stuff always looks more fun than mine though.biggrin Is that the same car that's in your signature pic? If so, what was your reason for tearing it down in the first place?
73 GTX *440*727*8 3/4*
69 DART GT *440*4 SPEED*DANA*
73 ROAD RUNNER *451*4 SPEED*DANA*
75 DODGE D300 *440*4 SPEED*DANA*
99 DODGE RAM 3500 4X4 DUALLY... ON 38"s
#1955667 - 11/21/15 11:16 PM Re: OK! No more BS. Time to start working. [Re: sgcuda]
sgcuda Offline
Well, I got in a bit of trouble some years ago, so I sold the car to a co-worker. After sanding it down and sitting out in the weather for 2 years, I was able to buy it back. Not quite the same shape as before, but at least I got it. I wasn't happy with the first attempt, homemade front end, so that got torn out. Engine in avatar was almost done, until I got some new ideas.
[image][/image]
#1955981 - 11/22/15 03:31 PM Re: OK! No more BS. Time to start working. [Re: sgcuda]
sgcuda Offline
Well, disassembled and pulled the rear end out today. Internals look great.
#1955984 - 11/22/15 03:33 PM Re: OK! No more BS. Time to start working. [Re: sgcuda]
sgcuda Offline
But serious damage was just around the corner on the right side. Something weird causing the right axle shaft to move around. The inside of the drive studs started to cut through the wheel cylinder. Could have been nasty.
[image][/image]
#1955988 - 11/22/15 03:38 PM Re: OK! No more BS. Time to start working. [Re: sgcuda]
sgcuda Offline
Measured both axles flange to retainer, drivestud distance, checked for differences in wheel cylinders, mounting studs for retainer, backing plate depth. Checked axle bearing registers, heights, etc. The only thing I see is that there is a grease line around the seal on the right bearing where it oozed out a little. The left bearing is sparkling clean. Could the rollers in the bearing be worn? It had to move over .100". I didn't notice any motion when I tore it down. Going to call Moser during the week to see if they could shed some light.
[image][/image]
#1956419 - 11/23/15 09:43 AM Re: OK! No more BS. Time to start working. [Re: sgcuda]
an8sec70cuda Offline
Loc: Marion, South Carolina [><]
Glad to see you're getting it out and working on it again Kenny! Sorry about your MIL...tell Diane I'll be thinking about her.
On the axle...take a good look at the machined surface the bearing is pressed onto. It must be worn and letting the axle/bearing slip in and out...IF the bearing itself is still in good shape.
CHIP
'70 hemicuda...8.91 at 150.5 mph street car...Mopar Action feature Dec. '14
'69 road runner 440 w/ Indy SRs
'69 road runner 440-6, 4 speed...Dad's ride
'71 Demon 340 resto project
'06 GMC 2500HD LBZ Duramax...toy hauler
'16 Grand Caravan SXT...baby hauler
#1956754 - 11/23/15 07:27 PM Re: OK! No more BS. Time to start working. [Re: sgcuda]
sgcuda Offline
Thanks, Chip.
Nope. Bearing isn't walking on the axle. I think the inside step on the race is worn. Changing both axle bearings.
[image][/image]
#1958015 - 11/25/15 09:37 PM Re: OK! No more BS. Time to start working. [Re: sgcuda]
sgcuda Offline
Thinking of going with a set of outlaw bars. Anyone use them yet? Any other companies make them at a better price?
http://chassisengineering.com/index.php?route=product/category&path=25_223
[image][/image]
#1958026 - 11/25/15 09:55 PM Re: OK! No more BS. Time to start working. [Re: sgcuda]
sgcuda Offline
Does anyone have a coupon code for Chassis Engineering???
[image][/image]
#1958522 - 11/26/15 06:54 PM Re: OK! No more BS. Time to start working. [Re: sgcuda]
sgcuda Offline
Figured out axle problem. Housing was deeper than bearing thickness, plus gasket thickness, plus backing plate thickness, allowed for .150" motion. Will fabricate up shims.
Ran a ride height line along the side of the car and set the rear slicks in place. Setting up for about 4" ground clearance in the front and 6" in the rear. Significantly lower than before. For the first time, the lower ladder bar will actually be able to adjust above and below parallel to ground.
[image][/image]
#1958538 - 11/26/15 07:34 PM Re: OK! No more BS. Time to start working. [Re: sgcuda]
496 A-body Offline
Loc: Indy
Hey Kenny, here are some outlaw bars at a better price
http://smithracecraft.com/index.php?page...rt&Itemid=1
#1958554 - 11/26/15 07:56 PM Re: OK! No more BS. Time to start working. [Re: sgcuda]
sgcuda Offline
Thanks, Neil.
They look as good as the chassis engineering piece, minus the coil over brackets. I'll give them a call and see if they have a bracket upgrade.
[image][/image]
#1959380 - 11/28/15 04:52 PM Re: OK! No more BS. Time to start working. [Re: sgcuda]
sgcuda Offline
So, I have come to the conclusion that when in your 20's, since priorities are sex and alcohol (and not necessarily in that order) maybe welding should be left to the more experienced. Finally repaired/redone/finished the parachute mounting crossmember. My level of expertise at that time was "Make sure the snow plow doesn't fall off the front of the boss's tow truck!".
I'm getting close, Chip. Take a good look at the pic. Your going to be seeing this view a lot this summer. beer
[image][/image]
#1960284 - 11/30/15 01:09 PM Re: OK! No more BS. Time to start working. [Re: sgcuda]
I should hope so Kenny, but remember mine looks the same as yours. biggrin Only you can see my mufflers, small tires, and license plate from the rear. smoke
Just let me know when you're ready to TRY. biggrin
CHIP
#1963893 - 12/05/15 03:48 PM Re: OK! No more BS. Time to start working. [Re: sgcuda]
sgcuda Offline
I had the motor pro built while I did the chassis and suspension back in the late 80's. Not knowing anything about coil overs, I went through an extreme learning curve, including 1 time veering off the track on a 2-3 full power shift. Didn't wreck, minor damage, but knocked out the mirrors in the headlight buckets. Never got around to putting them back after I sorted out the suspension... until now.
[image][/image]
#1963897 - 12/05/15 03:49 PM Re: OK! No more BS. Time to start working. [Re: sgcuda]
sgcuda Offline
And here's my pit crew
25,631 Registered Members
195,621 Topics
Holley fuel pressure regulator identification
by Hangtowner
12/14/18 02:55 PM
HELP WITH PARTS REPO/RESTORATION
by Magnumguy
12/14/18 02:37 PM
1970 'Cuda
by moparjack44
12/14/18 02:20 PM
15% off Sporting goods - EBAY
by moparx
12/14/18 02:05 PM
