Page 2 of 16 1 2 3 4 15 16
Re: OK! No more BS. Time to start working. [Re: sgcuda] #1963902
12/05/15 06:57 PM
12/05/15 06:57 PM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
Cool car, stick going back in it?
Re: OK! No more BS. Time to start working. [Re: sgcuda] #1963912
12/05/15 07:08 PM
12/05/15 07:08 PM
Charlotte, North Carolina
sgcuda Offline OP
sgcuda  Offline OP
Thanks. Yes. Gears are going back to Libert for overhaul. Not sure if just going back with pro shift rings or maybe upgrade to face plate. Haven't talked to them yet on price difference. Going to also put on a Passon aluminum case, tailhousing and side cover.
[image][/image]
Re: OK! No more BS. Time to start working. [Re: sgcuda] #1963917
12/05/15 07:13 PM
12/05/15 07:13 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I like it !
Re: OK! No more BS. Time to start working. [Re: sgcuda] #1963922
12/05/15 07:16 PM
12/05/15 07:16 PM
sgcuda Offline OP
sgcuda  Offline OP
I have red and yellow LED bulbs that I was going to use for a street project, but I think I will install them in the Cuda. They are the old 1157 style, so I could put the high elements on during the day. Should look cool.
[image][/image]
Re: OK! No more BS. Time to start working. [Re: sgcuda] #1964087
12/06/15 12:12 AM
12/06/15 12:12 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Lookin GOOD! scope
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: OK! No more BS. Time to start working. [Re: sgcuda] #1964338
12/06/15 01:38 PM
12/06/15 01:38 PM
sgcuda Offline OP
sgcuda  Offline OP
I could use some input for front bumper alignment. Anyone have any front end shots of their cars? My Unlimited Fiberglass bumper never really fit right. I don't know if the bumper is supposed to overlap the lower part of the grill and the valance at the same time. The angle of the bumper never really matched the angle of the front of the car. The center of the bumper is tight against the car, but the ends droop and are wide from the fenders. Might be time for a replacement. Any recommendations?
[image][/image]
Re: OK! No more BS. Time to start working. [Re: sgcuda] #1964376
12/06/15 03:11 PM
12/06/15 03:11 PM
Indy
496 A-body Offline
496 A-body  Offline
Indy
Can't go wrong with Glasstek or AAR/Stinger
Re: OK! No more BS. Time to start working. [Re: sgcuda] #1964447
12/06/15 05:16 PM
12/06/15 05:16 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Nice Duster!! ^^^
Re: OK! No more BS. Time to start working. [Re: sgcuda] #1964482
12/06/15 06:29 PM
12/06/15 06:29 PM
sgcuda Offline OP
sgcuda  Offline OP
Today's project. The wheelie bar brackets were welded on at a slightly wrong angle. By the time I got the pinion angle right, the bars were only an inch or two off the ground. Tightening the adjusters made the bars look like a bow and arrow. Tires being fairly worn and poor shock adjustments, made them slap so hard, you could see smoke on the 3-4 shift. Oh well, didn't need those anyway.
So, I modified the brackets and got the adjustments right. Axle is on a 15 3/4" centerline height. Housing is level. Wheelie bars are 8" off the ground with 2" of adjuster threads showing.
Re: OK! No more BS. Time to start working. [Re: sgcuda] #1964892
12/07/15 02:11 PM
12/07/15 02:11 PM
an8sec70cuda Offline
Sent a couple pics to your email to help w/ the bumper.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: OK! No more BS. Time to start working. [Re: sgcuda] #1965162
12/07/15 10:35 PM
12/07/15 10:35 PM
sgcuda Offline OP
sgcuda  Offline OP
Thanks, Chip.
Look what was on the Chrysler technical website this morning.
Re: OK! No more BS. Time to start working. [Re: sgcuda] #1970580
12/16/15 12:47 AM
12/16/15 12:47 AM
sgcuda Offline OP
sgcuda  Offline OP
Talked to Josh at Smith Racecraft today. Ordered custom cut Triple Adjustable Ladder bars, diagonal link and crossmember kit. Great guys. Gave me a great price. Not sure if they will be in time to go under the Christmas tree. Oh well. Pics to follow.
[image][/image]
Re: OK! No more BS. Time to start working. [Re: sgcuda] #1972956
12/19/15 10:28 PM
12/19/15 10:28 PM
sgcuda Offline OP
sgcuda  Offline OP
Got metering blocks, throttle plates, axle cover coming in for Christmas. Axle cover is Strange piece in black. My question is: do I paint my rear housing in black or in silver? I thought that the silver contrast would look different. Will be painting the ladder bars black. Rear shocks for now are Koni (red) but will probably be upgrading to Summit or QA1 aluminum pieces. Frame rails, springs will be black.
[image][/image]
Re: OK! No more BS. Time to start working. [Re: sgcuda] #1973732
12/21/15 11:36 AM
12/21/15 11:36 AM
I'd paint the rear black. Check w/ Viking for shocks.
http://vi-king.com/
CHIP
Re: OK! No more BS. Time to start working. [Re: sgcuda] #1975020
12/23/15 05:24 AM
12/23/15 05:24 AM
Brisvegas, Australia
Alchemi Offline
Alchemi  Offline
Anything welded or known to crack, silver or white
off color lateral lines along things that twist - tail shaft/diff tubes
Easier to spot issues, may save $$ and time
Re: OK! No more BS. Time to start working. [Re: sgcuda] #1975191
12/23/15 04:04 PM
12/23/15 04:04 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I think satin black looks great on most everything underneath a car.
Re: OK! No more BS. Time to start working. [Re: sgcuda] #1975421
12/23/15 10:44 PM
12/23/15 10:44 PM
sgcuda Offline OP
sgcuda  Offline OP
Either way, silver or black, I was going to clear coat it afterwards. Lighter colors to shows early signs of fatigue sounds like a good idea. But who really checks stuff like that. If it cracks, I'll find out on the next run. Black is always a killer look, but everyone and their brother has it painted black. First, I'll put the 4.10's in and clean the housing. Maybe purple??? Santa
[image][/image]
Re: OK! No more BS. Time to start working. [Re: sgcuda] #1978365
12/29/15 02:05 AM
12/29/15 02:05 AM
sgcuda Offline OP
sgcuda  Offline OP
Finally got my Christmas present!
[image][/image]
Re: OK! No more BS. Time to start working. [Re: sgcuda] #1981048
01/01/16 02:07 PM
01/01/16 02:07 PM
sgcuda Offline OP
sgcuda  Offline OP
Back to the axle bearing issue. Will probably be upgrading to rear disc brakes. That means the drum brake backing plates will be removed, taking .100" of motion out of the equation. Should fix the issue. My question is, where does the Wildwood rear brake caliper bracket attach to the housing flange? From the back or front of the flange. If it attaches from the front (axle shaft side) I'm guessing that I will have to grind the drive studs pretty short. Does anyone have a pic of the bracket on their rear axle?
[image][/image]
Re: OK! No more BS. Time to start working. [Re: sgcuda] #1982991
01/03/16 09:01 PM
01/03/16 09:01 PM
sgcuda Offline OP
sgcuda  Offline OP
Running out of room, quickly, in the garage.
