11" pressure plate mopar,chevy,ford? Also bellhousing questions.
#195128
01/16/09 01:12 PM
01/16/09 01:12 PM
Posts: 862 Iowa State fan
kilroy
Iowa State fan
Is there any difference in the 11" pressure plate between a mopar chevy and ford? If so what are the differences? Its a lot easier to find pressure plate for brand x and y! And let me ask this. Are the bellhousing flywheel specfic to the tooth count (aka 130 teeth flywheel and bellhousing) or can a 11 flywheel and 10.5 flywheel use the same bellhousing/starter teeth count combo?
Re: 11" pressure plate mopar,chevy,ford? Also bellhousing questions.
[Re: kilroy]
#195129
01/16/09 03:01 PM
01/16/09 03:01 PM
Posts: 43,007 Bend,OR USA
Cab_Burge
There are three different stock type pressure plates used in the three bmajor brands, diaprahm in GM, Borg and Beck in Mopars and long style in Fords. You can use them on the after market flywheels as long as you get all the parts needed to make them work like the throw out bearing and so on. If your using a factory stock bell housing you can't, as far as I know, switch flywhels and use the same starter. The bell housing starter mounts are fix so you can't move the starter, not the same on a scatter shield. The scatter sheilds that I have used (Ansen and Lakewewood brands)have several starter mounting holes so you can change the flywheel size and move the starter as needed IHTHs
[Re: Cab_Burge]
#195130
01/16/09 03:35 PM
01/16/09 03:35 PM
kilroy
Iowa State fan
So what your telling me is the pressure plate bolt positions are the same on the three manufacturers? What are the 11" , 10.5" flywheel counts or is it bb, sb, 6cyl teeth count and what are they.
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
[Re: kilroy]
#195131
01/16/09 04:45 PM
01/16/09 04:45 PM
Posts: 10,549 Rittman Ohio
fourgearsavoy
Rittman Ohio
The two common "car" flywheels are 130 tooth for smallblocks and some 383's.Most of the bigblocks and later Hemi's with gear reduction starters got the 143 tooth wheel.If you are going with a big block you can do either way with an aftermarket bell like Cab said.If you are going with a factory bell you will need the correct flywheel. If I were you I would get a Lakewood bell and a Hays billet 143 tooth race flywheel,it has just about every clutch bolt pattern that I have ever seen. Most all B&B 11" clutches are universal for Chevy and Mopar.I have an 11"Mcleod plate that came off a bigblock Chevy in my car now. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#195132
01/16/09 04:56 PM
01/16/09 04:56 PM
kilroy
Iowa State fan
thanks for pressure plate info!
[Re: kilroy]
#195133
01/17/09 10:02 PM
01/17/09 10:02 PM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
I think... (read think) that the zoom B&B pressure plate I have is the same for an 11" mopar and an 11" chevy truck.
I will check and get back to ya.
Doc.
[Re: NTOLERANCE]
#195134
01/17/09 10:18 PM
01/17/09 10:18 PM
NTOLERANCE
Madison Wi
Looks like my pressure plate number 250003 is obsolete.
I am pretty sure it was listed for Mopar and chevy trucks though.
Doc.
