Re: Will backing plates and drums from 8 3/4 work on Dana?
[Re: StrokedW7]
#194768
01/15/09 10:27 PM
01/15/09 10:27 PM
Posts: 1,505 TN
SCATPACK 1
TN
Ma Mopar used the same backing plates and drums on both rear ends. But that was with the same axle housing ends on both housings from Mopar. I assume your axles have the same spacing and ends on both housings.
Old Geezer Racing
[Re: SCATPACK 1]
#194769
01/16/09 03:00 AM
01/16/09 03:00 AM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
BBP stuff is all interchangable.
The only mismatch is between backing plates and drum combo's. So the drums you use, need to be from a similiar application as the backing plates you use.
In short, if you use drums and backing plates from ANY BBP 8.25, 8.75, 9.25, and 9.75 you are good to go,as long as they came off the same rig.
10" or 11" no problem.
