piston prep #194672
01/15/09 09:16 PM
01/15/09 09:16 PM
Finally a HUSKER again
Moparnut426 Offline OP
Is it ok to use a grey fine Scotch bright pad to de burr the tops of my pistons? I just want to break up any stress risor, or detonation hot spots.
What do you guys use?
Kasey
Re: piston prep [Re: Moparnut426] #194673
01/15/09 09:36 PM
01/15/09 09:36 PM
If there not ready for use now, unless you cut or did have extra deep valve reliefs cut into them, return them to the manufacturer
Re: piston prep [Re: Cab_Burge] #194674
01/15/09 10:01 PM
01/15/09 10:01 PM
They are Diamond pistons, they are VERY nice, but they have some shap edges. I took a non destructive testing, metalurgy class in colege, and know it doesnt take mutch to have a hot spot, and start detonation. Im just making sure nothing is overly sharp.
Kasey
Re: piston prep [Re: Moparnut426] #194675
01/15/09 10:31 PM
01/15/09 10:31 PM
gray, red or blue scotchbrite will be fine. it's a good idea to just dull those edges and it only takes a few minutes.
