Re: Mounting slicks
[Re: Aspen7695]
#194581
01/15/09 08:06 PM
01/15/09 08:06 PM
Posts: 549 Bristol, Va
fasteddie
Bristol, Va
The dish soap goes all over the inside of the tire. I haven't tried it but I need to. My new Hoosiers will leak down flat overnite.
2003 Bristol Dragway Sportsman Champion
2016 Bristol Dragway Power Hour Champion
Re: Mounting slicks
[Re: Aspen7695]
#194582
01/15/09 08:07 PM
01/15/09 08:07 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I have used tubes in the past mainly because I got tired of always having to put air in them. Some racers say you can stop them from leaking if you use dish soap on the bead when mounting them. Have any of you tried this? If you have, does it work, and what tricks do I need to know?
Raul
You put the dish soap on the interior side walls, a couple 2 or 3 coats.... let it dry between coat
Re: Mounting slicks
[Re: MR_P_BODY]
#194583
01/15/09 08:08 PM
01/15/09 08:08 PM
Posts: 19,360 Las Vegas
Al_Alguire
Las Vegas
AS Raff said you just need to soap up the sidewalls. I have found Dawn works bets for whatever reason, I use an entire bottle between my slicks, 15x33's.
Re: Mounting slicks
[Re: Al_Alguire]
#194584
01/16/09 08:19 AM
01/16/09 08:19 AM
Posts: 1,646 Ringtown, Pa.
Dartsport540
Ringtown, Pa.
I use Dawn also. About 1/2 to 3/4 of a bottle for 2 slicks. 32"x 13.5" x 15", Hoosier. I coat, around the inside. None on the bead. Mine are still holding air from november. In a building , with temperature set at 55*. This is the 5th set, without them leaking down.
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
