OH JOY!!!!!!!!!!! #194330
01/15/09 11:38 AM
01/15/09 11:38 AM
Finally a HUSKER again
Moparnut426 Offline OP
My crank, and pistons showed up today!!!
Thanks Dan at performance machine, they are in perfect shape, I have already inspected the parts for any shipping damage. Everything is fine, thank god!!
Thanks for being VERY reasonable on your prices!!
Kasey
Re: OH JOY!!!!!!!!!!! [Re: Moparnut426] #194331
01/15/09 12:46 PM
01/15/09 12:46 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Cool
Let the Begin
Re: OH JOY!!!!!!!!!!! [Re: WILD BILL] #194332
01/15/09 01:01 PM
01/15/09 01:01 PM
I have to get the block over to Kecks in Iowa to have the line honing done, and the balencing. then the wrenching, and the screaming can begin.
Kasey
Re: OH JOY!!!!!!!!!!! [Re: Moparnut426] #194333
01/15/09 01:04 PM
01/15/09 01:04 PM
Kasey
I thought that you are working on a SB,not a Hemiriod
Re: OH JOY!!!!!!!!!!! [Re: Cab_Burge] #194334
01/15/09 02:08 PM
01/15/09 02:08 PM
SD USA
neonic Offline
neonic  Offline
SD USA
Kasey
I didn't know there was a differance, says this SB owner.
Re: OH JOY!!!!!!!!!!! [Re: neonic] #194335
01/15/09 02:56 PM
01/15/09 02:56 PM
[ and the screaming can begin.
Kasey
Once you try to blueprint a Hemiroid you will know that there is a big difference in those two motors,SB , Hemiroid
Re: OH JOY!!!!!!!!!!! [Re: Cab_Burge] #194336
01/15/09 03:00 PM
01/15/09 03:00 PM
Its a small block, but I have herd gret things about Kecks shop,
Ive herd he is also a little slow, but thats better than fast and wrong!!
Kasey
Re: OH JOY!!!!!!!!!!! [Re: Moparnut426] #194337
01/15/09 07:11 PM
01/15/09 07:11 PM
Canada
lenweiler Offline
lenweiler  Offline
Canada
Christmas came a little late.......
Damn! I dropped my change.............
Re: OH JOY!!!!!!!!!!! [Re: Moparnut426] #194338
01/15/09 10:41 PM
01/15/09 10:41 PM
I'm glad to hear everything made it safely. thanks again.
Re: OH JOY!!!!!!!!!!! #194339
01/15/09 10:54 PM
01/15/09 10:54 PM
Ur the man DAN!!!
Are the bearings on the way??
THANK U THANK U THANK U!!
Re: OH JOY!!!!!!!!!!! [Re: Moparnut426] #194340
01/15/09 11:04 PM
01/15/09 11:04 PM
Ur the man DAN!!!
everything is on it's way.
Re: OH JOY!!!!!!!!!!! #194341
01/15/09 11:08 PM
01/15/09 11:08 PM
On the heads Dan, I think they are already machined to use the small seals, and tripple springs, so the Bee Hive springs should clear. When I switch the springs over, can I do it myself or should I have a head guy do it? I have all the tools to do the swap myself, but what do you think.
Kasey
Re: OH JOY!!!!!!!!!!! [Re: Moparnut426] #194342
01/15/09 11:31 PM
01/15/09 11:31 PM
you'll need a valve spring installed height mic that will work with the small retainers to set the installed height properly. the std. ones have too large of a hole in them for those beehive retainers. other than that it's a piece of cake.
Re: OH JOY!!!!!!!!!!! [Re: Moparnut426] #194343
01/17/09 07:34 PM
01/17/09 07:34 PM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
Kasey
Dan is great to deal with . Got my pistons, rods and crank from him also and all are quality pieces.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
