Re: Triple Black Bee
[Re: fc7_plumcrazy]
#1939395
10/27/15 12:45 AM
10/27/15 12:45 AM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
how is the current status? Yeah, are you going to have it ready for Woodward?
[Re: OhioMopar]
#1940422
10/28/15 03:22 PM
10/28/15 03:22 PM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
Not the best pics, but the 383 had been together since the mid '80's. So it was due for a freshening. Caught in the nick of time. Plum wore out. Being in focus doesn't make them look any better.
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
[Re: OhioMopar]
#1940430
10/28/15 03:32 PM
10/28/15 03:32 PM
OhioMopar
Mt.Gilead, Ohio
So it was all fresh and new, with a new crank, ready to go back in. Which it did. Then it ran for almost 5 seconds and stopped. Then it wouldn't turn over. In the case of "I've never seen this before", the forged 383 crank was not drilled for a pilot bushing. Go figure. So after pulling the engine, replacing the thrust bearings I crushed with the input shaft, cutting the end off the input shaft of a $2500 transmission, and putting it back together, it still wouldn't turn over. So back out it came. More off the input shaft. More measuring. Back together. No turn over. So we finally figured out the two year old Year One positive battery cable was junk. Replaced, fired it up, and finally I was able to drive it.
[Re: OhioMopar]
#1940457
10/28/15 03:59 PM
10/28/15 03:59 PM
OhioMopar
Mt.Gilead, Ohio
Now, for progress. It is still a running, driving machine. It is in need of a carb rebuild or replacement badly, and loaded up quit a bit after sitting during the Nats and after. So the oil needs changed, again, and the plugs need changed, again, and it needs some carb work. It doesn't run nearly as good as it should, but that will come once I really start tuning it. It feels good,but will feel better with new plugs and a better fuel delivery system. Having the engine out 3-4 times, I need to put new exhaust gaskets on it, these are roached. The front suspension and steering system should be gone through over the winter or early spring. The foundation is in place and strong, everything is new or rebuilt, now it is time to get it all dialed in. The short list: Carb rebuild or replacement. Exhaust gaskets. Front suspension Steering. That will do the safety items. Then I want to get my frame connectors in, maybe some different rear springs. More aluminum.(Dress up. I've outgrown the Mopar Performance look) Drive it...
[Re: DLewis]
#1942776
11/01/15 10:37 AM
11/01/15 10:37 AM
OhioMopar
Mt.Gilead, Ohio
Love it! How a Bee should look. Thank you. It has been a fun ride so far.
[Re: OhioMopar]
#1943119
11/01/15 05:42 PM
11/01/15 05:42 PM
Posts: 7,831 east side of Ohio
basketcase
east side of Ohio
nope...dead in the water. my guy got copd and can't finish it.paint is pretty much off the worry list, I'll just enjoy driving it.
1981 Dodge D150 360 auto
[Re: OhioMopar]
#1943124
11/01/15 06:04 PM
11/01/15 06:04 PM
Posts: 9,654 Southern by Choice
Shoozy
I have a foot fetish
Southern by Choice
If it was easy.... Love your persistence - that's what the hobby is all about. Look forward to seeing you next year out on Woodward
Old, tired, and sometimes broke down. Me, not my car...
[Re: basketcase]
#1943840
11/02/15 06:34 PM
11/02/15 06:34 PM
OhioMopar
Mt.Gilead, Ohio
nope...dead in the water. my guy got copd and can't finish it.paint is pretty much off the worry list, I'll just enjoy driving it. At least you can enjoy it! We need to get together sometime when it warms back up.
[Re: Shoozy]
#1943844
11/02/15 06:38 PM
11/02/15 06:38 PM
OhioMopar
Mt.Gilead, Ohio
If it was easy.... Love your persistence - that's what the hobby is all about. Look forward to seeing you next year out on Woodward If I didn't keep going I would have a big, expensive paperweight! I have already said I was going two years (or was it three) in a row now. I'll just say this time that I'm setting aside vacation for it.
[Re: OhioMopar]
#1943908
11/02/15 08:34 PM
11/02/15 08:34 PM
basketcase
east side of Ohio
pretty much the way I look at it. It's not in a million pieces, and off the road for 10+ years. Had it out today, and had a nice drive. and as long as I'm in primer, no worries about scratching new paint. agreed on the get together.
