Re: Why don't more people run Edelbrock carbs?
[Re: Hot 340]
#1940020
10/28/15 12:00 AM
10/28/15 12:00 AM
Posts: 7,506 Az
Crizila
Az
I'm Not familiar at all with them. Never hear much about them either. Do they hurt power? Hard to tune? Good street carb. Easy to tune - come with an excellent tuning manual. Float bowls are too small for a serious fuel drinker.
Fastest 300
[Re: Hot 340]
#1940057
10/28/15 01:10 AM
10/28/15 01:10 AM
Posts: 701 Southern Maryland
preddy
Southern Maryland
I'm Not familiar at all with them. Never hear much about them either. Do they hurt power? Hard to tune? I can relate. I've been a Holley guy for a long time and recently was forced to live with Edelbrocks. My FHO Hemi has two Edelbrock 1805 Thunder Series 650 CFM carbs. These are designed for single carb applications not dual so they can dump a lot of fuel and had been leaned out considerably. So recently, I was driving it on the street and it being Fall, the air is really good around here and I when I stepped on it, I could feel the engine lean out and pop. I have a wide band O2 sensor and could also see it leaning out. I knew I was planning on running it at the Nostalgia Drags at Capitol on Saturday and knew I needed to fatten up the carbs. It was a piece of cake. I changed the front metering rods. Think of these like restricting the front jets so they control how much fuel the jets allow. The secondary jets are simple to replace. Just take the top off. It's about the same level of effort as taking the bowls off a Holley except you only have 1 fuel inlet to disconnect instead of 2 and, you need to disconnect the accelerator pump - it's easy with one clip. You can leave the fuel in the bowl while you do it. I changed the secondary jets from .086 to .092 and went to slightly smaller metering rods in the primaries - Tim Banning's suggestions . They allow more fuel through. The only thing that made it harder was the fact that I had 2 carbs to deal with. So I took it to the track on Saturday. I had no idea how the Edelbrocks would feel. I had no idea how they would perform and if I had the jetting right. I was rewarded with a second pass of 10.03 @ 134 and 1.37 60's. I'm pretty sure I could have run some nines if I had time to experiment with them. Those carbs worked great. Zero issues. The car was deadly consistent. I'm a believer now... http://www.tdspeedshotz.com/wp-content/g...015-CR-1225.jpghttp://www.tdspeedshotz.com/wp-content/g...015-CR-1419.jpg
[Re: Hot 340]
#1940111
10/28/15 02:57 AM
10/28/15 02:57 AM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
Can`t stand em, just like vac secondaries and street avengers...........Just my personal opinion, however in dual carb applications apparently they shine.......
[Re: mickm]
#1940146
10/28/15 03:55 AM
10/28/15 03:55 AM
Posts: 200 midwest
superchuck
On thin ice
On thin ice
midwest
because they suck! everyone knows that the holley is the only real carburetor for a muscle car.
oh... wait... LOL! I like my 1406. It does a great job keeping my papers from flying away when all the doors are open in my shop.
[Re: Hot 340]
#1940217
10/28/15 10:23 AM
10/28/15 10:23 AM
Posts: 5,160 Texas
dannysbee
Texas
Running good with what everyone else thinks is junk is part of the satisfaction of being a mopar guy.
Getting old just means you were smarter than some and luckier than others.
[Re: Hot 340]
#1940232
10/28/15 10:57 AM
10/28/15 10:57 AM
Posts: 13,351 Marion, South Carolina [><]
an8sec70cuda
Sixpackgut's car ran REAL good w/ the big block and a pair of Edelbrocks on a tunnelram.
[Re: Hot 340]
#1940250
10/28/15 11:20 AM
10/28/15 11:20 AM
Posts: 11,996 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
The CarterBrocks are not a bad design carb, there are just better choices today for most of us. I rarely install them mainly due to 3 issues; they often have a poor tune out of the box. They are more difficult to tune and to find tuning parts for. And there are superior designs readily available.
Compare the price, tune and design features of the new Street Demons, and I do not understand why anyone would buy a CarterBrock.
Master, again and still
[Re: Mr.Yuck]
#1940268
10/28/15 11:55 AM
10/28/15 11:55 AM
Posts: 9,814 MI, usa
dvw
MI, usa
because they suck... ok to be fair they work well on a street car, meaning not raced. If you want to go racing with them you'll need two. Not hard to tune, they just don't tune well. If you run a mild BB you'll need the 800 thunder. I've won a fair amount of races in both Pro and N/SS with them. Doug
[Re: Crizila]
#1940269
10/28/15 11:56 AM
10/28/15 11:56 AM
Posts: 7,506 Az
Crizila
Az
Ran a 1406 on a stock 400 in a big old Newyorker a while back. Came lean out of the box, but easily fixed with needle / jet change. Only issue was it had a tendency to heat soak in real hot weather. Went back to a modified TQ and the heat soak issue went away.
Fastest 300
[Re: Crizila]
#1940293
10/28/15 12:29 PM
10/28/15 12:29 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
Ran a 1406 on a stock 400 in a big old Newyorker a while back. Came lean out of the box, but easily fixed with needle / jet change. Only issue was it had a tendency to heat soak in real hot weather. Went back to a modified TQ and the heat soak issue went away. Now that's a sweet looking car
