Exhaust popping on deceleration #193606
01/14/09 06:09 PM
01/14/09 06:09 PM
Wi.
65_gt_rag_402 Offline OP
Wi.
What causes an exhaust pop in the exhaust system when deceleration.
When lifting on full throttle deceleration You will get a loud explosion in the mufflers.
What causes this ?
Rich side or header leak ?
65 DART GT RAGTOP mopars "AWESOME" 360 magnum stoker 402 Engine !!!!!!! ROCKS !!!!!!!!!! 11.0's on pump gas .
Re: Exhaust popping on deceleration [Re: 65_gt_rag_402] #193607
01/14/09 06:10 PM
01/14/09 06:10 PM
Northeast, Alpine, NY
9
9 Sec Phill Offline
On a road near you
9 Sec Phill  Offline
On a road near you
9
leak
Re: Exhaust popping on deceleration [Re: 65_gt_rag_402] #193608
01/14/09 06:13 PM
01/14/09 06:13 PM
Missouri
StrokerPost Offline
StrokerPost  Offline
Missouri
I have Hedman slip tube headers on my Dart and had that going on a few years back. I had one joint that was real sloppy, so I eliminated that joint and the popping quit.
Re: Exhaust popping on deceleration [Re: 65_gt_rag_402] #193609
01/14/09 06:13 PM
01/14/09 06:13 PM
Fl. USA
PS Arrow Offline
PS Arrow  Offline
Fl. USA
I've had it bubble and pop in the headers on decel from being too rich
Re: Exhaust popping on deceleration [Re: 65_gt_rag_402] #193610
01/14/09 06:19 PM
01/14/09 06:19 PM
Brea, Ca
Dart Racer Offline
Dart Racer  Offline
Brea, Ca
Did it just start after no changes in your combo? Do you have a roller cam? If so, the dist bronze gear might be worn. Mine had never popped and then all of a sudden with no other changes it started. Turns out it was the gear.
Re: Exhaust popping on deceleration [Re: Dart Racer] #193611
01/14/09 06:30 PM
01/14/09 06:30 PM
michigan
tonycpe Offline
tonycpe  Offline
michigan
Un burnt fuel in exhaust normally.
Old Fogey Racing Ltd.
Re: Exhaust popping on deceleration [Re: Dart Racer] #193612
01/14/09 06:37 PM
01/14/09 06:37 PM
Wi.
Wi.
popping started after installing a 2 inch carb spacer .
Does not do it all the time ! just happened about three times .
Cam is a hyd. roller .
distributor is a new mopar performance electronic item .
I do have a couple minor header exhaust leaks .... could be that .......
Re: Exhaust popping on deceleration [Re: tonycpe] #193613
01/14/09 06:44 PM
01/14/09 06:44 PM
Wi.
Wi.
could it be the transfer slots on the carb are exposed to much ? would this allow fuel to drop after deceleration? off throttle.
Re: Exhaust popping on deceleration [Re: 65_gt_rag_402] #193614
01/14/09 09:38 PM
01/14/09 09:38 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
header and or a exhaust leak.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Exhaust popping on deceleration [Re: bigtimeauto] #193615
01/14/09 11:30 PM
01/14/09 11:30 PM
Colorado
Leadfoot Offline
Leadfoot  Offline
Colorado
It's an intake leak. When you close your throttle plates at high rpm it draws in more air through where it's leaking without a fuel mixture. It doesn't have enough A/F mixture to ignite until after it gets to the pipes.
Re: Exhaust popping on deceleration [Re: Leadfoot] #193616
01/15/09 12:04 AM
01/15/09 12:04 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Exh leak. It is doing the same thing and air injection pump would do. The extra air it pulls in on decell from the exh is igniting the unburnt gasses in the exh. The air injection pump for emission controls basically does the same thing but they are dumped on decell so thats why cars with them dont do it. Ron
Re: Exhaust popping on deceleration [Re: 383man] #193617
01/15/09 12:06 AM
01/15/09 12:06 AM
Colorado
Leadfoot Offline
Leadfoot  Offline
Colorado
That makes Phill right. It's a leak.
Re: Exhaust popping on deceleration [Re: Leadfoot] #193618
01/15/09 04:36 PM
01/15/09 04:36 PM
Dirty Jersey
LilWalt426 Offline
LilWalt426  Offline
Dirty Jersey
Mine does the same thing- always a leak. My header bolts loosen up after a while. If i catch it in time i can just snug them up with out replacing the gaskets.
Re: Exhaust popping on deceleration [Re: LilWalt426] #193619
01/15/09 06:17 PM
01/15/09 06:17 PM
Tampa Florida
dc426 Offline
gotta keep'm separated
dc426  Offline
Tampa Florida
header gasket leak
Re: Exhaust popping on deceleration [Re: dc426] #193620
01/15/09 08:54 PM
01/15/09 08:54 PM
Colorado
Leadfoot Offline
Leadfoot  Offline
Colorado
But the popping started after installing a 2" carb spacer. That's where I would look for the leak.
Re: Exhaust popping on deceleration [Re: Leadfoot] #193621
01/15/09 09:14 PM
01/15/09 09:14 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
and you would be wasting your time.
Re: Exhaust popping on deceleration [Re: 65_gt_rag_402] #193622
01/15/09 11:28 PM
01/15/09 11:28 PM
Wi.
Wi.
I talked to my local speedshop here and they told me it is in the fuel distribution .
It is on the rich side.......
said to take a 1 or 2 jet sizes out the secondaries.
over abundance of fuel when lifting on the gas pedal.....
Makes sense to me ..... You need Fuel + air + heat to have it explode in the exhaust system Right ?
how can a header or intake leak cause it to pull fuel out of the carb when lifting ? it needs that extra fuel to feed the explosion.
Re: Exhaust popping on deceleration [Re: 65_gt_rag_402] #193623
01/15/09 11:46 PM
01/15/09 11:46 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
As I had said it just like an emission air pump which injects AIR into the exh to ignite any unburned fuel and cut down on emission's. Not everything burns in the cyl on ign so if any air is pulled into the exh on decell it can ignite the unburned fuel sorta like what a diesel does. Now of course if the car runs to rich it can make it worse but if there is no air pulled or pumped into the exh then it can be way rich and still wont pop on decell if the car runs an exh system and not open headers. It could have had a small leak that was not enough to cause a poping but if you change the mixture then that small leak may be enough to cause the poping on decell. And you also slam the throttle shut on decell which cuts off the air going into the eng on decell. There are other things that may cause the poping in the exh on decell but 99% of the time it is an exh leak. Ron
