Page 5 of 5 1 2 3 4 5
Re: Moving Battery to trunk, do you have to have a shut [Re: RobX4406] #193353
01/17/09 05:33 PM
01/17/09 05:33 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Granted it isn't legal to hook it up the way I mentioned in the post above as it would not kill power as long as the engine is running off alternator output but once the ignition is shut off the alternator power wire would be dead with the master cut off shut in the off position until the ignition power switch or the master switch is switched to on. But with both switches off it would be dead as in sitting in a trailer or in the pits. Not legal NHRA legal but the power would be dead but wouldn't kill as long as the alternator was charging.
You do your others can do your thing and me and many others will do ours. Hope you rewire your drivers so that they are dead when you throw the switch there lot more live wires there with the ignition off. That way you can sleep easier.
Re: Moving Battery to trunk, do you have to have a shut [Re: MoparforLife] #193354
01/17/09 07:08 PM
01/17/09 07:08 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
Dont like the sound of that ,Worse case scenerio ,eg ,Motor running,,,crash or accident occurs down track,,,,motor still running or fire,,,,driver might not be able to shut off ignition inside car ( cant reach it,,or too dazed to shut it off) ,,,,track personal run up to car to help,,,, track personal cant kill car with switch on back of car ??
Re: Moving Battery to trunk, do you have to have a shut [Re: MoparforLife] #193355
01/17/09 08:00 PM
01/17/09 08:00 PM
Illinois
Mopar_Ray Offline
Mopar_Ray  Offline
Illinois
Oh master electrical god, it is dead with the switch in the off position when wire it to the off side of the switch so it is only connected with the switch in the on position. Ever think of that oh brilliant one.
OK another question I wish I never asked!
Re: Moving Battery to trunk, do you have to have a shut [Re: 69CHARGERMD] #193356
01/17/09 08:24 PM
01/17/09 08:24 PM
Upper Midwest
Upper Midwest
Like I said it ain't legal but have seen it done because they hook it up that way and it is dead. They turn it on and things work. They turn engine off with ignition switch, hit main and all is dead. A lot of people don't try to hit the main with the engine running to see if it will kill everything and just take for granted that because it is dead when it is off and alive with the ignition on it is right and track legal, when in reality it isn't. Yes every thing is dead when when everything is shut down. But not when you need it. Point I was trying to make is that there are many ways to hook up the main, some may work but not be racing legal but everyday functional and a theft deterent or what ever and there are also several race legal ways to hook up a main.
Re: Moving Battery to trunk, do you have to have a shut off [Re: PLUM BAD] #193357
01/17/09 08:58 PM
01/17/09 08:58 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
I made mine so the switch can be turned off and on from inside the car or behind it. I can't count how many times I got in and forgot to turn on the power. Not any more.
Awsome ! Idea of the month ! Thank you !
Re: Moving Battery to trunk, do you have to have a shut off [Re: VernMotor] #193358
01/17/09 10:58 PM
01/17/09 10:58 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I would also think one reason NHRA wants a cutout switch when the battery is in the trunk is because if the car needs the power killed with the battery in the trunk they may not be able to open the trunk. The hood can usually be opened even if a car crashes but most of the time you need the key to open the trunk and unhook the battery if the battery is in the trunk. Ron
Re: Moving Battery to trunk, do you have to have a shut off [Re: 383man] #193359
01/17/09 11:12 PM
01/17/09 11:12 PM
Bristol, Va
fasteddie Offline
fasteddie  Offline
Bristol, Va
Good Lord! Some people make even the simplest things complicated and fight about it.
Call Mark at Mad electrical and he will supply you with all you need, wiring, relays, and most important, instructions.
Wire it the way he says in the supplied instructions and you will be safe and legal.
2003 Bristol Dragway Sportsman Champion
2016 Bristol Dragway Power Hour Champion
Re: Moving Battery to trunk, do you have to have a shut off [Re: fasteddie] #193360
01/18/09 12:49 AM
01/18/09 12:49 AM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
My disconnect switch had 4 terminals on it. One set is large for the main battery cable, and one set is small for the alternator batt wire. I run a smal jumper from the battery larger terminal, to the small terminal. The other small terminal goes to the alternator.
No relay needed.
Re: Moving Battery to trunk, do you have to have a shut off [Re: NTOLERANCE] #193361
01/18/09 09:53 AM
01/18/09 09:53 AM
Upper Midwest
Upper Midwest
NTOLERANCE - Nice switch - really simplifies and things. Like said there are a lot of ways to do this and with out robbing a bank to do it.
Re: Moving Battery to trunk, do you have to have a shut off [Re: NTOLERANCE] #193362
01/18/09 10:53 AM
01/18/09 10:53 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
No relay needed.
I hope those little terminals are rated for more than 30 amp..most alternators put out at least 60A and average is 80A...usualy those smaller terminals would be reserved for the ignition which is a great idea...I use mine that has 2 poles for ignition and I use a solonoid for disconecting the power from the alternator so I dont have any HOT wires leaving the Trunk/battery area...and when the switch is OFF...its all OFF..
there are other ways Im sure...I believe there maybe a switch that has the two poles rated for the higher amperage
Re: Moving Battery to trunk, do you have to have a shut off [Re: smokinwoody] #193363
01/18/09 11:00 AM
01/18/09 11:00 AM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
This switch is from an industrial application. ITs all copper contacts inside, and while the terminals do seem small, I dont anticipate a problem. I dont have alot of power accessories. Headlights would be my biggest concern.
Re: Moving Battery to trunk, do you have to have a shut off [Re: NTOLERANCE] #193364
01/18/09 11:05 AM
01/18/09 11:05 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
the other reason why Im saying this about those switches is...I did the same thing you are doing on my other car...my switches also are heavy duty copper contacts...I went back to the switch as the car was running,and that switch was so hot it felt like it was going to go into meltdown...I went and switched over like I did in the race car and it doesnt have nearly the heat build up...
Im just saying those smaller contacts/terminals have a much lower rated load capacity...and be careful...
Re: Moving Battery to trunk, do you have to have a shut off [Re: smokinwoody] #193365
01/18/09 11:44 AM
01/18/09 11:44 AM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
One thing I have not seen covered in this thread is the size of wire..If you do not run a big good wire from the alt to relay/switch..your car will not charge good. I think it need to be #6 or bigger. one of my car has #8 on it and I lose 2 volts by the time it gets to the Battery..Long ways back there.
Re: Moving Battery to trunk, do you have to have a shut off [Re: smokinwoody] #193366
01/18/09 02:30 PM
01/18/09 02:30 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
No relay needed.
I agree with Woody. What is it's rating?
Also, what is the cost of the 4 post compared to a 2 post and relay. My 2 post switch cost right at $20-25 and the relay is $13-15.
I run very fine strand wire from the Alt to the relay. No matter if you run a relay or not, you'll have drop for the longer run.
Re: Moving Battery to trunk, do you have to have a shut off [Re: RobX4406] #193367
01/18/09 09:30 PM
01/18/09 09:30 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
I thought the 4 post switch was like $30.00 Been awhile since I bought it. I cant find it in my catalog now.
I am running welding cable for the battery/power cable.
