Page 1 of 5 1 2 3 4 5
Moving Battery to trunk, do you have to have a shut off #193273
01/14/09 03:18 PM
01/14/09 03:18 PM
Tulsa, Ok
WadeMetzinger Offline OP
Tulsa, Ok
I'd like to move the battery to the trunk of my wife '68 Cuda but since it's also a street car I do not want to put a shut off on the back of the car.
It's my understanding that there is an IHRA/NHRA rule requiring one but I was wondering if there was also and ET break for when it's required or does it not matter what ET, if you have it in the trunk you have to have an external shut off?
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
Re: Moving Battery to trunk, do you have to have a shut off [Re: WadeMetzinger] #193274
01/14/09 03:22 PM
01/14/09 03:22 PM
michigan
tonycpe Offline
tonycpe  Offline
michigan
Batt relocated to trunk = rear shut off for all power . you knew you knew the answer.
Old Fogey Racing Ltd.
Re: Moving Battery to trunk, do you have to have a shut off [Re: WadeMetzinger] #193275
01/14/09 03:30 PM
01/14/09 03:30 PM
Indy
FlyFish Offline
FlyFish  Offline
Indy
Yes you have to have one. On my 67 cuda its right through the center of my license plate.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: Moving Battery to trunk, do you have to have a shut off [Re: FlyFish] #193276
01/14/09 03:36 PM
01/14/09 03:36 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
What most guys who are opposed to the look do, is use a push pull type of switch.
then you run the rod for the knob/switch through a small hole in whatver part you like.(a lense or behind the plate, or whatever)
Then, when not in use just unthread the rod, and put it in the glove box.
Re: Moving Battery to trunk, do you have to have a shut [Re: dave571] #193277
01/14/09 03:38 PM
01/14/09 03:38 PM
organ
maximum entropy Offline
Happy Birthday maximum entropy  Offline
organ
not only do you have to have a shut off at the back of the car, but the battery needs to be in an nhra approved box vented to the out side, or you need a rear firewall. bolted down with minimum 3/8 studs x2.
Re: Moving Battery to trunk, do you have to have a shut off [Re: dave571] #193278
01/14/09 03:39 PM
01/14/09 03:39 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Also need a metal fire wall between the trunk area and the passenger compartment.
Re: Moving Battery to trunk, do you have to have a shut off [Re: dave571] #193279
01/14/09 03:41 PM
01/14/09 03:41 PM
Renton Washington
Triple Threat Offline
Renton Washington
There are ways to make it easier and less conspicuous on a street car. Through the license plate, under a tail light.
My car is just as much of a street car as a race car, With glass bumpers I said screw it and just mounted it in the bumper as normal. The handle is close to body color though so it doesn't stick out quite as much. Never been hassled in tech about it either.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Moving Battery to trunk, do you have to have a shut off [Re: dave571] #193280
01/14/09 06:16 PM
01/14/09 06:16 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
That is a great Idea.
I used a push/pull on Gina's car and was concerned about someone bumping it while we were driving on the street.
I used one of the existing hole in the bumper to put the rod through. If you have any it's an alternative to drilling into the body. I did have to ream it a little larger. But, if you take the rod out, you'll never notice.
Re: Moving Battery to trunk, do you have to have a shut off [Re: WadeMetzinger] #193281
01/14/09 07:09 PM
01/14/09 07:09 PM
AndyF Offline
AndyF  Offline
It depends on the track and how fast the car is. The local track here doesn't require an external shut off even though the rules require it. I've had my car thru tech several times and the tech guy has never been concerned about my lack of an external shut off. He looked over my trunk mounted battery closely and examined the straps that hold it down and then said I was good to go.
Re: Moving Battery to trunk, do you have to have a shut off [Re: AndyF] #193282
01/14/09 10:35 PM
01/14/09 10:35 PM
Gilbert, AZ
Aspen7695 Offline
Aspen7695  Offline
Gilbert, AZ
Obviously the tech inspectors at your track don't know what they are doing, or they are too lazy to do the job they are trained to do. Just because they are not following the rules does not excuse you from following them. You obviously know better. Do you even have a rear firewall?
I don't mean to be a fanatic, but I am a certified NHRA tech and I take the job personally.
Raul
Re: Moving Battery to trunk, do you have to have a shut off [Re: Aspen7695] #193283
01/14/09 10:48 PM
01/14/09 10:48 PM
Southwestern Ontario Canada
racealittle Offline
racealittle  Offline
What about the newer Chrysler products that come with the battery factory mounted in the trunk? I've seen them running at the track without a shutoff switch or a battery box.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen! Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
Re: Moving Battery to trunk, do you have to have a shut off [Re: racealittle] #193284
01/14/09 11:07 PM
01/14/09 11:07 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
Ah-Ha!!! A can of worms here???
Re: Moving Battery to trunk, do you have to have a shut off [Re: superwrench] #193285
01/14/09 11:12 PM
01/14/09 11:12 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
IIRC, it's required IF you move the battery from the factory location.
No worms on the loose
Re: Moving Battery to trunk, do you have to have a shut off [Re: racealittle] #193286
01/14/09 11:13 PM
01/14/09 11:13 PM
Upper Midwest
Upper Midwest
Don't need a box.
Re: Moving Battery to trunk, do you have to have a shut off [Re: RobX4406] #193287
01/14/09 11:23 PM
01/14/09 11:23 PM
Colorado
Leadfoot Offline
Leadfoot  Offline
Colorado
Does killing "All" power mean it kills the engine and it will not crank either? I can't think of a way to do it with a single set of contacts like most switches that I've seen. I've never put a lot of thought into it either.
Re: Moving Battery to trunk, do you have to have a shut off [Re: Leadfoot] #193288
01/14/09 11:30 PM
01/14/09 11:30 PM
Upper Midwest
Upper Midwest
Not hard to do. All you have to do is to run the alternator battery wire to the + side of the battery or the shut off switch. Then when the switch is turned to off it kills the battery flow that energizes the alternator. A lot of people also hook in a Ford type solenoid but it is not needed to kill the power.
Post deleted by Defbob [Re: Leadfoot] #193289
01/14/09 11:32 PM
01/14/09 11:32 PM
Re: Moving Battery to trunk, do you have to have a shut #193290
01/15/09 12:06 AM
01/15/09 12:06 AM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
i'm trying to figure this out too. so duster dave where does the big pos battery cable go to? the cold side of the switch?
Re: Moving Battery to trunk, do you have to have a shut [Re: dirtybee] #193291
01/15/09 12:11 AM
01/15/09 12:11 AM
Colorado
Leadfoot Offline
Leadfoot  Offline
Colorado
So now we have three wires going from the trunk to the front. 1 Big one and 2 little ones.
Alternator and battery go to the left side and out the right side we go to the starter with the big one and the relay with the little one.
I think I get it now.
Re: Moving Battery to trunk, do you have to have a shut [Re: Leadfoot] #193292
01/15/09 12:13 AM
01/15/09 12:13 AM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
wha?
i got to go to bed but i've been trying to figure out how to make my 2 post moroso shut off switch work ever since i bought it over a year ago soi'll check back in 2morrow. thx, dave
