front end cam bolt question
#1930352
10/11/15 07:02 PM
10/11/15 07:02 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
replacing the old crusty cam bolts on my RR and was faced with a choice, Plus / Minus 2-1/2 Degree Camber from NAPA or 1 1/8 from AdvanceAuto. is this THAT critical. i'd rather go with NAPA Yes upper control arms
Re: front end cam bolt question
[Re: mikemee1331]
#1930387
10/11/15 08:02 PM
10/11/15 08:02 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I assume you mean upper control arm adjusting bolts and not camshaft retaining bolt(s)?
If the UCA bolts, more is better abd I agree with NAPA over AA.
