Re: PTC or Dynamic
#192662
01/13/09 09:08 PM
01/13/09 09:08 PM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
Sorry I can't comment on either, but I have dealt with ATI and Ultimate Converter Concepts and both are great to deal with.
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Post deleted by Defbob
[Re: 68DART360]
#192665
01/13/09 09:56 PM
01/13/09 09:56 PM
Re: PTC or Dynamic
[Re: begood]
#192669
01/13/09 11:12 PM
01/13/09 11:12 PM
Posts: 6,293 Northeast, Alpine, NY
9 Sec Phill
On a road near you
On a road near you
I ran a used PTC in the cuda for a year then went to Dynamic, Called Frank and told him what I had, he sent out a custom unit that has been great for the car, 8" 5100 stall street use, best 1.36 60' with street tires and exhuast. I would use him again if I build another auto car. there was 3 tenths diff in ET, the dynamic being faster...Phill
Re: PTC or Dynamic
[Re: gch]
#192671
01/13/09 11:25 PM
01/13/09 11:25 PM
Posts: 3,009 Sac, CA
mopowers
Sac, CA
I have never run a PTC.I will NEVER run another dynamic.
It'd be nice if you explained why.
Re: PTC or Dynamic
#192673
01/14/09 12:24 AM
01/14/09 12:24 AM
Posts: 1,260 New Mexico
Adobedude
New Mexico
This is hoping that everyone says to PTC.
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
[Re: ccdave]
#192674
01/14/09 12:24 AM
01/14/09 12:24 AM
Re: PTC or Dynamic
[Re: gch]
#192675
01/14/09 12:38 AM
01/14/09 12:38 AM
Posts: 657 B.C.
mk_
B.C.
My feelings as well......dynamic is by far the worst convertor company I've dealt with. Here's my story: After spending $1800 with them on a convertor(initial cost plus it had to go back 2 times)and less than 20 total runs........all I got was a piece of junk. The stall speed was way off every time it came back from them by up to 1000 rpm.......the hub register that sits in the back of the crank was real loose and sloppy......it was 1.800", you could move the convertor up and down quite a bit before the convertor bolts were in. All the other convertors I have measure 1.810". Shaun told me to just put a piece of plastic between the crank and convertor hub............real professional! We cut the convertor open (4 runs after it came back from them the last time) and it looked like a 3 year old bent the fins with a ball pein hammer.....what a mess.........the work was disgusting.....I have pics somewhere. I ended up writing them a letter explaining how disappointed I was with thier work. Then I gave the exact same info about my car/engine to a different convertor company and they nailed everything right the first time.
Re: PTC or Dynamic
#192676
01/14/09 12:45 AM
01/14/09 12:45 AM
Posts: 13,185 aZLiViN
J_BODY
aZLiViN
I would suggest that you give Lenny a call at Ultimate..but I'm sure that either of the two you are considering would be fine also.
Re: PTC or Dynamic
[Re: Smoparmike]
#192679
01/14/09 10:36 AM
01/14/09 10:36 AM
Posts: 1,178 Indy
FlyFish
Indy
