street/strip 360 cam help
#192638
01/13/09 08:38 PM
01/13/09 08:38 PM
Posts: 117 @ the shop
E-85 408 DART
@ the shop
so car weighs 3400 ,3:91, 4-speed street/strip .already have eddy heads may or may not get ported but will get good valve job .hughes roller rockers,kb-107s,700dp w/proform main body ect..need help with cam !!
"Tappet" lead fabricator for the legendary "Flat & Tappet" race team .
Re: street/strip 360 cam help
[Re: E-85 408 DART]
#192639
01/13/09 09:16 PM
01/13/09 09:16 PM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
I put a Lunati Voodoo cam .517 lift in the 360 I built for my Mom's Duster. It is pump gas and about 10.2to1 compression. Steel worked J heads, 750, Airgap, 3200lbs and has run 11.70's in the 1/4 with an ignition problem. 7.44@91 was the best in the 1/8th. It idles at 800rpm and makes great torque. Car has gone 1.62 60'. Good luck. I don't know if this is the best cam for you but it's a good cam. A nice hydraulic roller would be cool.
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
[Re: Jacob Pitt]
#192640
01/13/09 09:28 PM
01/13/09 09:28 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Gina's 72 has almost the same set up. Only difference between hers and your is the auto trans.
We have a Luanti Vodoo cam in it. Jegs PN 638-60403LK
We got it together just before the season ended so we have yet to get the combo fine tuned but it has gone a best of 12.97.
[Re: justinp61]
#192643
01/13/09 10:19 PM
01/13/09 10:19 PM
Posts: 16,122 Grand Haven, MI
patrick
Grand Haven, MI
hydraulic or solid? flat tappet or roller?
I'll probably suggest smaller on the race board than most, but I'd keep .050 duration down to the 224-230 range for .050 duration on the intake for good streetability.
hydraulic, I'd look at a voodoo 670403 or comp XE275HL, or similar .050 duration hughes grind.
juice roller, I'd look at a comp XR274HR or XR280HR or similar duration hughes grind....
solid, probably something designed for a ford .875" lifter for a flat tappet--I'd be real leery of a comp MM lobe cam for low maintainence street duty...roller, again I wouldn't go super aggressive (even though you don't have to worry so much about eating lobes) to get some semblance of sping life. for a solid, I'd probably look for one that has 230-245 .050 duration on the intake.
[Re: patrick]
#192644
01/14/09 06:16 AM
01/14/09 06:16 AM
E-85 408 DART
@ the shop
thanks for all of the help guys !!i think i have it narrowed down to just 3 cams .comps (xs282s)solid (xe275hl)hyd ,or even lunati (lun-60403lk) .now will these cams all work with the ootb edelbrock springs . and if i go with the solid do i just drop the lifters in and go or is there some oil mods that should be done .thanks again
