Page 13 of 13 1 2 11 12 13
Re: 37 Plymouth PU Ressurection. [Re: jingro] #1923944
10/02/15 03:51 AM
10/02/15 03:51 AM
Dreaming of the 808
AZ_A12_BEE Offline OP
Dreaming of the 808
Originally Posted By jingro
Which transmission mount did you order from Speedway Motors?
I think I used this one, with the bolt on end caps
http://www.speedwaymotors.com/Tubular-Transmission-Mount-with-2-Inch-Drop,4219.html
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: 37 Plymouth PU Ressurection. [Re: AZ_A12_BEE] #1924825
10/03/15 12:04 PM
10/03/15 12:04 PM
New Mexico USA
jingro Offline
jingro  Offline
New Mexico USA
Do you want to get rid of your old transmission mount? I could use it on mine. Thanks
Re: 37 Plymouth PU Ressurection. [Re: jingro] #1926724
10/06/15 12:34 AM
10/06/15 12:34 AM
Dreaming of the 808
Dreaming of the 808
It was just a piece of channel iron, not a original mount
Re: 37 Plymouth PU Ressurection. [Re: jingro] #1930611
10/12/15 01:39 AM
10/12/15 01:39 AM
Dreaming of the 808
Dreaming of the 808
Next item to address, replace the hillbilly motor mounts and brackets with this new cross member and motor mounts that I got from Speedway motors
