Re: Best rust penetrant?
[Re: ahy]
#1955203
11/21/15 02:03 AM
11/21/15 02:03 AM
Posts: 4,395 The Pale Blue Dot
Skeptic
The Pale Blue Dot
I believe the 50/50 acetone/ATF works... that said, how many of us use heat if the fastener won't move with reasonable torque? Hitting acetone + ATF with a torch would be "interesting". It's not that dramatic, it does burn and I'm sure some hamfisted mekanik has burned some car/building/themselves/other. The idea is to gradually build heat, then spray the penetrant. Going back and forth on torque helps too.
[Re: McCandlessboy]
#1955307
11/21/15 12:43 PM
11/21/15 12:43 PM
Posts: 1,487 STL
cdstl
STL
I've never used Kroil, and probably never will since it's not on a store shelf. I'm sure it's good stuff.
Hands down I will always use the 50/50 Acetone Trans fluid mix. I broke loose 11 45-year old brake line nuts without twisting the line. I can, and will, reuse all of them.
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
[Re: cdstl]
#1955323
11/21/15 01:33 PM
11/21/15 01:33 PM
DaytonaTurbo
Manitoba, Canada
I've never used Kroil, and probably never will since it's not on a store shelf. Some auto parts stores have it on the shelf, although I have never used it.
[Re: DaytonaTurbo]
#1955361
11/21/15 02:35 PM
11/21/15 02:35 PM
Posts: 15,299 Omaha Ne
TJP
Omaha Ne
we've tried, Kroil, I wasn't impressed PB works but stinks A couple brands of the freeze off by different companies, Rip OFF Liquid wrench so-so A friend at another shop gave me a can of Free all to try and it is the current favorite in the shop. it has consistently worked where others did not. it is not readily available so I buy it online by the case http://www.alliedelectronics.com/FS16.html
[Re: McCandlessboy]
#1955401
11/21/15 04:12 PM
11/21/15 04:12 PM
Posts: 1,487 STL
cdstl
STL
I had to remove the pitman. I removed the nut and got all of the rust and grease off of the splines so the the Acetone mix could penetrate. I was careful not to squirt the stuff everywhere because I wanted to see how it would go through when I squirted it on the nut side. After about a half hour the stuff started running out of the bottom side towards the steering box.
[Re: McCandlessboy]
#2618588
02/08/19 11:38 AM
02/08/19 11:38 AM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
This is a followup to the article Dogdays posted. I've highlighted the things I think are helpful clarifications. Machinist's Workshop V20 number 2, April/May 007, page 35 Article: “Testing Penetrating oils” This reports a test of penetrating oils where they measured the force required to loosen rusty test devices. The details reported here were validated by the original article author. He also added some details on the methods. You must buy the issue if you want to see how they did the test. The back issue is available for purchase. The table below extracts the results table The lower the number of pounds the better. Interesting that a simple mix of acetone and power steering fluid (PSF) works the best!
Penetrating oil Average load Price per fluid ounce None 516 pounds WD-40 238 pounds $0.25 PB Blaster 214 pounds $0.35 Liquid Wrench 127 pounds $0.21 Kano Kroil 106 pounds $0.75 PSF-Acetone mix 53 pounds $0.10 (50/50 mix)
Notes from original article author: 1) These are loads required to free the test piece after 8 hours of immersion in penetrating oil. This is probably not representative of a quick squirt just before a wrench is applied. 2) The original article states ATF was used in the DIY mix. It was actually PSF. I corrected the table to reflect this.
© Copyright 8 February 2008, 63Avanti@sterkel.org Permission to print and post on the internet in this form received from the author 8 February 2008 Avanti.org is gone. Maybe its been saved in archive.org I haven't looked. There are various power steering fluids so we can only guess that the one used was one with low viscosity and high detergents. My own experience has been that PB Blaster is good when applied the day or days before. Even better reapplying each day. I like it for situations where impact is not possible or seems inappropriate. Removal usually requires slow steady force. Stuff doesn't 'break free' but feels more like a fastener with interference fit. Kroil seems better for last minute use. Sili-kroil seems to help more in making it easier to turn once the bolt has broken free. I agree with those that like the sprays specifically for freeing equipment
[Re: homemadetools]
#2618657
02/08/19 02:21 PM
02/08/19 02:21 PM
RapidRobert
Hey guys - we have a new free ebook of homemade car tools: Good info, (much) appreciated!
[Re: McCandlessboy]
#2618679
02/08/19 02:57 PM
02/08/19 02:57 PM
Posts: 3,392 cheshire, ct
davesmopars
cheshire, ct
I use Seafoam Deep CreeP for years one of the best I think
Keeper of the 440 M code Cuda registry mcodecuda@yahoo.com
[Re: davesmopars]
#2618695
02/08/19 03:33 PM
02/08/19 03:33 PM
Posts: 5,357 Rancho Cordova, California (Sa...
hemi71x
I use Seafoam Deep CreeP for years one of the best I think I bought a can of that last month, to give it a try, as it's available locally, at pretty much all the parts stores. Kroil, i have to order thru the manufacturer, and now shipping costs make it prohibitive. That Seafoam stuff works well, my two cents on the subject.
RF-4C Phantom 69-370 Zweibrucken, Germany
[Re: McCandlessboy]
#2618699
02/08/19 03:41 PM
02/08/19 03:41 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Kroil - free delivery with Prime
[Re: McCandlessboy]
#2618712
02/08/19 04:13 PM
02/08/19 04:13 PM
Supercuda
About to go away
About to go away
up yours
Pays for itself real quick. But to each it's own
[Re: McCandlessboy]
#2618760
02/08/19 05:30 PM
02/08/19 05:30 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
If you want good quality stuff, go to a real hardware store, not home depot or lowes, Autozone, Advanced or Oriellys.... I use Grainger, Industrial Supply, Marshall's Industrial Hardware, Fastenal...McMaster Carr for mail order. Most of the chain auto parts stores do not have quality anything hardware/chemical wise typically unless they get it at a price point that they can make an uber profit.
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: McCandlessboy]
#2619068
02/09/19 02:42 PM
02/09/19 02:42 PM
Posts: 954 Chicago
PurpleBeeper
Chicago
Having worked in the automotive chemical industry and having done a lot of testing.....PB Blaster is the best
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
