Re: Refreshed 440 sounds like a diesel - video
[Re: Charger446]
#1926251
10/05/15 02:35 PM
10/05/15 02:35 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Again,thank you all for the replies and suggestions, the engine in that last video sounds a bit similar, but mine doesnt change when the engine warms up.
Im pretty sure the bearings were installed correctly, once the motor warms up, the pressure will stay between 40 and 50 PSI, its pegged when cold.
I need to look at the side to side clearance of the aluminium rockers as I know for a fact I added a few shims this time around to get the roller over the valve stem centered. I know I have a few that feel very tight, I cant even get them to move at all.
John, If you have a cut up cover that you wouldnt mind bringing by, that would be great, let me know if you are around later this week. Thanks again guys!!
Mike
FWIW I was worried when I first fired this thing up. To the point where I was chasing everything. A friend stopped by and said sounds ok to me (has a lot of experience)then another told me his Ross pistons were loud as heck too, and long story short the engine had at least 40 runs on it (driven to and from the track) ran 11.30's shifting at 64-6600 and lots of street blasts when I sold it. Still running hard from what I understand.
[Re: Mr.Yuck]
#2512917
06/25/18 10:00 AM
06/25/18 10:00 AM
Posts: 282 Northeast MA
Charger446
Northeast MA
It has been a while since I posted on this topic. I have since put about 550 miles on this motor since the refresh and the noise has been and remains there. The engine has great oil pressure, doesn't smoke and was very powerful and responsive so I was very surprised with what I saw when I did some diagnostics this last weekend.
I don't know why I never did this test until now, but regardless I did a compression test on Saturday. Not sure if it was because the engine was cooling off but I got some strange numbers. I did the test with all the plugs out but forgot to open the butterfly on the carb, not sure how much that changes things. On the drivers side bank, the cylinders were all around 155 PSI, however on the passenger side, the numbers were higher, all around 190 PSI except for #8 which was zero!!! All of the other plugs looked good, light cocoa color except for number 8 that was still brand new and shiny.
So for 550 miles I have been running on 7 cylinders, I still cant believe how well it ran like this, but with the 484 cam, I just thought the rough idle was how it was supposed to be.
I am at a loss as to what this could be, seems like it was like this from first fire. Time to pull off a valve cover, do a leak down test after I visually inspect everything. I recall everything looking normal when I last checked it, meaning the pushrods going up and down, etc but who knows for sure.
What is ironic is someone posted back in 2015 that they heard a miss in the one of the videos I posted. Very good, it certainly did have one!
[Re: Charger446]
#2517263
07/04/18 01:15 AM
07/04/18 01:15 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
OK, I guess I'll be first in to say good luck on your cam / lifter swap. The cam bearing would be the last bearing I would look at. If your not going to pull the pan, pull the oil pump , no real cost , just a gasket and you can make that. Pull the pump apart for a inspection. That will tell you what your bearings will look like. Go from there. If it looks like rats have been chewing away at the gears you might want to pull the engine down for a review. I have got away with a cam /lifter change out and at that time I was using a double filter set up . As bad as your lifter looks your filter couldn't have caught all the metal. In the end it's your money , do as you think that is best for your wallet.
[Re: Charger446]
#2517358
07/04/18 11:05 AM
07/04/18 11:05 AM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I’d cut the filter open for a look inside as well as pulling the pump apart.
[Re: Charger446]
#2517405
07/04/18 12:18 PM
07/04/18 12:18 PM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
When I had my 383 magnum rebuilt for the first time 25 years ago , I reused a Mopar 284/484 cam and lifters that I had installed the year before
Machine shop said cam and lifters looked fine , well Lasted about a month , same situation as yours
Installed a new Mopar 284/484 cam and lifters , never took anything else apart on that new motor
25 years later , wiped out that same cam and lifters when I tapped a piston with the intake valve on my newly installed Edelbrock Heads
Long story short
432 Stroker now
Machine shop said all my bearings , crankshaft , cylinders looked good for a 25 year old motor
They did the short block , gave me all the old pistons , rods , crankshaft , bearings etc.
I took the oil pump apart this winter (This 25 year old motor had 75 psi hot at cruise and 35 psi at idle)
Inside the Melling HV oil pump it looked like someone took 60 grit sandpaper , a grinder , jack hammer you name it
I have no idea how it still rotated , it was that bad
Like I said , rest of the motor , bearings looked pretty damn decent
Replace the oil pump for piece of mind
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: Charger446]
#2517492
07/04/18 02:46 PM
07/04/18 02:46 PM
Posts: 43,097 Bend,OR USA
Cab_Burge
[Re: Charger446]
#2517856
07/05/18 10:28 AM
07/05/18 10:28 AM
Charger446
Northeast MA
Thanks guys, appreciate your feedback. I do plan on pulling that pump off and will have a look in there.
Now I have to shop for a cam and lifter set. I am looking at the Lunati Voodoo series cams, I just need to give them a call and talk about which one would work best for this engine and car.
Right now, I'm leaning towards the 60303, I just want something like the Mopar 284/484 but with better street manners.
[Re: ccdave]
#2518102
07/05/18 07:09 PM
07/05/18 07:09 PM
Challenger 1
Cincinnati, Ohio
This is why I refuse to build any engines with flat tappet cams. You can do everything right and still end up with a lobe/lifter failure... No thanks.... IMO everything was not done right on this build because the pre load was not set correctly or even checked. That does not make all flat tappet cams bad, IMO.
[Re: Charger446]
#2518138
07/05/18 08:36 PM
07/05/18 08:36 PM
Challenger 1
Cincinnati, Ohio
It was making a similar noise with the 1.6 roller rockers, but it seems worse with the stock ones in.
I didnt check the preload with the stamped rockers, just torqued the bolts down to spec.
On the roller rockers, I set them initially at 1/2 turn after having what I thought was zero lash, then i adjusted them a 1/4 turn at a time, the noise didnt get better or worse, then I just swapped them out for the stockers. That is as far as I got.
I figured the stock rockers would take the variable of the adjustable roller rockers out. It is not like setting valve lash on a hydraulic cam. You set them once and forget about them for ever. The number of turns is different for each valve, they will not be all the same turns. And once set on a hydraulic cam you should not adjust them while the motor is running, sure way to get them wrong. This is where I read you just bolted them on without checking pre load. I can be 99% sure the pre load was wrong. Also I called Edlebrock when installed my heads and was told to use 1.5 rockers. So I sold my 1.6 and got 1.5 rockers. 1.5 ensures push rod clearance and acceptable geometry for novice builders like you and me. Both my motors have proven durable during 11 years of beating them. My 340 has been beat to heck out at Bonneville all 4 times I have had the car out just messing around. Every drive your car for miles and miles at near wide open throttle. I have and I could not hold it at wide open throttle because it would over rev. I have many hi performance miles on them and the valve pre load is good and I have never adjusted it since I built the motor. I use Crane gold rockers on both motors.
[Re: Charger446]
#2518154
07/05/18 09:05 PM
07/05/18 09:05 PM
Challenger 1
Cincinnati, Ohio
When you setup the pre load, I have to see the lifter plunger in the top of the lifter. I make sure it is at the top and take out any play while spinning the push rod. Once I am sure there is no lash and the plunger is still at the top of the lifter against the retaining clip, then I set the pre load. Some rockers have different threads and adjusters so you can't say 1/4 or 1/2 turn is correct across all motors. I will see how many turns it takes to gently bottom the plunger and then set my pre load accordingly. I like the plunger in the middle to the top 1/3 of the lifter, has always worked me for many hydraulic cam installs. Years ago I installed hi po cams in many local cars for friends and even as side jobs for extra work. Then I eventually raced a top alcohol dragster where I set the valve lash before every run. I took out the push rods every night to preserve the hi dollar valve springs...hundreds of times. There's my push rod holder for a brad hemi.
